11-18-2017, 02:46 PM | #126 |
Formerly- 1972SuperCheyenne
Re: 73 gmc short Sierra Grande C1500
Your truck is looking great man! Keep at it!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-19-2017, 07:17 AM | #127 |
Well, I had to get the rear of the truck lowered a little before I could mount the vintage air box under the dash, you need to level it up so it drains correctly. I pulled the box back off and installed 2" shackles. Now the truck sits just how I like them, just a little higher in the rear, but not jacked up looking. Working mostly in the shop at nights, I had to take the time to fab up a box lifting jig for the engine hoist, my buddies will thank me. It turned out good, and seemed to work good! I have had this on the to-do list for awhile. I had to notch the cross member to clear the shackles while I had it up in the air. Now to finish up installing the vintage air....
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
11-19-2017, 10:47 AM | #128 |
That stance is perfect!
11-19-2017, 11:02 AM | #129 |
Looking really good! What size square tubing did you use for the attachment?
85 Silverado - 350/700r4 |
11-19-2017, 11:22 AM | #130 |
Looking good!!!! You didn't lift that box off that freshly painted truck by yourself did you?? Scary!! Great job Jayson.
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
11-19-2017, 12:10 PM | #131 |
It is 1 1/4", and the adjustable ends are 1". I used what I had leftover from building a welding cart, its pretty light tube, but it seemed to work fine.
11-19-2017, 12:14 PM | #132 |
I did Mike. With this lift jig thing, it is real steady, and easy to control. I will round up some more tubing and make you one, makes it a safe 1 man operation!
11-19-2017, 01:16 PM | #133 |
Thank you sir! Looks like that will be my next project.
11-19-2017, 04:05 PM | #134 |
Excellent, that would be awesome! Mike
11-20-2017, 04:30 AM | #135 |
My least favorite thing to do is sanding, and buffing! I have been putting off doing the hood and fenders, I only had medium activator, and reducer when I painted them, and needed fast. In an effort to avoid solvent pop issues, I was nervous about laying the clear down slick, and ended up with some orange peel. I made sure to lay an extra coat on since I knew that a sanding session was in my future. A couple buddies stopped by last night, and one of them asked why the back of the truck looks so nice, and the front looks like lizard skin? I guess that was the motivation I needed to get it done.😀
11-20-2017, 03:30 PM | #136 |
looks great.
what brand hood did you go with? I'm still torn as to whether do a cowl hood or stock hood. |
11-24-2017, 08:38 AM | #137 |
I'm not sure what brand it is, there is a guy kinda local that sells truck parts. He seems to have alot of the same stuff that you can get from any other truck catalog, I don't think there are very many outfits that actually manufacturer parts for these old trucks. Same stuff, different box most of the time.
11-24-2017, 12:43 PM | #138 |
All buffed out!
12-01-2017, 04:45 AM | #139 |
Man, look at that paint!
12-01-2017, 12:56 PM | #140 |
I'm just glad to be here!
Very nice!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-02-2017, 08:20 AM | #141 |
I got the light harnesses cleaned up, cleaned up and painted the grille, and final installed the front end stuff. I also got the vintage air hoses routed! Had to have a pipe made for the exhaust today, the kit I bought was not set up for a double hump transmission cross member. We are getting pretty close on this one.
12-02-2017, 08:36 AM | #142 |
One more for the heck of it.
12-02-2017, 10:30 AM | #143 |
Exhaust all tacked up.
12-02-2017, 11:17 AM | #144 |
Looks most excellent Jason. I just love those 73 front ends. Mike
12-02-2017, 11:46 AM | #145 |
Good looking square. Dig that paint color
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
12-02-2017, 11:14 PM | #146 |
Every truck you do is great. This one is phenomenal, you should hold on to this one.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
12-04-2017, 02:01 PM | #147 |
Shooooo purdy! Nice job!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-08-2017, 09:14 AM | #148 |
Exhaust is all welded up, transmission lines run, brake booster balsted, and painted, new master cylinder painted, installed and new lines made. I didn't have the greatest luck bending the curly-q in the lines, but they will work! I also got the taillight harness run, and the taillights installed, and I got the engine harness today, so I got that installed. I'm hoping to have it moving under it's own power in the next week.
12-19-2017, 12:37 AM | #149 |
Just been plugging away at getting the wiring hooked up, and nice looking. I bleed the brakes, and I wish I would have spent the half hour, and $25 to build one of these pressure bleeder 10 years ago!!! It made it real obvious when I pumped it up that I didn't tighten up the rear hard line to the rubber line.
12-19-2017, 08:58 AM | #150 |
Truck looks great. Did you buy a aftermarket engine harness? I need one for my bbc.
