05-21-2016, 12:15 AM | #126 |
Re: 1987 R20 Suburban LQ4 4L80E swap
Looks great. Good Job.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
05-21-2016, 12:46 AM | #127 |
Nice work that looks awesome. What are those codes?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
05-21-2016, 12:17 PM | #128 |
Keep getting p0171 & p0174, too lean on banks 1 & 2.
Thanks for the kind words!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
07-14-2016, 10:39 AM | #129 |
Nice work. What are you getting for fuel mileage now? Did you move your filter and get the codes figured out?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
07-14-2016, 10:53 AM | #130 | |
Here is a recent pic of the motor after everything was done.
07-14-2016, 10:57 AM | #131 |
Very nice. I want to build a 6L myself even though I don't have anything to put it into besides my K10 right now.
How is the power?
10-13-2016, 12:14 PM | #132 |
Just read through your thread. Very nice setup! I would live to have an LS swapped 3/4t burb. Lice the two tone combo also!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
10-13-2016, 12:35 PM | #133 | |
Thank you for the kind words! it was a lot of work and a lot of money, but in the end it was definitely worth it.
11-07-2016, 06:40 AM | #134 |
Wow really nice burb.who tuned the ecm? I have the p0171 ans p0174 and cant get rid of them either. Bolts are tight. I need a serious retune i only have a stock tune from psi conversion. Who did your tuning? You have hgen 3 you can send it quick anywhere to want without having to take out tcm like ua hen 4 guys. Sounds good i have same mufflers on a 6.2. Did you end up shaving tabs off tranny for manifolds? I had to switch to ls3 manifolds. nice build! Do you tow anything?
11-07-2016, 12:27 PM | #135 |
I found an exhaust leak at the manifolds where they meet the exhaust. Got that taken care of and codes haven't come back. I would recommend running some seafoam through your motor, and see if you see any smoke/leaks.
My ECU came already tuned with my harness/motor from LSX4U.com. Good people to work with. I did have to cut the tabs off the transmission with a sawsall for the exhaust to clear. I don't tow anything but if I wanted to, I feel I could with no problem. Good luck on your build, I hope you get those codes figured out.
07-28-2017, 01:47 PM | #136 |
Nodnarb, Awesome build! I've read this thread through a couple of times, had a couple of questions
How much of your stock wiring harness did you retain/reuse with the new harness? Removing the TBI harness—that includes the ECM, right? Did you go off of a GM shop manual or did LSX4U give you the instructions on what to delete/what to keep on your '87?
_____________________________________________ 1966 c10, short fleet, 402ci 700r4 1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon) 1980 shovelhead, hardtail, open primary 1998 FXDWG |
07-28-2017, 03:51 PM | #137 | |
when I did my swap I un-plugged the factory TBI harness from the motor. then found where the wires went into the firewall on the driver's side. I was very nervous but I cut the wires where they go into the firewall and left the TBI harness plugged into the stock connector with the cut wires coming off the connector. I did leave enough wire at the stock connector in case I had to re connect a wire I removed. I took the TBI harness home and took an entire Sunday afternoon and traced every wire on the factory harness and probed them with my multi-meter to make sure I knew what each wire did. I realized the majority of the wires were 12v switched on power for the various sensors on the motor, and of course some wires going to gauges, etc. I did remove the TBI ECU. After I removed the stock engine harness I had moment of truth, I reconnected the battery and wanted to make sure I didn't remove anything that needed to remain. I checked and all of my lights, wipers, turn signals, horn, blower motor, radio, windows etc all still worked. Thank goodness everything still worked, and I had not removed anything that I didn't need to. The LSX4U harness was great to work with, just follow the instructions they send you, the hardest part was wiring the torque converter lockup relay. I also made my own harness for the fuel pump/gauge sending unit and ran it back to the tank, and other end to the LSX harness and my new fuel gauge. I figured I might as well have new wiring for everything at that point lol. Good luck with your swap, let me know if you need anything else.
07-28-2017, 03:58 PM | #138 |
While I'm posting also wanted to show off my intake I painted.
07-28-2017, 04:06 PM | #139 |
Truck looks great. Have you been driving the wheels off of it? How's the performance and economy been?
07-28-2017, 04:16 PM | #140 | |
I love this truck!
07-31-2017, 08:58 AM | #141 |
I'm just glad to be here!
This suburban would make a great tow pig for my son's '84 SWB. It has the same color combo!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-31-2017, 03:53 PM | #142 |
How did I miss this one? Great stuff!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
07-31-2017, 04:13 PM | #143 |
I could be totally wrong, but could you have used the "Upper Radiator Mounting Panel" below to mount your radiator? It steps down a couple inches or so vs the SB mounting panel???? My radiator did the same thing and I put a 1"x 1" x 3" square tubing on the bottom of the radiator core support and put the mounting cushion on the tubing.
Just thinking out-loud. Mike
