Old 01-06-2013, 09:27 PM   #1
allaboutchevelles
allaboutchevelles's Avatar
Re: My 64 C-10 fleetside shortbed build
Thanks for the nice comments guys, I think I got a decent deal on the tailgate. I worked on making the new support braket for my inner fender last night. Im not going to spot weld it back in until after I sandblast the inner fender though. All that work spent on something that will never be seen when put together. Heres a few pics, I even posted a pic of my metal brake, LOL
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 01-07-2013, 01:01 AM   #2
likaroc13
Rollin' Old Skool
Originally Posted by Strodder View Post
You stole them. Good find.
glad to see you back on it as well
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-07-2013, 09:11 PM   #3
flips72
flips72's Avatar
sweet find on the parts, and great work on the inner fender. now i am going to make you a little jealous, knowing how much you like to fish i am headed to okeechobee bass fishing thursday, hopefully i will be sending you some pics.glad to see you back at it as well.
flips72 is offline   Reply With Quote
Old 01-11-2013, 11:22 PM   #4
allaboutchevelles
Ever since I heard how bad these new after market radiater supports fit I had to put my front end together and see if mine would fit ok. I got all the bolts started and then I had to pick up on the cab and position it a little better. My radiater support leans back also but everything bolted up nice and I think its going to be ok. Only thing I didnt do is put the hood on, didnt have any help around for that. Also check out the washer they sent in the bolt kit for the radiater support, last pic.
Old 01-13-2013, 11:58 AM   #5
1stseries55
1stseries55's Avatar
nice job man... it's funny, I think we are chasing the same parts sometimes. I got a hood and bed tubs from the same guy (I think) you got the tailgate from (in Cary)...and I swear those are the doors I tried to get a while back but I missed them...looks like they wen to a good home.
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 01-13-2013, 12:17 PM   #6
62 Barnfind
62 Barnfind's Avatar
Your truck is coming together nice. I remember when I was at the same spot in my build. I put my fender on without having one of my doors set right. Good luck!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-14-2013, 04:34 PM   #7
flips72
flips72's Avatar
nice work tony, starting to look like a truck again are you going to dis-assemble it again for paint?
Old 01-14-2013, 09:56 PM   #8
allaboutchevelles
Thanks Flips, Yes I will pull it back apart for paint. I still have to sandblast the other inner fender and paint them both. I just stuck the front end together to get everything lined up and fitted.
Old 02-10-2013, 10:39 AM   #9
allaboutchevelles
Just a small update. pretty boring stuff, I welded up some holes someone drilled in the kickpanel, one on the back of the cab, and a few more here and there. I did try out Alans trick welding a nut on the inside of the sheetmetal to fix a threaded hole. works great, thanks
Old 02-14-2013, 09:10 PM   #10
flips72
flips72's Avatar
progress is progress
Old 02-15-2013, 03:00 AM   #11
chevy88
chevy88's Avatar
You got really good fabrication skills, are you doing all your own body work also?
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-21-2013, 12:49 AM   #12
allaboutchevelles
Thanks chevy88. Yeah im doing all my own work. I cant afford to pay anyone. lol, I am doing all my own body work also. Im slow at it but just have to take my time and it should turn out good.
Thanks flips, you need a new project,
Im off work for a few days, I finally finished stripping the paint off the dash and sanded the kick panels tonight. I took a wire brush to the underside and backside of the dash the best I could. I bought some spray can eastwood rust encapsulater to paint the surface rust under there. Hope tomorrow I can push the truck out and blow it off, wipe it down and paint under the dash.
Old 02-21-2013, 11:49 PM   #13
allaboutchevelles
nice sunny day today in the mid 50s. I got to push the truck out of the shop and blow all the dust and mess off of it. I wiped down under and behind the dash with wax and grease remover and blew it off again. Used eastwood rust encapsulator to paint over the light surface rust under and behind the dash. Pushed the truck back in the shop and started some bodywork tonight. Still not finished yet but its a start.
Old 02-22-2013, 12:10 AM   #14
likaroc13
Rollin' Old Skool
looking good! makes you wanna get outside when the weather is nice...I know I'll be glad once Spring/Summer rolls around!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-22-2013, 11:06 AM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
I like the work your doing. Once I finish my son's truck, we are going to start working on mine again. Ill have to do some floors and rockers and lower front fenders, but that should be about it on the rust repair.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-22-2013, 11:42 AM   #16
Strodder
Daring to be Different
Strodder's Avatar
Progress is always good.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-22-2013, 12:34 PM   #17
Bomp
Bomp's Avatar
Been peekin in from time to time. Your movin right along.
Like that you took the time to get under the dash. Thats dedication.
Bomp is offline   Reply With Quote
Old 02-22-2013, 03:40 PM   #18
flips72
flips72's Avatar
nice work, i too like the fact that you took the time to go under the dash,atention to details is where its atwont be long till we start smelling paint, and your right i do need another project
Old 10-17-2013, 10:01 PM   #19
allaboutchevelles
Hey Guys, Its been a while since I posted on here. Been super busy with work and the family. I haven't worked on the truck too much all this year. I have got a few things done. Some body work and epoxy primmer and painted the firewall. Put the motor and trans in last weekend.
Old 10-17-2013, 10:29 PM   #20
likaroc13
Rollin' Old Skool
Good to hear from you! Truck is looking good.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 10-26-2013, 10:13 PM   #21
allaboutchevelles
took my power steering gearbox back off and cleaned and painted it. got it installed for the last time now. Also got some brackets and other misc things sand blasted tonight and ready for paint.
Old 10-31-2013, 06:21 AM   #22
flips72
flips72's Avatar
looking good tony, glad to see ya back at it.i aint got any fish pictures from you lately,have you been any? its about time for the crappie to get started.holler when you can.
Old 10-31-2013, 10:22 AM   #23
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Making fast progress! looks cool! keep up the good work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-04-2016, 12:07 PM   #24
allaboutchevelles
Hey Guys! Been a while since I posted anything. I have been busy with work and family. I have been tinkering a little on the truck here and there. Got all new brakes, wheel cyl, bearings, seals, and drums done. I mounted the power steering pump and lines. I also fabbed up a top radiator mount. my truck is lowered 3 inch drop springs in the front. My question is what shocks do I need to run? someone said factory shocks will work but I remember someone on here having a part number for a shorter shock from the parts store. thanks!
Old 12-05-2016, 01:18 AM   #25
Captainfab
60-66 Nut
Very nice work on the top radiator hold down.
