#1551 |
Re: Crusty Rusty Leaky Squeaky 67 Step
Even when you got nothing going on you got something going on
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1552 | |
The Gen IV and up do it with PWM to the fuel pump, so the pump only runs when needed, or only as much as needed to maintain the pressure |
#1553 | |
![]() Join Date: Mar 2012
Still no word from the frame shop, so I've been gathering up parts to complete the swap. The CTS-V oil pan and kit arrived and looks like it will provide plenty of clearance for the cross member. I removed the manifolds, fuel rails and sound cover from the engine. I plan to paint the sound cover and the rail covers to match the truck color. Speaking of painting... I made the third trip in the last four months to yet another cornea specialist who advised me to STOP doing paint and body work, welding and grinding or anything that would irritate my eyes, especially the right one. The growths over the iris are so severe, the doctors feel it's too risky to remove them surgically. That only leaves the option of trying to maintain the vision I have left. So I'm researching full face respirators with the corrective spectacle kit. I can use it for paint and body, but still not sure what I can do for welding. I know they have supplied air kits for welding helmets so I'll be looking at them also. Pretty sure Speedglas offers a model, but I need something full face to keep the fumes away from the eyes. This wasn't a budget item before, but it is now. ![]()
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#1554 |
![]() Join Date: Apr 2005
Did you get the complete C&C kit (motor/tranny/wiring harness/ECM)? If so, the tune should already account for FPR. The stealth pump should provide more than adequate pressure to minimize any variations in the fuel pressure due to the distance of the FPR from the fuel rails. If you were wanting to go with BIG HP, I would recommend installing a return style fuel system with the FPR close to the rails. Let me know if you need any help with the tune, I've played around with the LS3 a little,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#1555 | |
#1556 | |
#1557 | |
Scott |
#1558 |
Hey Vic, when you get that Ls in there and tuned you might have to reinforce the tongue on that travel trailer
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#1559 | ||
#1560 |
Okay, my BIL Rick has been here from Seattle for most of the week and between fishing, eating chips and salsa and drinking beer, we did get a few things done on CRLS. First off, we setup a string line from the front of the frame to the rear and verified what the laser was saying. The advantage of using the string line was that we were able to determine a bit more accurately where the bend in the frame starts (right around the trans x-member). By the time you get to the front frame horns, the spec says you should have 14" from the frame to the C/L. We had slightly over 15" on one side and less than 13" on the other. So I'm confident the frame is tweaked, even though it has no obvious buckled spot.
Precision Collision is still backed up on their frame rack, so I took a chance and went back to the local shop that did the work originally. Took my pictures and described to the owner what was happening. After I finished, he said the reason they no longer work on this model truck is that no matter what they do to the frame, the body panels never fit correctly. He swore that when the frame left his shop they would have checked all the factory measurements, so he had no idea how it could be in this condition. He did soften up a bit eventually, but said the earliest he could have another look at it would be the middle of June. So I'm now heading in another direction. Scott put me in touch with a stock car buddy of his. He's getting the contact info for the guy (Mike) that does a lot of frame work for those cars around this area. Assuming I can get a place in line, I'll see if he can put this issue to rest. Meanwhile, we cranked out the Aeromotive in-tank fuel pump mount. Started with some aluminum angle and fit it into the block off plate that came with the Boyd's tank. I used AN bulkhead fittings for the pressure and return lines. The wiring feed-through is a brass compression union that I modified on the lathe and potted with JB Weld where the wires feed through. Voila! I now have a 340 lph, 90 psi pump for under $150. We ended up switching the fuel line to the driver side since the LS3 fuel rails connect on that side. Mounted the regulator/filter to the angled cross member which kept the return line short. While Rick was here, he also helped me repair my ancient Craftsman air compressor. The tank was leaking a tiny amount from the weld around the drain bung. Looked like an automated wire feed weld and right at the start/finish overlap there must have been a tiny inclusion caused by an impurity. Over time, the pressure and corrosion opened up a tiny little pinhole that would weep an occasional drop of water. Rick removed all the hardware and we laid the tank on it's side, cleaned the area and then welded up the pinhole. Good as new!
#1561 |
Very creative Vic, looks good!!! Hope you get the frame issue "straightened" out.
#1562 |
Vic it's good to see that you are getting some stuff done.
#1563 |
![]() Join Date: Sep 2010
Very Nice Vic... Good luck getting the frame straight... I would say the guy that straighten it the first time is a incompetent frame man... Stating that he no longer works on "those" truck because nothing ever fit is the biggest line of crap I have ever heard... back when we have the shop open we did the 50,60 and 70's truck all the time and NEVER had a issue getting one straight...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#1564 | ||
You bet, Brian. A little here, a little there... Quote:
#1565 |
Hey Dan, I've been watching Raymond's progress and it seems like I'm stuck in waist deep mud compared to you. I reckon no business owner likes to see a "comeback" but he could have finessed it a bit better. At least he made the offer to have another look. He's been doing it a long time, but everyone makes a mistake now and then. However, it's probably best if this other shop can work me in. I'll keep everyone posted.[/QUOTE]
I understand Vic... I have certainly had my issues with Chris Carlson's Hot Rods... I am on the downhill slope now... and I would say that once you get the frame issue Straighten out (tongue in cheek) you will be well on your way to completion... I did send you a PM awhile back about your engine... We may be isterested in it for my grandson...
#1566 |
Good lookin' stuff, Vic! Thanks again for helping Boppa the other day.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#1567 | |
Your fuel module looks good! Did you use fuel line that can be submersed in fuel? I found out the hard way that you can't just use normal fuel hose as the exterior of the line is not designed to be submerged in fuel and will deteriorate over time. Just a heads up.
#1568 | |
Outstanding work Vic, as usual!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#1569 | ||
![]() Quote:
Thanks, John!
#1570 |
#1571 | |
#1572 |
Vic,
I know you already have your fuel system planned, but I seen this setup a while back on a Corvette Forum and I thought I'd share, it's a mod to use the "Return less" fuel system....... Have a good one! Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#1573 |
We went to Sedalia yesterday to the annual West Central MO Vintage Auto Club car show. All their proceeds go to several charities, plus I get to catch up with a lot of my car buds, so we always have a great time. Weather was outstanding and they had over 150 cars counting the members.
When we got home, the spectacle kit for my full face mask was in the mailbox. So this morning I assembled it all and tried it on. Looks like it should work very well for grinding and painting tasks. That only leave welding protection for me to figure out, although I really don't have that much welding to do at this point. I'm leaning toward prescription swim goggles to wear with the helmet. They look like they'd easily fit. The lead I had on a frame shop petered out. So I'm back to looking again. I pulled the fuel tank, hitch, sway bar, fuel lines and some of the brake lines while I sort out where to go. Looks naked without some of those pieces. ![]()
#1574 |
I like the spectacle kit, i could use one to say the least.. even using a full face over instead of my nose/mouth mask would be nice except it won't seal around the ear frames of my glasses, then again i also have a goatee, humm....
Can you tell me what cartridge you have? Looks like 6011 but i cant locate that on the 3M page. Thanks! I just bought some new P95's at the paint store.
#1575 |
It's a 3M 6001 which is a "P95 series" organic vapor and particulate cartridge. P95 just means it filters 95% of airborne particles and is strongly resistant to oils which makes it a decent filter for painting.
