07-07-2012, 09:03 PM | #151 |
US Army Veteran
Re: Post Your Engine Bay Pics!!!!!!
That is stunning, Matt. Do you have a color code for the silver or any details you could share? Silver is silver, sometimes, but that looks like the most perfect silver I've ever seen.
1972 C10 Highlander - The making of a daily driver |
07-07-2012, 10:22 PM | #152 |
very nice!!
07-07-2012, 11:23 PM | #153 |
It's actually spray can. It's DupliColor Cast Coat Aluminum engine paint. I was gonna stick with the gray/blue theme my small block had, but it never looked quite right. The engine is all aluminum, and I wanted it to stay looking good, so painting it aluminum color keeps it that way.
07-09-2012, 10:36 PM | #154 |
Subscribed
1969 K20 4x4 1989 V1500 Burb |
07-10-2012, 02:19 AM | #155 |
Mine just finishing my ls conversion
Posted via Mobile Device |
07-10-2012, 08:44 AM | #156 |
67cheby
I like it with all of the orange peaking out !
07-10-2012, 09:13 AM | #157 |
What is your total cost on the swap if you don't mind my asking? If my 350 ever craps out, I'll be really tempted to drop a Vortec roller in instead of building another old school SB.
www.tomthetruck.blogspot.com <-- Aka build thread. |
07-10-2012, 11:32 AM | #158 |
There is a whole stack of receipts on the dash and some in a drawer at home. I haven't even begun to add all this up. There has been a lot of work done on this truck and I may have went over board on some things but wanted to do it right the first time and not go back and spend more money nothing was half a*****s on this conversion.
07-10-2012, 11:34 AM | #159 |
Thanks 67 cheby
07-10-2012, 12:56 PM | #160 |
07-10-2012, 01:35 PM | #161 |
Just got it out of the exhaust shop getting ready to plumb all liquid lines. The truck does start and run once done I'll try to post a video. This thing runs awesome and sooooo smooth when it's idling.
07-10-2012, 01:42 PM | #162 |
Just a car guy
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-24-2012, 04:05 AM | #163 |
10-24-2012, 01:39 PM | #164 |
Not quite done but it's getting there. Probably gonna end up doin an LS or big block swap somewhere down the road. This is just a plain ole 350, double hump heads, aluminum intake, mild cam, holley carb. Before, after
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
10-24-2012, 02:47 PM | #165 |
heres mine
10-24-2012, 02:58 PM | #166 |
better pic of mine and one of my wifes
10-24-2012, 05:21 PM | #167 |
1968 SWB - Project JA 1969 Camaro RS/SS 396 Conv |
10-24-2012, 06:56 PM | #168 |
Does this LS motor use coil packs? I don't know a lot about LS motors but I thought they all used them. I don't seem them in the pic.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
10-24-2012, 08:47 PM | #169 |
If you look close you can see them mounted where the dist. Would be only know this by reading his build thread awesome truck
10-24-2012, 09:50 PM | #170 | |
Here's a couple better and more recent pics. Engine swap thread is here--> http://67-72chevytrucks.com/vboard/s...d.php?t=506692 GM makes a distributor conversion kit for LSx engines, though. It mounts in place of the front cover, and has a piece that bolts to the front of the cam with a dist. drive gear and a fuel pump lobe to be able to run a mechanical fuel pump. It uses a SBF dist. Here's a link to a build with a front drive dist. conversion, and also with a front accessory system that will be similar to what I will eventually run. http://ls1tech.com/forums/carbureted...71-camaro.html
10-24-2012, 10:00 PM | #171 |
Cruzin
^ wow at that rad hose, i'm not a big ls fan there usually not to pretty, but yours is nice with that carb sittin atop.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-25-2012, 07:48 AM | #172 |
Yeah, the rad hose is gonna get changed. I think I'm gonna have my buddy at a machine shop make a threaded insert to go into the top of the water pump, then have custom metal tubing made for a custom fit.
10-25-2012, 03:08 PM | #173 |
best looking ls ive seen, nice job,
10-25-2012, 04:43 PM | #174 |
What!!! no inline 6's?
10-25-2012, 10:02 PM | #175 |
Cruzin
those great motors have a special 6 only threads
67-72chevytrucks.com/vboard/showthread.php?t=258488&page 67-72chevytrucks.com/vboard/showthread.php?t=471078
