Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-01-2020, 10:47 PM   #126
shearjs
shearjs's Avatar
Re: Project: '72 Family Hauler
Originally Posted by 04ls1gto View Post
I knew I had a pic somewhere
Looks like a major difference. It’s easy to see why your ride quality improved!
shearjs is offline   Reply With Quote
Old 05-06-2020, 11:56 AM   #127
shearjs
shearjs's Avatar
What began as a mostly simple fuel tank install turned into a cnotch install, which turned into a rear end cleanup, which turned into a full rear end rebuild and disc brake conversion. These are all things that I had planned on doing eventually, but I figure I might as well dive in while it’s all apart. I likely scraped off 10 lbs of gunk and dirt from the rear end. I’ve been doing a little research to determine exactly what gear combination and traction device would give me the ride I’m looking for. With a final gear ratio of .75 on the 4l60, a 29.3” tire height, and 3.73 ring and pinion, I should be around 2096 rpm at 70 mph. My old GMC was around 2350 rpm at 70 and that felt a little high for my preference. I’m currently trying to decide between the Eaton Posi and Eaton Detroit Truetrac and leaning toward the Truetrac. Does anyone have any prior experience that might persuade one over the other?
Old 05-06-2020, 01:30 PM   #128
polishspy
Originally Posted by shearjs View Post
What began as a mostly simple fuel tank install turned into a cnotch install, which turned into a rear end cleanup, which turned into a full rear end rebuild and disc brake conversion. These are all things that I had planned on doing eventually, but I figure I might as well dive in while it’s all apart. I likely scraped off 10 lbs of gunk and dirt from the rear end. I’ve been doing a little research to determine exactly what gear combination and traction device would give me the ride I’m looking for. With a final gear ratio of .75 on the 4l60, a 29.3” tire height, and 3.73 ring and pinion, I should be around 2096 rpm at 70 mph. My old GMC was around 2350 rpm at 70 and that felt a little high for my preference. I’m currently trying to decide between the Eaton Posi and Eaton Detroit Truetrac and learning to the Truetrac. Does anyone have any prior experience that might persuade one over the other?
If you are going to drive it regularly, a posi is the way to go. The true trac is more of a racing rear end.
polishspy is offline   Reply With Quote
Old 05-06-2020, 05:16 PM   #129
04ls1gto
I put a true Trac in mine with the 3:73 but I am running a 6l90 which has another overdrive. I highly recommend the trutrac as it drives like a open diff and is nice and quiet. Honestly made the drivability a lot better then the open diff.
04ls1gto is offline   Reply With Quote
Old 05-06-2020, 07:09 PM   #130
FLYNAVY30
for the uneducated in the group (ME), what's the difference between the Eaton Posi and Eaton True Trac? I'm assuming they're both different takes on a limited slip diff...
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 05-06-2020, 08:00 PM   #131
04ls1gto
The standard posi uses a spring to engage both Axel's. The trutrac uses gears instead of the spring. Check out this website
https://www.currieenterprises.com/di...ions-explained
Old 05-06-2020, 08:09 PM   #132
FLYNAVY30
Thanks very much....that was very helpful!
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 05-07-2020, 08:49 PM   #133
shearjs
shearjs's Avatar
Thanks for the real world responses. I will likely go with the Truetrac. This is my first complete rearend rebuild by myself so I’m looking forward to the challenge.
Old 06-23-2020, 11:55 PM   #134
doowoppwer
I don't know diddly squat about Suburbans. Any idea why there's plywood on the floor?
Roger
doowoppwer is offline   Reply With Quote
Old 06-24-2020, 11:11 AM   #135
polishspy
Roger
That is standard for the cargo area of a suburban. Basically like a truck bed.
Old 06-24-2020, 11:50 AM   #136
shearjs
shearjs's Avatar
Roger
I honestly don’t know why they went with a plywood floor instead of steel either.
Old 06-24-2020, 12:01 PM   #137
shearjs
shearjs's Avatar
I took a week off work to focus on the Burb. The to-do list included installing the Deadend Garage C-notch, painting the rest of the rails, moving the rear crossmember to install the 31 gallon fuel tank, mocking up the fuel tank, swapping springs to the CPP 4” HD, completing the rearend rebuild(ended up with a Truetrac and 3.73 gears), and running new brake and fuel lines from front to rear. I initially added the one inch blocks as well but I think it would be too low with the weight of the vehicle so I pulled those back out for now. I also have a No-limit rear sway bar that I tried to snake between the body and top of rails but I just didn’t have the ability to raise the body high enough to get it through. Maybe I’ll try again at a later date. I’m close to having the fuel pump wiring sorted out to maybe get this thing running soon.
