Old 01-16-2020, 05:28 PM   #126
Mains52
Re: "52 3600/3100"
Originally Posted by Brads49 View Post
nice building you have there! That will be really nice having that much room to move around working on the truck!
Thank You its really a dream building for me .
Mains52 is offline   Reply With Quote
Old 01-17-2020, 12:03 PM   #127
Desert1957
Desert1957's Avatar
Re: "52 3600/3100"
Originally Posted by Mains52 View Post
Yup the plan is to pour the entire floor. I could pour half this year and half next year but if I dont do it all at once the wife will be hesitant when it comes to spend the money again ha. Since I have the truck and my moto stuff the plan is to 50/50 the shop into individual hotrod/moto & misc. spots might epoxy the floor after its poured as well so it will be an easy clean up.
OMG , Nice building.can't wait to see how much all that concrete will cost,getting ready to build another pole barn myself.
Desert
Desert1957 is offline   Reply With Quote
Old 01-17-2020, 12:10 PM   #128
Mains52
Re: "52 3600/3100"
Thank You, My first quote was 10k . But it needs done.
Old 01-17-2020, 06:29 PM   #129
joedoh
joedoh's Avatar
Re: "52 3600/3100"
woooop nice space!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 04-30-2020, 04:29 PM   #130
Mains52
Re: "52 3600/3100"
Finally got some cement in my building and just purchased a new welder so I can get my truck project back on track. The building isn't set up at all yet but it will be over time . We seem to have a lot of home time right now so I am hoping to go hard on the truck this summer.
Old 04-30-2020, 05:23 PM   #131
8man
Re: "52 3600/3100"
Lots of room now! Nice building.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-01-2020, 08:01 AM   #132
Mains52
Re: "52 3600/3100"
The concrete ended up coming in just under 6k. Not bad at all.
Old 05-05-2020, 08:42 AM   #133
Mains52
Re: "52 3600/3100"
Was able to get some time in the shop this last weekend and I got my shocks installed up front then started prepping for my 4 link install. Found some scabs on the frame under the old leaf spring mounts, so I had to make a couple of patches. Of course I ran out of shielding gas so I had to switch over to flux core. I figure just for little patches and tacking in my 4 link the FC .030 will be fine. The new VULCAN welder works surprisingly very well. As far as the 4 link goes I am measuring everything 1000 times because I am so new to building a chassis it sort of freaks me out ha . Also any of you that have went this route or something similar did you use the stock 116in wheelbase?
Old 05-05-2020, 05:27 PM   #134
Mains52
Re: "52 3600/3100"
Well ended up making some more boxing plates and was able to fully weld in both sides before the wife shut it down to help rearrange the bed room lol. Now with a 4th check of axle center and rearend center. I can start measuring and tacking in my 4 link. My ebay coil overs for the rear came today.
Old 05-05-2020, 05:38 PM   #135
joedoh
joedoh's Avatar
Re: "52 3600/3100"
haha always something that comes up, I know it well.
keep plugging!
Old 05-11-2020, 11:32 AM   #136
Mains52
Re: "52 3600/3100"
After a ton of measuring and remeasuring I got my 4 link tacked in this past weekend. Next time I get some time in the shop ill be working on my upper coilover mount. My new rearend cover came in the mail so ill be getting that put on as well.
Old 05-11-2020, 11:34 AM   #137
Mains52
Re: "52 3600/3100"
Ugh I hate posting with my phone sorry for the sideways photo.
Old 05-11-2020, 12:13 PM   #138
dsraven
Re: "52 3600/3100"
sometimes something like these calculators can be handy, if nothing else it makes you think about how the suspension reacts and plants the tires if done right.
https://www.crawlpedia.com/4_link_suspension.htm
http://www.jascoautomotive.com/4linkrearsuspension.htm
Old 05-11-2020, 03:35 PM   #139
Mains52
Re: "52 3600/3100"
Thanks those are good links
Old 05-12-2020, 07:30 AM   #140
Mains52
Re: "52 3600/3100"
Isn't crazy that if you sit and wait for 3 hrs it seems like forever but if you go out to the shop and start working on your truck 3hrs flies by and its midnight all of the sudden. Happens every time. Anyways I was able to do a 15 degree shock mock up and tack in an upper shock mount last night. Had to do some more boxing which never hurts anything but cutting out boxing plates with a cutoff wheel is getting old. I need some hardware for my shock mounts then I can get everything finish welded and painted.
Old 05-12-2020, 08:08 PM   #141
joedoh
joedoh's Avatar
Re: "52 3600/3100"
nice work!
Old 05-12-2020, 10:52 PM   #142
Mains52
Re: "52 3600/3100"
Thanks Joedoh trying to learn how to fab as I go. Its been a blast figuring it out.
Old 05-13-2020, 11:10 AM   #143
gigamanx
Re: "52 3600/3100"
Very cool. Currently working on a triangulated 4 link myself but I wasn't sure I could weld to the pumpkin on my Ford 8.8. Decided to build a truss over the pumpkin and weld to that kind of like the offroad guys do with their Jeeps
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 05-13-2020, 01:25 PM   #144
Mains52
Re: "52 3600/3100"
Dang that is a really good idea if I cant get the welds i like when it comes to finish welding the tabs I may just have to build one like it. I picked up some hardware and pipe yesterday to finish my upper shock mount so I am hoping to be able to finish weld everything tonight and put the thing on the ground officially on its own without jack stands. Got new CV joints to install on the utv so that may come first.
Old 05-14-2020, 04:30 PM   #145
Mains52
Re: "52 3600/3100"
ITS OFFICIALLY A ROLLING CHASSIS!! I know most of you guys have done it 1000 times but figuring out the chassis part of this build by myself was a big accomplishment for me . In the past I just waited until my pops had time to help but I didn't want to bug him this time. Now I still need to finish weld everything and make it pretty but my goal for this week was to have a rolling chassis. Now to get engine and trans mounts in and start fitting body panels before I put the cab on the cab cart and finish the chassis.
Old 05-14-2020, 04:31 PM   #146
8man
Re: "52 3600/3100"
Feels good doesn't it! Congrats.
8man-aka Robert
Old 05-14-2020, 05:26 PM   #147
Mains52
Re: "52 3600/3100"
Thanks It does.My wife looked at me like "So what did you do to it again". She doesn't realize that what I think the hardest part is, is done. Body work stuff isn't a huge deal to me so if I have to drive a multi colored/primered truck for a bit until I figure out a color, I will. I have access to a running low mileage 350 sbc that will bolt right up to my older 4l80e and drive down the road if the LS has a spun bearing or needs machine work so It could be sooner than later that its running. My semi realistic goal is next summer. ha we will see .
Old 05-14-2020, 07:31 PM   #148
oldman3
oldman3's Avatar
Re: "52 3600/3100"
Big step forward congrats...Jim
oldman3 is offline   Reply With Quote
Old 05-14-2020, 10:55 PM   #149
Mains52
Re: "52 3600/3100"
Thank you Jim ! In typical dad fashion my dad took it upon himself to come double check all my work ha ha its all good so onto finish welding.
Old 05-14-2020, 10:59 PM   #150
joedoh
joedoh's Avatar
Re: "52 3600/3100"
woop woop! congrats on the milestone, all downhill now (and it rolls so downhill is even easier)
