11-24-2010, 05:43 PM | #151 |
Registered Chevy Owner
Re: '71 Chevy 1/2 4x4
Here are a couple pictures for ya. I had to go back out into the bitter cold to take these. I hope you like.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
11-24-2010, 05:59 PM | #152 |
Wide n'Low
Brrrrr..
I know what you mean, really cold down (14 degrees or less) here as well.. my doors froze shut overnight with the rain the previous day. Took some time to thaw them out just to get to work. Too bad your not closer, I'd lend a hand. Looks like its going pretty fast though, you'll be back in action in no time. Drew it could be worse of course...lol
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 11-24-2010 at 06:02 PM. |
11-24-2010, 06:18 PM | #153 |
6>8 Plugless........
Nice progress. Good luck with the swap. Here is a trick I used on the side of the road getting semis unthawed. get a tarp, cardboard, wood, anything to put around the vehicle at the bottom. Place a salamander type heater in the side or at the front under the engine bay. It will heat up under there and the heat will rise. You can also use a metal oil pan and put charcoal in it and start a mini Weber fire. Just be careful with this as there is obvious open flames.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-24-2010, 10:25 PM | #154 |
yes, i do
I'd help but i leave on monday, got duty this weekend and the mrs and kid to spend time with
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
11-24-2010, 11:19 PM | #155 |
I know you would, thanks.
11-25-2010, 01:57 AM | #156 |
Still Learning
Holy crap! It looks super cold there. Man, it sucks you have to swap the motor out in that kind of weather, been there done that back before I had my own shop. I feel for you man. Keep the pics coming.
11-27-2010, 08:09 PM | #157 |
So I started the engine swap on tuesday the 23rd, and today I got the newer engine in and running. I just need to adjust the timing and/or carb, and now I also need to replace the heater core. A friend of mine came over to help yesterday and acedently bent the heater nipples, and now they leak.
I want to say a special thanks to oldiron. With out him with his help, guidance, and knowledge I would still probably scratching my head. Thanks buddy! Another thanks to lobofreak for coming over to help. Again with out his help I'd probably screwed up the install. Thanks bud! Here is what the new to me engine looks like.
11-27-2010, 10:01 PM | #158 |
yes, i do
Wait, that gob of grease is the engine? any weird noises from this motor yet?
11-27-2010, 10:23 PM | #159 |
I actually cleaned off most of the grease, but ya there still is a little left. The only noises coming from it was the valves when it first started, but it went away after it warmed up.
11-28-2010, 09:20 PM | #160 |
I had a hiccup with the engine this morning. The starter from the other engine apparently was going bad, and it finally kicked it this morning. So I swapped it out and everything was fine. I also replaced the heater core, and checked the timing while I was messing around.
The engine runs great and I'm getting a lot more heat now. Next thing I might get to this winter is changing out the radio to the AM/FM radio.
11-29-2010, 04:04 PM | #161 |
Nice job. Does this engine run better than the old one?
11-29-2010, 06:10 PM | #162 |
Heck ya it does! That old engine was real tired. I'm starting to think that there was something wrong with the bottom end, but I guess I'll find out for sure when I take it apart to see what was going on in there.
11-29-2010, 06:37 PM | #163 |
That's a good deal!
12-01-2010, 10:55 PM | #164 |
This morning I started the truck as I always do to get ready to go. after about 5 minutes I went back outside to kick down the choke, and I noticed that I didn't have any oil pressure then ....Well I fiddled around with it for a few then I decided to take my car instead. While I was out I got a call from my parts store telling me that my kick down cable for the trans was in. Since I had them on the phone already I asked to talk to my normal parts guy. I ordered all the stuff that I would need to replace the oil pump and he said that he would have it all ready for me when I got there. (Thats why I go where I go for my parts) Picked up all my parts and got to it when I got home. Since I was pissed about this I was talking to a couple other guys about it and they told me to check everything else out before I tore out the oil pan. So I did, and I started with the gauge lines. I hooked up a spare gauge pod that I have so I could watch for pressure while I cranked the engine. Strange I had oil pressure building. I started the truck up, and ya know what I found? I didn't have the distributer clamp on the distributer. I adjusted the timing the other day and I know I tightened the clamp and I checked the distributer, but I guess I should have taken a flash light to the clamp just to make sure.
Talk about a learning experience. I also replaced the kick down cable. That was fun
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 Last edited by nickp51chevy; 12-01-2010 at 10:56 PM. |
12-02-2010, 12:32 AM | #165 |
Atleast you caught it and you didn't end up dropping the pan. Think how bad that would have sucked!
12-02-2010, 01:16 AM | #166 |
yes, i do
sounds like you've been having quite the crash course lately nick. wonder what's gonna happen next?
12-02-2010, 01:48 AM | #167 | |
Well I do need to put in a new gasket between the pass. side exhaust manifold and pipe. But I'm not too worried about that. I guess these are the kind of things that happen when you're trying to do things for the first time, by myself, in the driveway, without all the tools to make things go easier, and in the freezing cold.
12-02-2010, 03:01 AM | #168 |
Just try to remember the KISS method when troubleshooting. Keep It Simple Stupid. A lot of times a problem can be something really simple that will get over looked most often.
12-03-2010, 12:56 AM | #169 |
yes, i do
well at least nick wasn't trying to NUKE it(navy joke)
12-03-2010, 12:59 AM | #170 |
Are you kidding?!? I was a conventional electrician. We have the most common sense out of all the rates in the Navy.
12-03-2010, 03:42 PM | #171 |
yes, i do
lol yeah ok nick........
12-05-2010, 05:26 PM | #172 |
I was driving to my Mom's house yesterday, and the truck started running kinda funny. I limped to the closest park and ride and left it there for the morning (we had plans for my son to see Santa so the truck could wait). So I got to the truck and started checking the spark plugs, and I had 4 plugs were the electrode had melted. Good times to be had in the park and ride. I would have taken pics but the plugs are some where in the parking lot.
12-05-2010, 05:40 PM | #173 |
yes, i do
all on one side, front, back or just all over??
12-05-2010, 06:33 PM | #174 |
I think 3,4,6,7, but 7 the electrode broke and fused to the ground tab.
12-05-2010, 07:36 PM | #175 |
yes, i do
sounds like you're too lean there. and it could possibly be a vacuum leak????
