Old 11-13-2011, 08:47 PM   #151
67cheby
67cheby
67cheby's Avatar
Re: A New 68 Build Thread
LOL...that was funny...Plasma cutter !!
67cheby is offline   Reply With Quote
Old 11-13-2011, 09:01 PM   #152
VA72C10
VA72C10
VA72C10's Avatar
Nice work!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-13-2011, 10:07 PM   #153
nds1968
nds1968's Avatar
Nice work neighbor Can't believe I never seen this build until today Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 11-13-2011, 11:18 PM   #154
ccracin
CCTek
ccracin's Avatar
Thanks Nate, glad to see another truck in the area! I checked out your thread, very nice. Keep up the good work.
Chad
68 swb Project
http://67-72chevytrucks.com/vboard/s...d.php?t=262840
72 swb Project SOLD
http://67-72chevytrucks.com/vboard/s...=1#post3993641
THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com)
ccracin is offline   Reply With Quote
Old 12-05-2011, 08:52 PM   #155
ccracin
CCTek
ccracin's Avatar
More Pieces Going In!
We are continuing working on the cab. Before we mount the firewall for good, I thought it was a good time to build the brackets needed for some of the major components. The below pics are the mounting configuration for the Vintage Air Gen IV unit. Man this thing is big, but it should make it snow in the cab. The truck will be black with a black leather interior. We need the cooling. Next will be the brake pedal assembly and steering column brackets.
There was a ton of work just to prep this area to put the a/c unit in. We had to remove the old fan bump in the dash/kick panel area as well as fix some rust we uncovered. I think it turned out alright. Check it out.
This is where we removed the stock fan pocket.
By the way, that is the vintage air mock up unit. Man is it nice to work with. Not heavy and has the actual mounting brackets on it.
Thanks for looking!
Chad
68 swb Project
72 swb Project SOLD
Old 12-06-2011, 12:02 AM   #156
ajgriffin
ajgriffin's Avatar
Just out of curiosity would the unit fit if you pushed it as far to the passenger side as possible? Or do you just not need the extra space that would create? I have been under my dash enough to know
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 12-06-2011, 12:11 AM   #157
ccracin
CCTek
ccracin's Avatar
Not sure exactly what you mean, but it can only slide about 1/2" more to the passenger side before it hits. I also want to be able to put finished kick panel upholstery in. My other consideration was being able to hook up the hoses without getting broken fingers. I will probably use the original vent opening to mount some speakers. Hope that answers the question. Thanks for looking.
Chad
68 swb Project
72 swb Project SOLD
Old 12-06-2011, 12:52 AM   #158
ajgriffin
ajgriffin's Avatar
You answered it. At first glance it looked like you could fit the unit into the area where the factory vent in the kick panel goes.
Love the progress though! Top notch work!
Old 12-06-2011, 12:02 PM   #159
CheyenneShop
CheyenneShop's Avatar
Awesome work! You ain't lyin that thing is HUGE.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 12-06-2011, 05:17 PM   #160
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 12-06-2011, 06:01 PM   #161
crappiewrangler
This is some of the nicest sheet metal work I have ever seen. Very impressed with what you have going on here...
crappiewrangler is offline   Reply With Quote
Old 12-07-2011, 04:09 PM   #162
mac72
good info, I've been on the fence about the gen iv. nice to know you got it to fit,let me know if you want to sell the mock up unit when your done w/ it.
mac72 is offline   Reply With Quote
Old 12-09-2011, 02:27 PM   #163
ccracin
CCTek
ccracin's Avatar
I was going to do that, but then the hoses became a problem. I am really trying to build this thing with function in mind while not sacrificing the looks too much. I hate stuff that looks awesome but is impossible to maintain or work on. Thanks for the compliment!
LOL, isn't it. To make matters worse, we moved the engine back about 2 inches and are hiding the LS coil packs on the back of the heads. So the firewall recess is 7" deep! I don't know if you can tell from the pics. but the thing is in there at an angle to clear the firewall too. You will be able to see that better when I put the firewall back on. Thanks for the compliment!
Originally Posted by VA72C10 View Post
Looking good!
