Old 11-23-2008, 11:47 AM   #151
jlaird
jlaird's Avatar
Re: 67-72 Bolt in pedal assembly
jeph, tommorrow i also want to talk about exhaust pipe routing. I just sit my trans in place and it doesn't look like the exhaust will fit between the booster and trans.
jlaird is offline   Reply With Quote
Old 11-25-2008, 09:07 PM   #152
nuke1
nuke1's Avatar
Well i recieved my set up today from Jeph and Justin at Scott's, very nice piece they have built won't have it installed for a while yet, but look forward to ordering more from them in the future, thanks for sending one my way . Very sastisfied customer
James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-25-2008, 09:14 PM   #153
Scottshotrods
James
James thankyou again for the order and we look forward to doing more buss
with you.
Justin
scotts hotrods
Scottshotrods is offline   Reply With Quote
Old 11-30-2008, 11:46 PM   #154
69chevy1
69chevy1's Avatar
any more specs or pics on the dash mount pedal assy
69chevy1 is offline   Reply With Quote
Old 12-01-2008, 01:29 AM   #155
Scottshotrods
we will have pics in a couple of days and we will be also
showing you the remote fill and the remote fill cap for
the master.
Justin
Scotts Hotrods
Old 12-01-2008, 10:35 AM   #156
ibad57
ibad57's Avatar
I went thru this whole thread and didn't find info on bleeding the system.
with the master as low as bleeder valve is there a lot of trouble removing air?
and gravity bleeding is out of the question.
Just woundering about basic brake porocedure!
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 12-01-2008, 10:54 AM   #157
bdydrp97s10
bdydrp97s10's Avatar
Jlaird.. any answers on exhaust clearance yet..
im curious
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 12-01-2008, 11:30 AM   #158
jlaird
jlaird's Avatar
not really. Justin has been great though with numerous phone calls. He emailed me some pictures, but they were not very useful just because they didn't show the area in question. Within the next couple weeks, I will be dropping in the engine and trans which will answer a lot of questions. If there is no room for the exhaust pipe, I will see if I can exhange it for the under dash assembly.
Old 12-01-2008, 04:44 PM   #159
jephs422
I'll have pics of the under dash assembly today. jlaird, get that motor in a.s.a.p., it's driving me nuts, LOL!!!
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 12-02-2008, 06:19 PM   #160
jephs422
Okay, here's a picture with the exhaust installed with the same pedal assembly.
This is a bad angle, but even though it is tight, there is room for the exhaust.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 12-02-2008, 06:47 PM   #161
jephs422
Just in case you want one of these to go with the booster
http://67-72chevytrucks.com/vboard/s...13#post3004813
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 12-02-2008, 08:08 PM   #162
kizer
Its Deja Vu time again
kizer's Avatar
Is that going to get the brake fluid really hot?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 12-02-2008, 08:37 PM   #163
Scottshotrods
we have done several chassis this way and have never had any problems
with the brakes not working well or the brake fluid getting to hot
Justin
Scotts hoitrods
Old 12-09-2008, 07:20 PM   #164
jlaird
jlaird's Avatar
justin/scott,
One these trucks, there is a wire going to the combination valve which activates the brake lights, correct? With the Wilwood proportioning valve, there is no wire. So what happens with the wire/how do the brake lights come on? I'm not sure what I'm talking about here, LOL!!
Old 12-09-2008, 07:27 PM   #165
smbrouss70
smbrouss70's Avatar
The wire going to the proportioning valve is for the brake warning light in the dash. The brake lights in your taillights are activated by a switch that is activated by the pedal under the dash. I don't know how their product is set-up, but you will need to find a different way to activate the brake lights since you are not using the factory pedal.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-09-2008, 07:41 PM   #166
Scottshotrods
Originally Posted by jlaird View Post
justin/scott,
On are brake pedal assy you have from us.You will have to install,
inline brake pressure swithch.When you press the pedal down this will
create pressure and activate the brake lights. We sell the brake pressure switch here at our shop.The price is $25.00
Justin
Old 12-09-2008, 08:27 PM   #167
jlaird
jlaird's Avatar
hmmm, would something like this work?
Old 12-09-2008, 09:22 PM   #168
Scottshotrods
One more thing to add to what I said
earlier.You will also have two wires coming off the pressure switch to power it up.
Josh your parts you are showing above will work for your application
Justin
Old 12-10-2008, 08:57 PM   #169
jlaird
jlaird's Avatar
FYI, (for people like me that didn't know) the wire going to the combination valve is for a brake warning light.
Old 01-03-2009, 03:21 PM   #170
69chevy1
69chevy1's Avatar
what ever happened to the dash mount pedal assy we never got specs or pics
Old 01-03-2009, 04:55 PM   #171
Scottshotrods
Sorry about the delay on the pics.The good news we have all made and ready
to ship.We will post some pics up this coming week for sure.
We have been really busy getting ready for the grand national roadster show
coming up in jan 09.No excuses,so please be patient we post this coming week.
Justin
www.scottshotrods.com
Old 01-04-2009, 01:51 AM   #172
69chevy1
69chevy1's Avatar
thanks justin
Old 02-01-2009, 12:27 AM   #173
jlaird
jlaird's Avatar
well I finally got the engine and trans in today and I dont see how an exhaust pipe can possibly be run. These pics show a piece of 2.5" pipe sitting on the booster and electrical connector of the trans. Where that pipe sits in the pics it would be hitting the floor.
The last pic I have the pipe touching the bottom of the booster and trans pan. The way it is in this pic it is STILL below the bottom of the frame rail.
I am lost for a solution.
Old 02-01-2009, 12:37 AM   #174
XXL
Seņor Member
XXL's Avatar
I've got an idea... Scott's needs to send you a call tag.
Sorry to see that this part of the project has gone so poorly.
XXL is offline   Reply With Quote
Old 02-01-2009, 12:39 AM   #175
jlaird
jlaird's Avatar
I'm thinking about exchanging it for one of their under dash units. Maybe they can make that happen for me.
