Old 03-05-2015, 11:37 AM   #151
Hogshooter
Re: Good 70 SWB
Man that looks nice, just read the whole thread and it looks like its been a journey for you to get it this far.
Hogshooter is offline   Reply With Quote
Old 03-05-2015, 07:19 PM   #152
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks it has been challenging at times and I will be glad when it is complete. I have learned a a lot and really enjoyed it.
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 03-11-2015, 08:55 AM   #153
rthomas
Re: Good 70 SWB
I like the detail of your build. Can you tell me the deminsions of the hole in your dash for the GPS/Radio system? Thanks
rthomas is offline   Reply With Quote
Old 03-14-2015, 08:42 PM   #154
bgood70
bgood70's Avatar
Re: Good 70 SWB
Ill measure but it fits a standard 2din radio cage.
Old 03-14-2015, 08:52 PM   #155
bgood70
bgood70's Avatar
Re: Good 70 SWB
I finally got the wood finished and bed installed on the truck. I used a black varnish 3 coats and 3 coats of spar varnish on top of that.
Old 03-26-2015, 05:29 PM   #156
bgood70
bgood70's Avatar
Re: Good 70 SWB
Ok so I am working to finish up for a car show here in the south east on April 11. This past weekend I installed taikgate. I had purchased aftermarket gate and latch kit. However I could not get the latch to clear with out wanting to hit edge of gate. So i pulled the orginal latch off original gate and cleaned it up and painted. Worked great. Also installed rear bumper from NPD which fit good. And installed upper side trim purchased from classic industries. Name:  20150322_172644.jpg
Old 03-26-2015, 05:32 PM   #157
bgood70
bgood70's Avatar
Re: Good 70 SWB
Also if you look i got exhaust installed. Went with (2)14 inch magnaflows up nice and tight and out behind he rear wheels. Off for an alignment tomorrow.
Old 03-26-2015, 06:42 PM   #158
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Good 70 SWB
Looking good. How about some pictures of the finished interior? I want to see how your dash, carpet and seats turned out.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-26-2015, 08:22 PM   #159
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Good 70 SWB
Your bed floor looks really nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-03-2015, 09:26 AM   #160
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks Dieselwrencher appreciate to comments.
Old 04-03-2015, 09:32 AM   #161
bgood70
bgood70's Avatar
Re: Good 70 SWB
My seats are still at the Upholstery shop I thought a month would be enough lead time for 2 bucket seats but seems I was mistaken... Once I get seats back and installed I will update with photos. I still need to get some carpet installed up on firewall. You can see some of the sound deadner still. Here are some picts of Dash.
Old 04-03-2015, 09:55 AM   #162
derotoreut
derotoreut's Avatar
Re: Good 70 SWB
Looking good. I wanted to see how the stereo and heater controls worked out for you. Keep us posted with updated pictures once you get the seats and carpet installed.
What are you using for carpet? Is the upholstery shop doing that too, or something you're installing? Keep up the good work.
~ Dan
Old 04-03-2015, 02:15 PM   #163
Advanced Design
Advanced Design's Avatar
Re: Good 70 SWB
Just went through the build. Great work and nice truck! Long journey to get here. Enjoy the April 11 show!
Advanced Design is offline   Reply With Quote
Old 04-03-2015, 02:35 PM   #164
Mapearso
Re: Good 70 SWB
Ok so I am working to finish up for a car show here in the south east on April 11. This past weekend I installed taikgate. I had purchased aftermarket gate and latch kit. However I could not get the latch to clear with out wanting to hit edge of gate. So i pulled the orginal latch off original gate and cleaned it up and painted. Worked great. Also installed rear bumper from NPD which fit good. And installed upper side trim purchased from classic industries. Attachment 1382967
Upper trim looks nice. What did you use to install it? Clips? Tape?
Mapearso is offline   Reply With Quote
Old 04-04-2015, 08:05 AM   #165
bgood70
bgood70's Avatar
Re: Good 70 SWB
Carpet I order a single molded piece from NPD And it fits well, however I will need to install addtional carpet (custom) higher on firewall where original for wall padding went. And also behind seat where fuel tank sat.
Old 04-04-2015, 08:08 AM   #166
bgood70
bgood70's Avatar
Re: Good 70 SWB
I used clips on most of the truck as I still had orginal holes where molding had been installed before. I did replace rear bed panel and opted to use tape for that one so I did not need to drill holes. I used 3m trim tape and seems to be holding well.
Old 04-05-2015, 06:03 AM   #167
HeavyD
HeavyD's Avatar
Re: Good 70 SWB
Truck looks great! I noticed you are using the cpp master cylinder rather than a booster setup..how does it stop? Rather, how much effort is needed compared to factory power?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 04-06-2015, 08:21 AM   #168
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks for the comments HeavyD. I am using Wilwood master cylinder with 1/4 bore. I have 4 wheel disk breaks and a portioning valve. With this setup I have nice easy pedal and it stops good. I know a couple people running this setup and all like it.
Old 04-06-2015, 08:53 AM   #169
bgood70
bgood70's Avatar
Re: Good 70 SWB
Took an opportunity the other day and had a buddy help me powder coat the rims. I had a local shop sand blast them for me first. Below are some pictures. Name:  wheel sandblasted.jpg
Name:  wheel powdercoated.jpg
Name:  Outside final.jpg
Old 04-06-2015, 02:10 PM   #170
Dieselwrencher
Re: Good 70 SWB
The wheels turned out great!
Ryan
Old 04-07-2015, 09:53 AM   #171
bgood70
bgood70's Avatar
Re: Good 70 SWB
Old 04-07-2015, 11:40 AM   #172
sduckworth13
sduckworth13's Avatar
Re: Good 70 SWB
Your truck turned out awesome What color was the original paint color code for the green? I'm debating colors and I'm leaning toward the original green.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-07-2015, 12:45 PM   #173
Advanced Design
Re: Good 70 SWB
Wheels look great. Did you powder coat them yourself?
Old 04-14-2015, 12:33 PM   #174
bgood70
bgood70's Avatar
Re: Good 70 SWB
Yes I had a buddy that had an old electric Kitchen oven and powder coat gun. I had the wheels broke down and took them over and did them at his place. Nothing fancy but they came out looking pretty good. We ended up putting a couple coats on baking after each coat. Great to learn new skills.
Old 04-14-2015, 12:34 PM   #175
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks I am not sure the ordinal color code. It would be the light green from a 70 Chevy c10.
