Old 11-17-2017, 09:51 PM   #126
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Elwood the 77_remix
Originally Posted by BB72CHEVKT View Post
I like the new wheels so much I think I need a pair for my new to me 83. Any idea when they can be purchased and price point.
You will need to contact your local Wheel Pro dealer. They can give you info on pricing and availability.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-18-2017, 12:12 PM   #127
N2TRUX
Happy to be here
N2TRUX's Avatar
Friday night shop session was focused on the rear axle. I wanted to pull it to clean it up a bit. The stock shock mounts were still attached, and the pinion seal is seeping.
I had preciously removed most of the 4 link and set it aside. I finished removing some components and disconnected the E brake cable and brake line.
I pulled the inspection cover and drained the gear oil. While that was off, I tested the fit of the Moser Engineering differential cover. I was concerned that the panhard bar mount might create a conflict, and it does. I'll address that issue later.
Articles-
"Refining Sierra"
Old 11-18-2017, 12:25 PM   #128
N2TRUX
Happy to be here
N2TRUX's Avatar
With the 12 bolt on the ground i was able to slide it out from under the truck. I recall removing the bottom shock mounts from Scarlett while laying on my back. I decided to do it standing up on Elwood.
After a few minutes with a cut off wheel, followed by a flapper disc the axle was cleaner looking. I plan to make new brake lines and replace the rubber with braided stainless. I am working with Wilwood to determine what brakes I will run. That will decide how the lines are laid out.
Time constraints wont allow me to change gears and add a locker. My 3.08 one wheel peel differential will have to do for now.
Articles-
"Refining Sierra"
Old 11-19-2017, 11:55 PM   #129
rustytruck50
rustytruck50's Avatar
Hooked & reeled in Ken! Elwood is spot on in so many ways
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-20-2017, 08:38 AM   #130
N2TRUX
Happy to be here
N2TRUX's Avatar
Come on in and enjoy the show.
Articles-
"Refining Sierra"
Old 11-20-2017, 11:28 AM   #131
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by smpoulin01 View Post
I have 2 - 12577 on mine. Love them.
I finally had a few minutes to compare the specs on the mufflers I was considering. I am restricted by my RideTech 4 link not allowing space to run a true dual system out the back. Consequently I need a free flowing muffler that wont be too loud in the cab.
I looked hard at the Borla XL series since I have them on Scarlett and know what they sound like. I compared them to the Magnaflow for size, appearance, and sound.
Its hard to compare sound when there are so many variables, but I listened to several sound clips and liked the Magnaflow stainless series best. The end result is I will be running a MagnaFlow 14336 which is a 2.5" SI/SO.
Up front I have 2.5" Corvette ramhorns flowing in to a mandrel bend Y pipe. I will use Deeds Engineering V bands to connect to a Vibrant Performance #64810 10" flex coupling going back to the Magnaflow muffler. That will be suspended by Deeds Engineering billet brackets and hangers.
From there I will have to rely on Alex my exhaust technician at New Star Muffler to work his magic and get the exhaust pip under the rise in the frame to the wheel well.
Articles-
"Refining Sierra"
Old 11-20-2017, 04:50 PM   #132
smpoulin01
smpoulin01's Avatar
I believe that will be a great choice!
85 Silverado - 350/700r4
smpoulin01 is offline   Reply With Quote
Old 11-21-2017, 12:56 AM   #133
Sik66
DeJaVu for me with my last weekend!....I fitted up my 4 link conversion
I also will have to modify my moser cover....thinking of just welding together.....or even welded bracket to actual diff housing instead...
Sik66 is offline   Reply With Quote
Old 11-21-2017, 03:08 AM   #134
gringoloco
A guy with a truck
gringoloco's Avatar
I like my stainless magnaflows, but with the small block, they can get a little glass-packy. Brrraaaap!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-21-2017, 10:33 AM   #135
N2TRUX
Happy to be here
N2TRUX's Avatar
I hope it has a good sound. I'm going to run as much tailpipe as possible to clean it up.
Articles-
"Refining Sierra"
Old 11-21-2017, 10:36 AM   #136
N2TRUX
Happy to be here
N2TRUX's Avatar
I wont be able to determine a solution until I get the axle back in place. I need to see how much needs to be removed from the bracket, or housing. I dont want to compromise the integrity of either part.
Articles-
"Refining Sierra"
Old 11-21-2017, 01:15 PM   #137
N2TRUX
Happy to be here
N2TRUX's Avatar
I received a batch of goodies from Deeds Engineering yesterday. I would normally say the pics dont do them justice. In this case Kevin has some fantastic photos on his website and the finished product looks just as nice. These definitely are multi level up in quality over standard exhaust components.
