Old 10-18-2015, 03:14 PM   #126
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I forgot to mention how great my cab dolly system works. I can roll it around as well as roll it over to front or back. Made my job a whole lot easier.
Metaldoc is offline   Reply With Quote
Old 10-18-2015, 04:20 PM   #127
Advanced Design
Advanced Design's Avatar
Re: 67 long box
That is a really trick cab dolley stand. Any problems rolling it over on the forks so you can get to the bottom?
Advanced Design is offline   Reply With Quote
Old 10-18-2015, 04:40 PM   #128
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I put a set of C-clamps on the wheels and roll it over. Nose down on the floor or it rolls on the tubes without touching the body to the back side. The tubes rest on the floor but the body doesn't hit the tubes. I can tilt it to the nose and back myself but need a second set of hands to tilt backwards .
Old 10-19-2015, 02:22 PM   #129
Metaldoc
Metaldoc's Avatar
Re: 67 long box
bottom sprayed and almost ready for paint. One step closer
Old 10-20-2015, 12:01 AM   #130
Metaldoc
Metaldoc's Avatar
Re: 67 long box
crack repair and restoration
Old 10-21-2015, 10:47 PM   #131
Metaldoc
Metaldoc's Avatar
Re: 67 long box
ready for paint tomorrow
Old 10-21-2015, 10:57 PM   #132
Sicksty8
Sicksty8's Avatar
Re: 67 long box
Looking pretty good!
Sicksty8 is offline   Reply With Quote
Old 10-22-2015, 03:42 PM   #133
Metaldoc
Metaldoc's Avatar
Re: 67 long box
cab interior painted and fire wall. It's ready to sit on the frame, so it's time to bring in the frame. I reached a milestone today and is a good day. It's funny I was a body man, a sheet metal worker, a metal fabricator, mechanic, media blaster, and now a painter. I still have to be a mechanic, wiring specialist, an assembler and body fitment specialist, glass installer and paint buffer. It's a good thing I don't have a sewing machine or I would do that to.
Any progress is progress.
Old 10-25-2015, 03:05 PM   #134
Metaldoc
Metaldoc's Avatar
Re: 67 long box
steering column disassembled and painted, wheel turned out great. Filled the shifter opening in the column and cut off the shift arms on the bottom so it looks like a factory floor shift. door hinges got a coat of blue as well.
Old 10-25-2015, 04:15 PM   #135
Xeen
Xeen's Avatar
Re: 67 long box
That is a really pretty metallic blue.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-25-2015, 04:27 PM   #136
Advanced Design
Re: 67 long box
Looking really good! What did you use to repair the cracks in the steering wheel?
Old 10-25-2015, 04:44 PM   #137
Metaldoc
Metaldoc's Avatar
Re: 67 long box
it is that is factory color and its ppg Omni line one stage. I love the metallic but hard to spray even
Old 10-25-2015, 04:48 PM   #138
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks I used a dremel and ground it out, then used two part epoxy puddy the polyester puddy to finish. Not an easy job blending the shaped wheel.
Old 10-25-2015, 09:45 PM   #139
deejaaa1
Re: 67 long box
amazing work. love it.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 10-25-2015, 10:14 PM   #140
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks the project has been a lot of work and now it's starting to show.
Derek
Old 10-25-2015, 10:18 PM   #141
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I sure am grateful for the digital camera, it makes it easy to remember reassembly when I take pics before disassembled.
Old 10-26-2015, 12:22 AM   #142
88Stanger
88Stanger's Avatar
Re: 67 long box
great build! awesome idea on the seam sealer and thinner.
88Stanger is offline   Reply With Quote
Old 10-26-2015, 09:39 AM   #143
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks, it spread the seam sealer out and made it easy to make a nice flowing edge. I can't take credit for the idea, as I saw it online. but I did pass it on.
Derek
Old 10-26-2015, 08:05 PM   #144
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Steering column done and put away. got the frame in, prepped it for satin clear for UV and got it sprayed.
Old 10-27-2015, 10:37 AM   #145
Xeen
Xeen's Avatar
Re: 67 long box
Man you are moving at a fast pace this thing is going to be done before we know what happened.
Old 10-27-2015, 11:58 AM   #146
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks I plan on diving it in May so the push is on
Old 10-27-2015, 09:23 PM   #147
Advanced Design
Re: 67 long box
Yeah the frame looks really good. How many hours a week are you putting into the build?
Old 10-27-2015, 09:33 PM   #148
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks I try to get at least a couple hours a day, some days more some days none. My wife said she'll see me after the build. I get pretty involved once I start working and I plan ahead so the next day is productive. I don't drink beer which I heard slows build progress so this helps
Old 10-29-2015, 03:14 PM   #149
Metaldoc
Metaldoc's Avatar
Re: 67 long box
brake and fuel lines bent and installed.
Old 10-29-2015, 11:25 PM   #150
Sicksty8
Sicksty8's Avatar
Re: 67 long box
Your progress is quite astonishing. Looks pretty damn good
