04-29-2016, 01:07 AM | #1526 |
fabricator of anythng not wood
Re: 72 k20 project
Finally had some free time to surf some threads and happened on yours and I gotta say you got mad skills! And a sweet project as well!
05-06-2016, 12:01 AM | #1527 | |||||
Re: 72 k20 project
Aluminum is a bit trickier to get a handle on for sure. The more you do the easier it gets Quote:
I got these fancy things the other day... Last edited by ryanroo; 05-06-2016 at 12:06 AM. |
05-06-2016, 12:07 AM | #1528 |
Collector of Projects
Re: 72 k20 project
From where did you procure such an item?
05-06-2016, 12:19 AM | #1529 |
Re: 72 k20 project
Thanks!
Gsi machine and fab is the outfit |
05-06-2016, 12:33 AM | #1530 |
Re: 72 k20 project
05-06-2016, 10:42 AM | #1531 |
Re: 72 k20 project
05-06-2016, 03:59 PM | #1532 |
6>8 Plugless........
Re: 72 k20 project
Those handles are sweet! Thanks for finding them. :LOL:
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-08-2016, 09:52 AM | #1533 |
Re: 72 k20 project
I caught wind of these when they were in final prototype stage. I called that day and ordered them. my first question was, are you having them polished? Thankfully no. The surfacing work on the cnc is very impressive and gives it a nice bright but not shiny color. I love them.
You betcha. I mentioned how I thought that would be killer when I talked to them. I'm glad they ended up offering that. I'd love to have a set anodized before the pocket was milled in handle, then mill that in raw. I have plans to own more of these... Haha. the colors you can choose from for custom anodizing are pretty vast. |
05-08-2016, 10:12 AM | #1534 |
Carpe manana
Re: 72 k20 project
Those handles are a very nice touch Ryan. Look great.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-08-2016, 01:12 PM | #1535 |
Re: 72 k20 project
do they need to be coated, being raw aluminum?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-08-2016, 02:06 PM | #1536 |
Re: 72 k20 project
I hope they'll sell me 3, for my Suburban
07-06-2016, 12:16 AM | #1537 |
Re: 72 k20 project
Ryan, hope all is well. I noticed you haven't posted any progress posts in a while.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
07-06-2016, 12:58 AM | #1538 |
Re: 72 k20 project
Yes I hope all is good as well. Canada needs its fix of ryanroo fab wizardry as well. Altho I'm in Guatemala as I write this but I still need a fix ......
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
07-09-2016, 11:43 AM | #1539 |
Re: 72 k20 project
Sorry fellas, I didn't realize that it had been so long. Everything is good here and I appreciate the thoughts. My wife is a pretty specialized RN and travels for work. She was able to take a contract locally so it's been easy not to get on the computer as much when we are usually doing things together. I'll post up some pics soon I promise!
07-09-2016, 11:59 AM | #1540 |
Junk Yartist
Re: 72 k20 project
glad to hear all is well. what part of SW CO are you in again? We have family close to Dove Creek and have been back and forth a lit since we've been back.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
07-09-2016, 06:42 PM | #1541 |
Re: 72 k20 project
Yes we were getting worried... Good to hear things are going well for you both.
1972 K2500 Long Box 400/350 |
07-10-2016, 11:17 AM | #1542 | ||
Re: 72 k20 project
Thanks Pete!
It probably wouldnt be a bad thing. especially depending on where in the world you may be. here i am less worried, but i may drop them off with a paint guy and have a few layers of clear put on them just to assure they stay fresh. Quote:
anyhow, i will proceed with some pics The diff cover was waiting on tabs last i posted. here is the process for that 4140 insert and a pocketed hole in 6061 for the tab with the cover welded and all mounted up. the tie rod clamp |
07-10-2016, 11:33 AM | #1543 |
Re: 72 k20 project
i decided to rebuild the alternator mount. it had the stock cummins upper mount and an adapter plate i made to space it up a bit. i wanted something one piece.
part of the motivation for that was the need for air inlet tubing support. i made a bracket down low and a support rod off of the alt mount for the top. now the compressor snout wont be supporting the weight. next was oil lines. i used a strait and a 90* #10 ORB adapter to get out of the oil cooler housing. the #10 lines split into #8s and go to the dual filters in parallel. they are not tied down in the pics, i built them and hid them on the shelf so they are not in the way for now. |
07-10-2016, 11:44 AM | #1544 |
Re: 72 k20 project
i also had some clutch pedal things to address. i located the master and mocked up the pedal a while back, but decided to change it up for a better pedal feel and all that.
i guess i didnt take any pics of the firewall bracket for the master. so here is the start of the pedal mod. the Valair 3rd gen hydros come with this little rod end on the push rod. the tabs are its future i am also stretching the line between master and slave to far for reliable long term operation, so i picked up a few of these adapters for the pivot ends they use. i will build the line when i pull the bracket off the firewall for paint. i also have the brake pedal and push rod rigged up but have a few more things to do to call to it paint ready. |
07-10-2016, 11:50 AM | #1545 |
Re: 72 k20 project
I also finally dragged the welder over and welded the rear shock mounts. i should get some limit straps soon for the rear. once i have them i can mount the tabs and paint all this.
weld pics.... i also sketched this flare press tool and had a buddy burn it out on the cnc. the punch is 4140 it makes a 37* tube flare on 1" .065" wall SS sanitary tube. all made up and threaded on a #16 adapter. i have a cart-full of sanitary ells and some more tube to make up what will end up being the oil pick up tube, when i get to there... Last edited by ryanroo; 07-31-2016 at 11:22 AM. |
07-10-2016, 11:53 AM | #1546 |
Re: 72 k20 project
07-10-2016, 11:52 PM | #1547 |
Re: 72 k20 project
Ryan,
Thanks for the updates. Very nice work as usual. Do you need an apprentice?
07-10-2016, 11:59 PM | #1548 |
Re: 72 k20 project
You were trying to make a event in Augst weren't you? Going to make it ? And yes as always , great work . But I bet you allready knew that . Lol
07-11-2016, 12:11 AM | #1549 |
Chevy Enthusiast
Re: 72 k20 project
Here you go again making us all look bad, haha nice job as always!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
07-11-2016, 10:30 AM | #1550 |
Re: 72 k20 project
Beautiful work Ryan!