Thanks Buddy, I keep chopping but it's tough making chips! Why you selling your project? Hopefully it's just a change direction and not stopping! Thanks for all the kind words!
Thanks very much. I am really trying to do it right. So far so good!
With a stock fire wall recess, it would fit with no problem. The only thing is it will stick down below your factory dash if that is what you are using. This one is about 11" off the flat part of the floor. Some of this will be hidden with the new dash. Either way I think you can make it work. This truck is going to be Black with a Dark Leather interior. I didn't want the A/C unit to fight to keep it cool. I've seen a lot of vehicles that only need and on/off switch for the A/C. It's either on high fighting to keep cool or off. This unit should do the trick. We will probably keep the mock-up unit, this isn't going to be our last rodeo and this is my preferred unit if it will fit. They are not expensive. They are 59.95 at Summit. Well worth it so you don't damage the real unit while fitting and fabbing the brackets. Good luck with your project!
Chad
68 swb Project
72 swb Project SOLD
Old 12-09-2011, 04:35 PM   #164
FrankieD
FrankieD's Avatar
Just found this build I am always amazed at the talent on this site and the different types of builds being done. Keep up the good work.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 12-10-2011, 12:28 PM   #165
mac72
I here ya,mines black/black & in southwest fl. its gotta cool like a hurricane in Alaska,Ive put in a few VA units myself & they all seem to struggle.I got their biggest condenser & modified the core support to fit it, hopefully between that & the gen IV it'll cool it down,still worried about blower volume though.
really nice fab work so far,that trans tunnel looks sweet!!
Old 12-17-2011, 08:50 PM   #166
ccracin
CCTek
ccracin's Avatar
Thanks for the kind words Mac. I really am happy with how it is turning out so far.
Chad
68 swb Project
72 swb Project SOLD
Old 12-17-2011, 08:51 PM   #167
ccracin
CCTek
ccracin's Avatar
More Parts!
We are still trying to get as much done under the dash as we can before we weld the new firewall on. Next up is the steering column and mount for the brake pedal. After a lot of measuring, what iffing, we got the bracket built. I decided that I wanted to incorporated the pedal mount anf steering column mount into one piece that could be fixed to the cowl area. This is the area that the factory bracket was fastened too. Here is what we cam up with. A couple more gussets on the pedal mount and I'll get the bracket welded in. Here it is so far.
As always comments good or bad are welcome.
Chad
68 swb Project
72 swb Project SOLD
Old 01-07-2012, 10:10 PM   #168
ccracin
CCTek
ccracin's Avatar
1 step back!
So before we do anymore work to the cab, I want to get it back on the chassis to make sure everything we have done so far works. I also want to make sure the cab is held in place on the chassis before we fit and weld the firewall in. There were a few things we wanted to do before we put the cab back on the chassis. One of the main things was to fix a missed assumption we made when building the chassis. We set the front drive shaft loop height thinking we were going to use a 3" drive shaft and making some assumptions for rear end travel. Well, it turns out after talking to Denny's drive shaft, we need a 3.5" shaft because of the length and power output. That combined with the wrong guess as to rear u-joint placement and you have an interference with the drive shaft and front drive shaft loop. Here is a close up of how it looked.
You can see it is an integral part of the X-bracing in the chassis. After some head scratching we came up with a plan to fix the issue. First it called for grabbing the plasma cutter and sawzall and getting the bulk of the original loop out. Then we wondered how to get the rest of the bars cleaned up. Here is what we came up with. The trusty tubing notcher!
It really worked better than we had hoped. Check it out.
Then we made some sleeves to fit in the stubs to align the new loop. After that we cut and fit the new loop. Overall we added 2 1/2" to make sure we had enough room. There may be a trans change coming and the new one will be slightly shorter.
Some welding and grinding and you would never know we made the error, well except for me telling you here. Oh well, it's all part of the process!
Next up is putting the cab back on the chassis and then putting the engine and trans back in. Just to make sure everything clears! Better safe than sorry. After that we go for the firewall! Thanks for looking!
Chad
68 swb Project
72 swb Project SOLD
Old 01-07-2012, 10:34 PM   #169
VA72C10
VA72C10
VA72C10's Avatar
Nice work!!!
