02-06-2011, 01:53 PM | #151 |
Re: No Limit '72 C-10
Yes, we made the axle-side mount so that it can be flipped over, it my put the bar at too much angle. You really want the panhard rod to be level at R.H. Our panhard rod has a slight bend in it to clear the HD diff covers I'll put up some picts mon.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-06-2011, 02:03 PM | #152 | |
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-06-2011 at 02:08 PM. |
02-07-2011, 04:12 PM | #153 |
Here are install shots of our rear pahard rod kit. The chassis mount is the hardest part. The stocker has 4 rivits, that pass through 3 layers. I recomend drilling to 1/4", then punching out. Thats the way we do it. The new mount gives you three positions, and is a bolt in, using the stock holes to align it to the frame.
02-07-2011, 04:26 PM | #154 |
The axle mount is pretty basic. Slide the mount plate in between the axle pad and trailing arm, or lowering block. We provide a drivers side plate as a shim to keep the truck level. These plates are also the link mounts for our new rear sway bars. The U-saddle/mount plate have 5 deg. of adjustment via a slot for one of the mount bolts. This is to allow you to set the bar mount/bar with no binding. The bar has a 4 deg bend to clear aftermarket aluminum HD diff covers. The U-saddle can be mounted above or belowthe mount plate. The goal here is to get the panhard rod as level as possible at R.H.
02-07-2011, 04:53 PM | #155 |
Never Done?
Rob, the truck is looking good! Glad to see you guys getting some products developed. Makes me wish I could start to build another one myself!
02-07-2011, 06:03 PM | #156 |
A guy with a truck
Coupla Qs:
Is this your set ride height? If so, it appears you could move the driver's side of the bar down a hole to level it out more. Any reason it is positioned up one? Do you plan on doing the trailing arm forward mount flip on this truck? The IROCs go great with the sunroof
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-07-2011, 10:07 PM | #157 |
Just wondering on how you mounted those awsome looking IROC rims ? adapters or redrilled hubs ?
02-07-2011, 10:31 PM | #158 |
Easy boys. Yes, we will flip the front mounts, one thing at a time. Yes, we dropped the chassis mount 1 hole to get it level. No, we didn't drill, these spiffy 20" IROCs came 5x5. I know, it makes you want some doesn't it!!!!
02-07-2011, 10:51 PM | #159 | |
Thanks for the pics. Any idea when you'll have the sway bar mock up complete? I'm curious to see if it will work with my setup. Thanks, Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-07-2011, 11:09 PM | #160 |
Yea I want them and especially for $400, I paid $550 for 92 chevy SS rims, tires & caps. Where can you get them from with that bolt pattern ?
02-08-2011, 04:49 PM | #161 |
Rob, are you running 28" tires with your current setup? Do you sell the Moog springs and McGaughy drop spindles you're using?
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
02-08-2011, 04:54 PM | #162 |
Is there a problem with welding the Panard bar frame bracket?
02-08-2011, 05:30 PM | #163 |
The tires are 275 45 20, they measure almost 29". In the future I see a 275 40 20, at 28". Yes we sell the springs and spindles. Springs are 119, spindles are 249. Well, yes, you could weld the mounts, but, most of todays home builders want "bolt-on" components. So, naturally thats what we're trying to give them.
02-08-2011, 05:35 PM | #164 |
Tonight we're going to track test with the new shock and panhard set-up. We'll run the first session on the old tires to get a good test against the old numbers, and then swap to those fine irocs and run the second session. I fear that due to the weight of the wheel/tire combo, it might run slower with the 20's. Have to wait and see.
02-08-2011, 06:32 PM | #165 |
Happy to be here
JT is rockin the IROC's. Needs a big Rebel flag in the back window and some 38 Special blasting from the cassette deck.
Posted via Mobile Device |
02-09-2011, 02:26 AM | #166 |
"cassette deck" may be the hard part, - but you know we have .38 Special on the I-pod!!!!
02-09-2011, 11:25 AM | #167 |
Happy to be here
So how did he do last night?
02-09-2011, 04:00 PM | #168 |
You know how you buy a new Bad ass flowed carburator, bolt it on, and it runs like crap? Well it's really not the carbs fault, the rest of the motor just isn't up to the task. Thats how last night went. The new shock/panhard set up feels great. In both corner entry and exit, the rear is stable and connected. Thats good, sort of. The other thing is, you can throttle-steer a car thats 'loose' (rear slides around) but if you car/truck is tight, or pushes, you have to over brake. And thats where were at. Having the rear work is now causing a push, and we thought it would, and so we slowed our lap times to a 56.19 yes, we lost a second. Micheal mobley was our test pilot, and we also had 2 very experienced drivers take it out. All had the same experience. Tire temps show that the front is suffering, and with the rear hooked up, its just worse over all. You have to brake so much to get it to turn that you scrub off too much speed. Over all this is OK, and we kind of expected it. We stil have no sway bars, and old front shocks. So we go there next.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-09-2011 at 04:00 PM. |
02-09-2011, 07:07 PM | #169 |
Do you think your rear sway bar will work on a truck with the shocks in the factory location?
02-09-2011, 10:11 PM | #170 |
yes, no problem. I'll post picts once we have it installed.
02-10-2011, 12:16 AM | #171 | |
Man of Mini-Talents
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-10-2011, 12:34 PM | #172 |
Ha, well, I'd have to say that the difference is really small. The wheels are heavier, requiring a bit more brake going in. On the plus side, the tire grips a bit better, as would any tire less than 10 yrs old. Even though our lap numbers were slower, the truck feels better driving around, and a few more updates should bring the numbers down. We're going at this step by step so that you can see the progress, and what changes. Most trucks already have 'something' done, so this may help on the next changes or upgrades your deciding on.
02-10-2011, 02:16 PM | #173 |
A guy with a truck
Coupla questions on your panhard setup: Are they provided with poly bushings, or a rod-end? I see both in your pics. Also, any concerns with being a single vs double shear mount on the chassis side? And why the two piece construction (i.e: bottom and side pieces of the chassis mount bolt together, as opposed to an 'L' shaped bracket)?
Not intentionally picking your stuff apart, just curious. Very nice to see you guys experimenting and injecting some new products into this market
02-10-2011, 02:25 PM | #174 | |
Truck and auto performance nut
looks like routing the exhaust out the back gets a bit tougher....
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 02-10-2011 at 02:26 PM. |
02-10-2011, 08:25 PM | #175 | |
As far as exhaust plumbing, I would say that it's easier. I'll post up some picts as I plumb the JT
Tags |
1972 chevy, c-10, no limit engineering |
