Old 06-11-2009, 12:01 PM   #151
joe231
joe231's Avatar
Re: I'm one of you guys now
Originally Posted by TimE View Post
The X looks good. How'd you cut the pipe? Chop saw?
Yes sir, Chop saws have a tendency to walk, so I had to grind some too....that is why there are different markings on them...I would test fit 2 of them then grind away what I need to until they all fit well..
we have a big gravity feed band saw, but it takes longer to set up so I figured I would just use the chop saw.....if I were going to make a few I would set up the band saw and cut a bunch....
CHEVY ONLY
Old 06-11-2009, 12:01 PM   #152
TimE
Hey Y'all!!
TimE's Avatar
http://kalecoauto.com/index.php?main...&products_id=2
Maybe you should try one of these instead and let us know how well it works...
"You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is dual input O-Pipe with standard finish."
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 06-11-2009, 12:04 PM   #153
joe231
joe231's Avatar
I have tried those...they make an amazing amount of torque, but I couldn't keep my high performance muffler bearings in with all that power...so until the muffler bearing technology improves I will stick with the X
CHEVY ONLY
Old 06-11-2009, 12:09 PM   #154
joe231
joe231's Avatar
has anyone seen this...it is a D pipe from flowmaster
http://www.summitracing.com/parts/FL...2/?image=large
looks pretty easy to make...no angles to cut
CHEVY ONLY
Old 06-11-2009, 05:11 PM   #155
JohnC
JohnC's Avatar
JohnC is offline   Reply With Quote
Old 06-11-2009, 06:16 PM   #156
scotts62
One day...
scotts62's Avatar
What will really help you is the "Dead end" pipe, you see it caps the flow directly and save the hassle of fixing engines or trannys, it makes your car/truck very quite and you dont even have to change the oil!!! EVER
Scott
93 crew cab build
Project 62
Old 06-11-2009, 06:25 PM   #157
JohnC
JohnC's Avatar
That and if you wanted to save on weight you could go with those plastic engines too.
Old 06-14-2009, 07:09 PM   #158
protrash64
Resistance is Futile
protrash64's Avatar
Nice job, Joe!! So now Ive read the whole thing.....what wheels did you use and have you gotten the exhaust installed? I have 40's on the pick-up and they are loud and resonant.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-14-2009, 07:21 PM   #159
JohnC
JohnC's Avatar
I have 40's on mine and it's not too bad. They are all they way out by where the spare tire is, so that may be why. If they are dumped before the axle they may be pretty loud.
Old 06-14-2009, 08:22 PM   #160
joe231
joe231's Avatar
Thanks Jeff...I have been running th rally wheels and 235/75/15's from the '66 so far....I want to get some black 20" Coys for it though...
I haven't gotten the exhaust done yet...was kinda planning on doing it after the engine swap....although I can't wait to hear it
John, do you know what size tube your exhaust is? is it a true dual?
CHEVY ONLY
Old 06-14-2009, 11:02 PM   #161
joe231
joe231's Avatar
I bolted up some stuff to see what it looks like, pay no attention to the rusty bolts, I will clean them up and paint them before final assembly...
CHEVY ONLY
Old 06-14-2009, 11:07 PM   #162
joe231
joe231's Avatar
got my X-pipe welded after fighting with the welder, it wasn't pretty, but it was welded, so I cleaned up the welds a bit and painted it.
also cleaned and painted my new to me flows, my wife thinks I'm crazy for doing it....she said "who is going to be looking under your truck?"
I said "there is a forum full of people like me, and I look under people's trucks"
CHEVY ONLY
Old 06-15-2009, 08:17 AM   #163
JohnC
JohnC's Avatar
Yeah she sounds like my wife. They just don't quite understand our sickness. I'm like that too. One thing that bothers me is on my truck there is one pipe ran above the tranny crossmember, and the other ran under. From what I can tell that is a stock type of thing to do, but it really drives me nuts!
I think the pipe on mine is 2". Down the road I will probably go 2.5". Are you running yours all the way out, or dumping it?
Old 06-15-2009, 09:20 AM   #164
joe231
joe231's Avatar
I know what you mean about the trans crossmember....it can be ran with both ove, just have to find a good exhaust guy....
I haven't decided if I'm gonna dump them before the axle or after....
CHEVY ONLY
Old 06-15-2009, 09:45 AM   #165
JohnC
JohnC's Avatar
I like both ways. I cut the tips off of mine so at least they are gone, but still trying to decide which way I want to go. I know the dump before will be louder, which on mine since it's not a daily driver will be ok. On yours though driving it everyday may be different. Well until you rap the throttle. Then it's like what complaints, I have no complaints. That's what I tell my wife when we have a moment of practicality about the Mustang. I just rev it up, and say what problem I see no problem!
Old 06-23-2009, 09:13 AM   #166
joe231
joe231's Avatar
I was charging my A/C last night and noticed the vacuum diagram shows a vacuum switch for the lock up converter...I got to looking around and think I may have found the switch, can anyone help me ID it?
here is a crappy cell pic of what I believe it to be
Name:  vacuum switch.jpg
oh and by the way...I got some nice ice cold A/C
CHEVY ONLY
Old 06-23-2009, 11:21 AM   #167
JohnC
JohnC's Avatar
I have that same switch on my firewall as well. The vacuum line is off of it, and I wondered what it went to. Mine is above the transmission dipstick though.
Old 06-23-2009, 12:41 PM   #168
jason65
Registerd User
jason65's Avatar
That is what it is. 2 wires and a vacume line. I was going to hook one up for the 700.
jason65 is offline   Reply With Quote
Old 06-23-2009, 02:15 PM   #169
JohnC
JohnC's Avatar
hmmmmm. I'll have to do some work on mine, and see what it does. Where does the vacuum line go to?
Old 06-24-2009, 12:47 PM   #170
joe231
joe231's Avatar
manifold vacuum, a loss of vacuum opens the switch and unlocks the converter.
so basically the only time the converter will lock is under light throttle.
it is used in conjunction with a normally closed set of contacts on the brake light switch.
hit the throttle and the converter unlocks to help with building speed...hit the brakes and the converter unlocks so you can stop with out killing the engine
look under your hood for the color vacuum diagram, should see the switch on there.....
on another note....I believe I have decided to convert my front end to a '73-'76 front end.
I am wondering what pieces and parts I will need to swap, other than the obvious....do I need to swap the core support and the lower valance panel?
CHEVY ONLY
Old 06-24-2009, 01:05 PM   #171
scotts62
One day...
scotts62's Avatar
Cool! I havent been on in a while, looks good!
Scott
93 crew cab build
Project 62
Old 06-24-2009, 01:55 PM   #172
joe231
joe231's Avatar
thanks brother-man, homie-G!
CHEVY ONLY
Old 06-24-2009, 03:25 PM   #173
JohnC
JohnC's Avatar
I wouldn't think you would have to change core supports. I figured the 80's were close enough that it was just a grill change, and headlight bucket change. I think it will look awesome! Are you ordering new parts, or going junkyard hunting?
Old 06-24-2009, 04:33 PM   #174
joe231
joe231's Avatar
I will probably hit up the pull-a-part, they typically have some 73-76 trucks.....certifit has the headlight doors for @ $14 a piece and the hoods for just over $100.
I know I have to change the support that mounts to the core support to fit the '73 grill.....I also know I should probably use search and see what I can find....
CHEVY ONLY
Old 06-24-2009, 04:37 PM   #175
JohnC
JohnC's Avatar
I thought the hoods were the same. Shows what I know. I didn't think anything really changed til 81.