Old 01-23-2012, 11:22 PM   #170
ccracin
CCTek
ccracin's Avatar
Moving On!
Let's see where were we? Well the cab is now back on the chassis and the new drive shaft loop fits nice. The driveshaft will now fit as well. All good things! Now that the cab is bolted back on the chassis it is time to continue with the fitting of the firewall. Well, until you get side tracked. More on that in a minute. We set the engine in the chassis to verify that all the work we did on the trans tunnel was correct. It was, however we decided we wanted more room around the bell housing. So we added some pieces to make some room. All in all it didn't take anything away from the interior and it will be much easier to work on the drive train. Here is what we did.
Once this was complete I went ahead and welded in the steering column/brake pedal mount. I coated the cowl area with Eastwood's Por-15 product before welding it in. Here it is.
Now here is where we got side tracked a bit. As we were taking the motor in and out, we realized we hated our original design for the motor mounts on the chassis. If you look in the back ground in the first and second second pictures above you will see what they looked like. They didn't fit the LS engine as well as we would like since they were put in with the Big Block. They were also tight to the oil pan rail of the LS. You can see the notches we were contemplating. (Looks Like A Mistake Too) They also made us stand the engine and trans up at a severe angle to get the assembly in place. Are you getting where I'm going here? We need to get this truck done, we are running out of cut off wheels! Out they came and a new design was developed. Check it out:
Old Vs. New
These will allow the engine to slide back between the mounts. Previously the kick outs on the Champ Pan required us to go over and in the set the engine and trans. in. I think these look much better in general. The other thing this allowed us to do was lower the front of the engine 3/4". We couldn't do that with the rack and Big Block. I know it was the so called 2 steps forward one step back, but we will be better off in the end. Once we get the mounts stitched in, we will be off the side-track and back to getting that fire wall put in for good! Thanks for looking and sorry for the long post, but it is progress!
Chad
68 swb Project
72 swb Project SOLD
Old 01-23-2012, 11:42 PM   #171
jtp67-72
jtp67-72's Avatar
Re: Moving On!
Originally Posted by ccracin View Post
I think these look much better in general. !
ME 2...............................jim (yes I am paying attention!!)
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 01-23-2012, 11:55 PM   #172
ccracin
CCTek
ccracin's Avatar
Re: Moving On!
Good, there will be a test later!
Chad
68 swb Project
72 swb Project SOLD
Old 01-24-2012, 11:43 AM   #173
72k5zl1
72k5zl1's Avatar
just found this, looks great!
72k5zl1 is offline   Reply With Quote
Old 02-01-2012, 01:58 PM   #174
ccracin
CCTek
ccracin's Avatar
Major Milestone! (To Us)
It seems we started this project forever ago. We have been trying to get the new firewall in the truck. Every time we thought we were ready to put it in we found something else that should be done before we put it in. All in all I'm glad we did it right the first time. Every thing fit just as it should. Here are some pics to show how we went about it.
This is the empty hole. The floor and trans tunnel are all finished. We then went around the face of the cowl area in the dark with a light and welded up any pin holes in welds from the rust repair. The new firewall has a mounting flange that covers this area, so I don't want any moisture to get between those panels and into the cab. After all the holes were taken care of, I coated the area with Eastwood's rust encapsulator. This was to help curb any development of rust from factory seams we did not take a part.
Before mounting the piece, we applied a bead of seam sealer to the mating face of the cowl. This is mostly to eliminate any potential vibration between the 2 sheet metal panels. We also sealed the bottom weld seam. This will be done on the inside of the wiper tray before paint as well.
I also coated the back of the firewall mounting flange with self etching weld through primer for an added level of protection.
We then used cleco's to hold the firewall on and braced it to hold everything flat for alignment while tacking.
And FINALLY, here it is all tacked in. The fit to all the mating panels is excellent. Now it's time for me to try to weld it in and finish it with out screwing up all our hard work!
Thanks for looking!
Chad
68 swb Project
72 swb Project SOLD
Old 02-01-2012, 02:33 PM   #175
67cheby
67cheby
67cheby's Avatar
Clean !
