Old 07-19-2016, 01:46 PM   #126
DPowers
DPowers's Avatar
Re: New member with a 1960
Great progress= going to be killer
DPowers is online now   Reply With Quote
Old 07-19-2016, 02:42 PM   #127
The1960APE
The1960APE's Avatar
Thank you sir, I greatly appreciate it! Its nice to get the opinions and feedback of the group!
The1960APE is offline   Reply With Quote
Old 07-20-2016, 10:53 AM   #128
The1960APE
The1960APE's Avatar
I am going to have to modify the wood in the bed for the afterthought of wheel tubs, I am not sure in I should put the when tub flange on top of the wood or sink it and flush the wood up to the wheel tub, it would be cool if there were a trim piece made to hide the gap.
Any ideas or suggestions?
Old 07-20-2016, 01:10 PM   #129
The1960APE
The1960APE's Avatar
Originally Posted by Captainfab View Post
The closest fitting factory engine mount brackets for the '60-'62 frames are the '67-'72 small block engine mount brackets. Although some say they had to add a .250" spacer on top of the frame. Then you will need the '63-'72 engine mounts and an adapter plate for the LSx engine. Other than those, I do not know of any off the shelf engine mount solutions. Depending on just what you are wanting, the engine mounts might just have to be custom fabricated.
This is one of the reasons I don't care for the '60-'62 frames.
We ended up modifying the mounts sent by CPP, I didn't like how their mount kit had the engine sitting, it was way to high for my taste! So we did use them just made some adjustments and lowered the engine down a bit!
Old 07-20-2016, 02:30 PM   #130
66ChevyMax
66ChevyMax's Avatar
That engine is sweet!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 07-20-2016, 03:55 PM   #131
DPowers
DPowers's Avatar
Sink and flush IMO
Old 07-20-2016, 04:33 PM   #132
The1960APE
The1960APE's Avatar
Thanks guys!!!! hopefully we may make a little more progress soon!
Old 07-28-2016, 03:48 PM   #133
The1960APE
The1960APE's Avatar
A lot of grinding and welding going on! Hopefully this junk will crank one day, the A/C, power windows and wiring are next!
Old 07-29-2016, 04:34 PM   #134
The1960APE
The1960APE's Avatar
All this dang work, and all the hard work from the guys at MDS Motorsports......this photo just made it all worth it!
Old 08-02-2016, 01:28 PM   #135
The1960APE
The1960APE's Avatar
The junk keeps on progressing..... Tranny cooler is installed, AC lines run, supercharger reservoir installed....
Wheel tubs, wiring, and more plumbing to come! I have the AC/Heat vents figured out! This should be interesting !!!!
Old 08-02-2016, 01:36 PM   #136
DPowers
DPowers's Avatar
WoW that looks great. Really like the gas cap delete.
Old 08-02-2016, 01:43 PM   #137
The1960APE
The1960APE's Avatar
Thanks,
Ironically someone handed me your business card yesterday!
Old 08-02-2016, 03:55 PM   #138
DPowers
DPowers's Avatar
Thanks,
Aint that something.
Plan on coming over to see you the first of September. Expect it to be done by then
Old 08-02-2016, 05:27 PM   #139
66ChevyMax
66ChevyMax's Avatar
Moving right along, looks great!
Craig
Old 08-03-2016, 09:27 AM   #140
The1960APE
The1960APE's Avatar
Thanks for the kind words!
Below is the Supercharger coolant tank, it will be hidden in the inner fender with only a billet cap showing from the top side of the fender!
Old 08-08-2016, 04:06 PM   #141
The1960APE
The1960APE's Avatar
Has anyone run a sway bar on a 1961 ?
Old 08-08-2016, 04:26 PM   #142
forestb
forestb's Avatar
Not on a 61 but on a 62. There are a couple of threads on the subject. I used one from cpp that was meant for a 63-66. It was the type where the ends of the bard have a hole with a bolt that goes through and the bolts have bushings around them. I had to drill all my own holes but it worked fine. I am assuming you meant a front sway bar.
forestb is offline   Reply With Quote
Old 08-08-2016, 04:41 PM   #143
The1960APE
The1960APE's Avatar
correct!....thanks so much!
Old 08-09-2016, 03:51 PM   #144
The1960APE
The1960APE's Avatar
Another bang the head against the wall moment...... It must be old age catching up with me.
so I have combed over the forum, looking for front/rear sway bar ideas. There are some very helpful threads, but I am looking for something a little more performance geared, after all the hard work I really don't want to drop the torsion setup, I hear people say the torsion suspension will not perform but I cannot see why not, its just that the parts aren't available. I'd like to utilize some nice performance sway bars that will help when attempting to carve some corners in the old junk!
Old 08-09-2016, 04:53 PM   #145
Joe Pass
Joe Pass's Avatar
Good speaking with you today... I like your build....
Joe
Joe Pass is offline   Reply With Quote
Old 08-10-2016, 07:33 AM   #146
The1960APE
The1960APE's Avatar
Joe
Thanks Joe,
Yours is phenomenal! After speaking to you I believe I know which direction to go! Thanks for your help and time!
Old 08-10-2016, 10:00 AM   #147
The1960APE
The1960APE's Avatar
Originally Posted by Northwest Outlaw View Post
you should get Detroit Steel Wheels...because reasons.
Keep up the work and post pics when you can of the rear end, we all like rear end pics
I ended up taking your advice on the wheels, I ordered the Detroit Steel wheels, 20x12 & 20x8, I should see them in about 2 weeks!
Thanks!
Old 08-12-2016, 09:59 AM   #148
The1960APE
The1960APE's Avatar
I went ahead and ordered the Hotchkis front sway bar for 63-72, I'm assuming we can make that work pretty easily, we are going to build the rear bar! The LED lights arrived and I believe they will work great, I think I have about 600.00 in the full LED swap including signals, tail lights, brackets and head lights and all of it was United Pacific products!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
Old 08-12-2016, 11:54 AM   #149
62stepside longbox
62stepside longbox's Avatar
What power steering kit is that? Looks like it bolts right up to the 60-62 frame
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 08-12-2016, 12:10 PM   #150
The1960APE
The1960APE's Avatar
Its the CPP conversion kit, and it was an awful fit, we actually modified the frame to make it work!
