Old 09-27-2018, 03:26 PM   #126
beaterku
beaterku's Avatar
Re: 1972 SWB Build
The first part of the puzzle is back. I bought this 80e from a fellow board member here in KC. He bought it from a local big rig tire service truck. Since I didn't know the complete history of it, I opted to have it gone through. Turns out it was in great condition. Did a full rebuild and added a TransGo HD-2 kit. My builder said it should be good for 800-900hp now. I wanted to build it fairly well while it was out in the event I go with a Procharger or turbos in the future. Easy to do when it is torn apart.
Motor should be done hopefully next week. Same goes with the heads.
beaterku is offline   Reply With Quote
Old 10-03-2018, 04:10 PM   #127
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I've been slowly gathering parts. While talking with Texas Speed, they mentioned that my stock 24lb injectors will not be enough for my build. I did some digging and found a set of injectors from a 2012 6.0 flex fuel. Here is a picture of the stock 25317628 24lb injector on the left, and a flex fuel 12613412 50lb injector on the right. The mounting height is the same. The flex fuel doesn't have the boot on the tip, which as far as I can tell effects nothing. The flex also uses the EV6 connector. Since I am going to buy a harness, I'll just spec it with the EV6 connectors. These will be more than enough for what I am doing and probably will support a small blower in the future.
Motor is almost done
Trans is rebuilt
Heads are almost done
Motor mount adapter plates are on the way
Still need to order some big items. I'm trying to space these out a little to fly them under my wife's radar.
-exhaust manifold or headers. Debating between the hooker cast manifold or tying out a set of the speed engineering shorty headers. The reviews seem favorable on them.
-Boyds tank
-Radiator
-Wiring harness
Old 10-03-2018, 05:31 PM   #128
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1972 SWB Build
Glad to see you figured out the direction for your motor and trans. Interested in what the rebuild cost for your 80e. I am crossing my fingers that mine is as good as they said it was and just going with it. If it has problems after I am completed we will pull it then. Next time in the KC area I need to hit you up.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-03-2018, 05:46 PM   #129
beaterku
beaterku's Avatar
Re: 1972 SWB Build
It's getting there. Since I didn't have any history on mine, I opted to have to have it gone through. Turns out it was actually in pretty good shape. Now it will last the life of my truck.
Sure thing, I think there are a bunch of us up here. Maybe we can get everyone together.
Old 10-08-2018, 04:00 PM   #130
beaterku
beaterku's Avatar
Re: 1972 SWB Build
A little update. I haven't worked on the truck. We had friends in town for my class reunion this past weekend. Trying to find free time has been hard. I did get the heads and a bunch of parts back from Texas Speed.
Heads are the stock 317 heads. I did their stage 1 kit. For my application, the stage 2.5 was not needed. It only flows 6cfm more peak and I don't need the stainless valves. These have PAC dual valve springs, titanium retainers and a full cnc port job. I also have them mill the head .030 to bump the compression closer to 10:1 since I am still using the stock dished LQ4 pistons. I went with their 224r cam.
They came back looking amazing!
The Circle D 2800 stall converter also came in.
Just waiting on the bottom end to come back from the machine shop. I am hoping this week. We shall see.
Old 10-08-2018, 04:22 PM   #131
1971Stepside
Almost Satisfied
Re: 1972 SWB Build
Wow! Those look great. I too am finding it hard to get much done on the truck lately.
Old 10-09-2018, 09:36 AM   #132
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thanks, I think they really knocked it out of the park for the money. Local shop wanted almost half of what texas speed charged to do a valve job and reassembly only.
It seems like there is something going on every day these days. Couple that with the obscene amount of rain we have gotten this week. We are 10" since Saturday with 2 more coming today.
Old 10-16-2018, 01:59 PM   #133
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Not much progress lately. I spent a few hours cleaning some of the parts before assembly. The front and rear covers, valve covers and valley cover were disgusting. Gave the trans the wire brush treatment. Motor is supposed to be done at the end of this week. I have started gathering more and more parts. Trying to keep most of it under the wife's radar.
Hopefully have some more progress soon.
Old 10-23-2018, 05:35 PM   #134
beaterku
beaterku's Avatar
Re: 1972 SWB Build
No real progress. Last weekend was a bust and I've had my IT had on at work the last 2 weeks. I have been amassing more parts. I've got a truckload of new Delco parts for the motor, alternator, water pump, gaskets etc... ) that showed up this morning.
