04-03-2021, 06:36 PM | #1501 |
Post Whore
Re: A '54 named Busty
so the rear speed bleeders aka speed thread leakers did not work for us, we got more bypass action than through the hole, and we even tried the just barely crack it open trick rather than the 1/4 turn twist to get them to bleed, so we went back with the stock bleeders in the rear, the front ones worked, so we kept them, I don't like returning parts but for $30 bucks these will be going back, just wanted to share
and a huge thanks to Pontiac Mike who swunged by for the first time in over a year to help a brother out, (we know he really wanted to get out of baby sitting his grandaughter, but shhhh I won't tell) |
04-03-2021, 11:44 PM | #1502 |
Post Whore
so the next hurdle to get over is to fab a custom lower bracket for the steering column since the aftermarket one I bought is a joke and an insult to Hot Rodding, I would not install this on my kids Big Wheel it's that flimzy and it doesn't even fit around the steering shaft
04-04-2021, 08:42 PM | #1503 |
Post Whore
I've been meaning to fabricate this rear bumperette to go behind the rollpan for quite some time now, and what better time than Easter Sunday
04-04-2021, 08:43 PM | #1504 |
Post Whore
I am most proud of using all Corono Virus scrap metal
04-04-2021, 08:47 PM | #1505 |
Post Whore
of course I had to run to Depot Home twice to get some MIG wire for the spark machine, the first time they put flux core wire in the MIG wire bin, and I didn't bother checking, the second time they were all out of .030 wire until I looked in the .025 bin and found two spools, next time I'm going to LOWE's
note the single bolt hole per side to reduce weight (ok so I was too lazy to drill two holes per side) |
04-04-2021, 08:49 PM | #1506 |
Post Whore
I think I even managed to spritz some gray primer on the metal to prep it for bondo and sanding before the final two stage powder coating tomorrow, ha ha yeah right
04-05-2021, 10:43 PM | #1507 |
Post Whore
made a lower steering column bracket for my late 50s truck / impala steering column
started out by carefully selecting the very first pipe I saw than we lopped 4" off of it and split it in half... half moons style |
04-05-2021, 10:49 PM | #1508 |
Post Whore
then we made fools out of ourselves by tryin to cut a hole in 10 gauge steel with a holesaw powered by a cordless drill, so we called in the heavy artillery aka Ol' Milwaukee
yes I know WD-40 aint cutting oil but that's how they do it on TV Last edited by Gregski; 04-06-2021 at 12:19 AM. |
04-05-2021, 10:53 PM | #1509 |
Post Whore
not my design, something I stoled off the InterWebs
04-05-2021, 10:55 PM | #1510 |
Post Whore
then it was off to our brake (break?) machine to put a bend in it
04-05-2021, 10:56 PM | #1511 |
Post Whore
the SEMA judges love rounded corners on their brackets, so here we go
04-05-2021, 10:58 PM | #1512 |
Post Whore
you find out right quick who yer friends is, when you try and get some help scratching up the newly painted steering column moching it up 17 times all by yourself, using every trick you go
04-05-2021, 11:01 PM | #1513 |
Post Whore
and here she is before I splashed her with sum primer
04-06-2021, 09:12 AM | #1514 |
Turned out good, and it's quite substantial!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-06-2021, 09:22 AM | #1515 |
Nice job on the column mount. Looks great
04-06-2021, 09:46 AM | #1516 |
That bracket is going to do the job for sure! Compare that to the aftermarket peice....no comparison, you will feel good using it. I don't know if it's necessary but I welded a small stopper/tab on the column , on the bottom next to the half sleeve you have and again at the column top against whatever bracket you use. Kinda locks the column between upper and lower mounts.
04-07-2021, 11:19 PM | #1517 |
Post Whore
04-07-2021, 11:21 PM | #1518 |
Post Whore
and here she is all bolted up, exhaust clamps aint just for exhaust you know
had Ray Charles weld it up for me... with his feet! |
04-07-2021, 11:24 PM | #1519 |
Post Whore
so Good News... Bad News
Good News: she runs and drives Bad News: the front tires rub on the outer fender bracket bolts, you know there are two per side on the inside front of each fender, so I am thinking of switching to the smooth button head Allen bolts and considering 1/4" spacers between the radiator core support and them brackets but this is all part of the shake out, the engine sounds soooo smooth like a Buick Last edited by Gregski; 04-08-2021 at 11:39 PM. |
04-08-2021, 07:30 AM | #1520 |
well hell, congrats!! if that's your number 1 issue after the first drive, you are doing REALLY good.
04-08-2021, 08:52 AM | #1521 |
Good deal. Glad it is driving.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
04-08-2021, 08:54 AM | #1522 |
"It's alive!"
That is a big step, congratulations.
04-08-2021, 10:45 AM | #1523 |
Post Whore
04-08-2021, 10:46 AM | #1524 |
Post Whore
04-08-2021, 11:13 AM | #1525 |
Congrats, that is great news.
please post some pics (with, or without the hood)
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
