06-24-2021, 06:57 PM | #1 |
Re: "Project Orangepeel" 52 A.D
beautiful! put the front clip lights on a switch for when the teenagers are "watching a movie"
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-25-2021, 08:46 AM | #2 |
Haha, I don't have a teen anymorebut that would work
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-14-2021, 11:30 AM | #3 |
I haven't posted in awhile thought I'd put some shots up.
I did upgrade the door panels with a 50's Era material and suede on the inserts. Mark.
11-14-2021, 01:03 PM | #4 |
The door panels look good.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-14-2021, 01:13 PM | #5 |
Gotta love it.....Sweet
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
11-14-2021, 05:10 PM | #6 |
Good job on the door panels!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
11-15-2021, 10:42 AM | #7 |
Thanks Guys!
Mark
11-15-2021, 10:58 AM | #8 |
Great job on the door panel. Very unique design.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-15-2021, 12:11 PM | #9 |
what a great looking truck
nice upgrade on the door panels too Thanks for sharing
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
11-16-2021, 06:41 AM | #10 |
Defiantly sets it off now.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-16-2021, 10:26 AM | #11 |
Thank you everyone!
The door design was put together by Erin Ruddy @ Ruddymade he lives here in town and we planned it out when the truck was first put together. (all black then) Mark.
11-16-2021, 11:10 AM | #12 |
Honestly speaking, I am not a fan of the patina look. However, this truck is awesome!
12-01-2021, 09:49 AM | #13 |
Thanks.
Yeah patina is not everyone's cup of tee. This a bit of survivor and custom. Mark
04-03-2022, 06:10 PM | #14 |
Thanks for checking out my build!
As far as the upper bars go the angle in or out isnt as crucial as long as they are parrallel to the lowers. your 22 degrees would be fine. Your lower bars... id try to really get them inside if possable depending how low its going to be. If you mount under the frame they could drag. When you start to set it up get your pinion angle set @3 degree up and tack a piece of 1x1 tube to frame and top of rear end tube to hold it in place. now it will make getting the 4 bar mocked up easier. hope this helps Mark
04-04-2022, 11:24 AM | #15 |
Junior Member
Thanks Reaper, I will do that, the welder series instructions aren’t that complete, but they do show that there is convergence of the upper and lower somewhere near engine. If they’re parallel, the pinion angle doesn’t change when diff goes up and down. With the two uppers at angles, in theory, they’re arc of travel would keep the diff cantered in the frame, left and right, and would only allow travel up and down depending on how stiff the bushings are. The shorter they are, the tighter the radius, and not much travel. Anyway, I’ll follow your suggestions and build. Thanks for the advise, and I won’t put the lower underneath, you’re right, it would interfere with ground lol
04-05-2022, 10:09 AM | #16 |
Sorry to hijack Mark
SARBlade Here is a web sight I used to figure out a 4 link. It talks about a 4x4 but the concept is the same. It is quite forgiving if you have interference in places. https://www.crawlpedia.com/4_link_suspension.htm
04-05-2022, 11:47 AM | #17 |
Junior Member
Thanks L50!
04-05-2022, 04:24 PM | #18 |
i love your truck mark!
04-05-2022, 07:12 PM | #19 |
Thanks Guys