Last night a about 5:30 I got a call that my shortblock was done. So I scooted up there at lunch today and picked it up. She's so shinny and clean now. No surprises in side. Just did a quick hone job. Stock dished pistons, stock rods and crank. New clevite bearings throughout. She's all wrapped up and snug as a bug in a rug.
I've got to remove the inner wheel wells to have them powdercoated as well as the bling bling stainless battery tray I bought. I didn't realize it was going to come so shinny. Too much for me, so it's going to be satin black like the fenders. I still need to remove the fuel lines, but that requires emptying the fuel tank first. So I may tackle that one night this week.
Sorry, just rambling...
Old 10-25-2018, 07:54 AM   #135
mcbassin
Still Learning
mcbassin's Avatar
Re: 1972 SWB Build
Looks like you have everything going the right direction on this build.
mcbassin is offline   Reply With Quote
Old 10-25-2018, 09:48 AM   #136
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thanks! I've got 8 weeks to get this wrapped us so it's crunch time!
Old 10-25-2018, 10:28 AM   #137
redneckgames
Re: 1972 SWB Build
Good looking truck, interesting build.
redneckgames is offline   Reply With Quote
Old 10-25-2018, 10:59 AM   #138
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thanks!
Old 10-29-2018, 12:49 PM   #139
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I feel like I am not making progress but things are getting done. I am finally to the point where the motor can go in. I am going to start assembling the motor this week. Finally!
Old 11-05-2018, 11:28 AM   #140
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Spent a few hours on the truck this morning. I buttoned up the long block. Everything went to plan with no hiccups. I ran out of time and I wasn't feeling to great so I called it a day. Hopefully smooth sailing from here.
Here is the latest YouTube update:
Old 11-05-2018, 12:42 PM   #141
Stickman
Stickman's Avatar
Re: 1972 SWB Build
Very Nice
Stickman is offline   Reply With Quote
Old 11-13-2018, 03:51 PM   #142
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Originally Posted by Stickman View Post
Very Nice
Thanks!
Old 11-13-2018, 03:53 PM   #143
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Made a little more progress this weekend. Still running low on energy. Damn sickness. I was able to get the oil pump shimmed and installed as well as the front cover. I spent most of my time in the shop cleaning. Can't have a messy shop.
Old 11-20-2018, 04:49 PM   #144
beaterku
beaterku's Avatar
Re: 1972 SWB Build
The motor is assembled and ready to put in the truck. Finally! I decided at the 11th hour to clean up the trans a little and dust a coat of cast aluminum paint on. A buddy showed me a pretty trick way to make it look like it is not painted. I think it turned our great. It looks like really clean cast aluminum now. I had the wait for the paint to dry, otherwise it would have been all together as a unit. The plan is to remove the grille and core support tonight so I can slide the engine/trans in as a unit. Much easier to do by myself.
I am going to order the radiator, boyd tank, dakota guages and a few other odds and ends this afternoon. Black Friday sales!
Old 11-20-2018, 06:14 PM   #145
Low Elco
Re: 1972 SWB Build
What's the trick? I have to paint one soon.
Low Elco is offline   Reply With Quote
Old 11-20-2018, 06:37 PM   #146
1971Stepside
Almost Satisfied
Re: 1972 SWB Build
Please order two of each....HA!
Old 11-21-2018, 10:58 PM   #147
beaterku
beaterku's Avatar
Re: 1972 SWB Build
So what he does is blast or clean the part throughly. He then dusts the part with vht cast coat flat aluminum paint and literally wipes it off with a rag. This seals the pores on the cast and keeps the cast color. It was pretty trick. He does it to all of his cast parts. Turned out really well on the trans and alternator bracket. .
Haha. One of each was hard enough on my wallet. I placed the order this afternoon. That’s the last of the big parts. A lot of nickel and dime parts left.
Old 11-22-2018, 11:20 AM   #148
1971Stepside
Almost Satisfied
Re: 1972 SWB Build
I saw Boyd’s was having a sale with free shipping. I went ahead and ordered my tank. What radiator did you go with? Fans?
Old 11-22-2018, 07:52 PM   #149
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I got in on the sale as well. I went with an Entropy with fans. I bought it all from Travis at Pro Performance. They make it so easy. It was a package deal.
Old 11-26-2018, 11:06 AM   #150
beaterku
beaterku's Avatar
Re: 1972 SWB Build
The motor is in. We had a blizzard forcasted to come in on Sunday so we hoofed it and got the motor in on Saturday. Everything went smooth. The only problem was my mistake, I put the motor mounts in the wrong place on the adapter plates. Easy fix.