Articles-
"Refining Sierra"
Old 11-21-2017, 01:50 PM   #138
Bloodhound
Wow those are nice. Trying to picture how they bolt up.
Bloodhound is offline   Reply With Quote
Old 11-22-2017, 11:13 AM   #139
N2TRUX
Happy to be here
N2TRUX's Avatar
The V bands are a three piece component. There are two rings that slide over the exhaust pipe. The outer band clamps around both rings and clamps them together to create a seal.
Those flat tabs are weld to the exhaust system. The "dogbones" are captured between the tabs. They have a built in bushing to absorb some of the vibration. There are additional hangers that will be utilized as we get the system laid out.
Articles-
"Refining Sierra"
Old 11-22-2017, 02:03 PM   #140
Bloodhound
Very cool.
Old 11-22-2017, 11:26 PM   #141
N2TRUX
Happy to be here
N2TRUX's Avatar
A swing, and a miss. I got my exhaust parts from Summit today. I wanted to test fit everything to see how it fit. Yikes! I was not even close. In my defense, its not easy trying to lay on your back, hold parts in place, and measure what you need.
I ordered a 10" Flex fitting and its way too long. I wanted as much flex as possible but a 6" tube will have to suffice. I mistakenly pulled the Magnaflow part number for a offset/offset muffler. Instead I need a center/offset to work.
Fortunately Summit has an excellent return policy. Since the parts weren't installed, they emailed me a prepaid return label. As soon as they see that I shipped the parts they will process my new parts. Thanks Summit!
Articles-
"Refining Sierra"
Old 11-27-2017, 10:23 AM   #142
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by N2TRUX View Post
...Time constraints wont allow me to change gears and add a locker. My 3.08 one wheel peel differential will have to do for now.
Looks like there might be a change in plans. I located a 10 bolt with 3.42 gears locally. I'm supposed to pick it up later today.
I was sick over the Thanksgiving weekend so i didnt get any shop time. I manged to finish my work on Friday but that was about it. Saturday was bad and Sunday I slept all day.
I'm somewhat better today, so I'll be doing updates later.
Articles-
"Refining Sierra"
Old 11-27-2017, 06:35 PM   #143
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Everything looks fantastic as usual! Can’t wait to see that interior finished up!
--Josh
Old 11-27-2017, 09:03 PM   #144
N2TRUX
Happy to be here
N2TRUX's Avatar
It really sucked not being able to put in shop time this weekend. I'm trying to shake a respiratory infection and I find the best cure is sleep. Consequently I was rather depressed today after a much needed weekend past by.
Fortunately I received some pics today from Brent at Sculpt Garage He is almost finished with the seat for Elwood. I wanted to wait till I picked it up to post pics, but I cant. I'm really pleased with the results.
The insert material is OEM for earlier squares, and the red emulates the 1977 grain. Its a brighter red by Enduratex in the Oxen series. Its a bit brighter than what I wanted but so far everyone I show it to likes it better than my choice.
Lets see what the critics think?
Articles-
"Refining Sierra"
Old 11-27-2017, 09:31 PM   #145
STOCKISH
STOCKISH's Avatar
Spot on! Beautiful
--Josh
Old 11-27-2017, 10:05 PM   #146
smpoulin01
smpoulin01's Avatar
Looks really good!
Old 11-28-2017, 08:17 AM   #147
Coursey
Coursey's Avatar
Where did you source the OEM material?
Coursey is offline   Reply With Quote
Old 11-28-2017, 08:41 AM   #148
ultrahd4me
ultrahd4me's Avatar
That's next level stuff for sure. Ken, yourself and Elwood is what has inspired a lot of us younger guys to get into the squarebody trucks. This definitely raises that bar to another level. Killer work as usual sir.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 11-28-2017, 11:00 AM   #149
aggie91
I'm just glad to be here!
aggie91's Avatar
The new seat looks great! I really do like the red you used!
Can't wait to see Elwood in February.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-28-2017, 12:02 PM   #150
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by STOCKISH View Post
Spot on! Beautiful
Looks really good!
Originally Posted by aggie91 View Post
The new seat looks great! I really do like the red you used!Can't wait to see Elwood in February.
Thanks guys. I'm trying to stay true to the original truck with some pleasing updates. The OEM material came from SMS Auto fabrics They have the best selection and are very knowledgeable on their inventory. I was apprehensive about using 40 year old vinyl until I got the sample. It still had that "new car" smell to it.
Articles-
"Refining Sierra"