Old 06-24-2020, 09:22 PM   #138
LockDoc
The Older Generation
LockDoc's Avatar
Looks good! I can't help with the sway bar, I've never installed a rear one.
LockDoc
Leon
Old 02-13-2021, 10:27 PM   #139
shearjs
shearjs's Avatar
After months of distractions, I'm finally back to a spot where I want to get going on the Burb again. Since the last update, I managed to squeak the rear sway bar between the body and rails. I went back and forth a few times, but ultimately decided to sell the Wilwood Rear Disc kit with parking brake to a local C10 club member and purchase Captainfab's rear D52 brackets and new Wilwood D52 calipers. I just wasn't happy with the way my the parking brake kit matched the Wilwood D52 on the front, and I honestly can't remember the last time I used a parking brake in an auto tranny vehicle. I've also dove back into the wiring to figure out exactly where I'm at. With a little luck, I should have it running within the next few weeks. Thanks for hanging around!
Old 02-13-2021, 11:24 PM   #140
ajgriffin
ajgriffin's Avatar
Looking good! How did you go about painting the rails while still under the car?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 02-14-2021, 12:29 AM   #141
shearjs
shearjs's Avatar
On my back with a foam brush and a quart of POR15 and some
solid help from my apprentice. It wasn’t the most enjoyable part of the build so far.
Old 02-14-2021, 01:23 AM   #142
ajgriffin
ajgriffin's Avatar
Any man willing to risk getting POR15 on a clean Paw Patrol shirt is worth his weight in gold!
Old 02-14-2021, 08:40 AM   #143
04ls1gto
He's hired! What sway bar did you use?
Old 02-14-2021, 09:32 AM   #144
shearjs
shearjs's Avatar
It’s the top mount anti sway bar from No Limit Engineering. I wanted something that didn’t hang down below the trailing arms so this one seemed to be the logical choice.
http://nolimit.net/products#!/Rear-S...tegory=6157532
Old 02-28-2021, 08:27 PM   #145
shearjs
shearjs's Avatar
Spent a little time this weekend finishing up the rear axle brake lines and fuel tank install. Hopefully this tank is in it's home for the final time. Eager to hear this turd make some noise!
Old 04-04-2021, 08:39 PM   #146
shearjs
shearjs's Avatar
I spent a little time installing the Captain Fab D52 brake brackets and new Wilwood rear calipers this weekend. These match the front brakes a lot better than my previous attempt. It also appears that the rear wheels are pushed out an additional 1/4” or so, which I desperately needed. I am not running the spacer pictured, just using it as a washer to hold the rotors right. The new studs were too long to use existing lugs without a spacer. 1 step closer!
Old 04-06-2021, 08:04 AM   #147
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on your burb! This is all stuff I'd like to do to our burb eventually but the money tree is missing a lot of that green stuff.
Where did you get your tank at? LMC is OOS and every where else wants to sell you a Blazer tank. I am not into ordering something that won't really fit. If I'm going to modify something I'd rather put a larger capacity tank in it. Or, do the blazer tanks actually fit?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-06-2021, 08:19 AM   #148
FLYNAVY30
You might check out Boyd Welding....made in the USA and they offer a tank for the Suburban. Not cheap but very high quality, bolt in, and you can spec it with a number of options as far as return lines, baffles, pump assemblies, etc. Its the only company I've been able to find that offers a fabricated tank with the Suburban side fill.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 04-06-2021, 08:24 AM   #149
Dieselwrencher
I've got one of their tanks in my Longhorn. They do offer a very nice tank but a square body burb tank will be roughly $500 or more cheaper to get in and done.
Ryan
Old 04-06-2021, 09:06 AM   #150
shearjs
shearjs's Avatar
I ordered a fuel tank kit for an 87-91 blazer through rockauto. It came with the tank, sending unit, fuel pump, and straps for $163. I swapped out the fuel pump with an Aeromotive 340lph. It is already baffled for fuel injection and only required moving the rear crossmember to make room. I'm pretty happy with the fitment. I had a Boyd tank on my old 70 GMC, but it felt like the 19 gallons didn't last very long with a 6.0L.
