Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-10-2012, 10:12 AM   #151
Super73
Super73's Avatar
Re: My build thread.. 63 LS powered C10
Ahhh, doing the thrash to get it done before the 19th...
Fuel system is done, decided against the hardline.
Mounted the regulator in a different spot
-12 from cell to pump
-10 from pump to y-block before rails
-8 from y-block to rails
-4 from rails to Aeromotive regulator
-6 return to cell
(2) -4's from rails to Fuel noids.
My bloody finger tips reminded my why I hate -4 stainless braided lines.
Got the rear end filled back up with fluid.
Got the drivers header back in place (sure wish I had a new set that fit, but oh well for now). Can't put the passanger one in until I get the trans cooler lines done.
Got the old rear brake line back in place for now, want to do stainless but time is my enemy right now, so when I rewire the truck after this race, I will go stainless hard line and braided ends.
Radiator hoses done and radiator filled.
Revised my to do list:
Converter Bolts
Alternator Mounting Stud
Belt
Oil Change
2ga for batterey Cut off
Wire Fuel Pump
Extend Fan Wiring
Motor Wiring Harness
Bolt done Throttle Body and spacer
Double check N20 Noids and jetting
Bleed Brakes
Trans Cooler Lines (Make one more -6)
Headers
Wide Band
Exhaust
Cut outs
Plugs
Mount Trans Cooler
Trans Fluid
Install windshield
Front bumper (optional)
Turn Signals (optional)
Not sure if I will do the front bumper or brake lights/turn signals. There is a class for the 20th that requires them, but I don't have to run in the class, just would like to. If time permits, I will do it, If not, oh well.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-10-2012, 12:15 PM   #152
Marv D
Registered Truck Offender
Marv D's Avatar
Looking at that list,, you better have a BUNCH of free time this weekend if your going to make the 19th !!!! If it were me, it would be 2 months (wait,, when my list was that short it still took me all stinking summer !!! LOL)
You know what happens when you start rushing....
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-10-2012, 12:41 PM   #153
Super73
Super73's Avatar
Luckily a lot of it is stupid simple stuff that has already been together before so that helps to reduce going together time. I think I can knock a good part of that list out tonight. Getting the misc parts I need today.
Old 05-10-2012, 02:08 PM   #154
PGSigns
PGSigns's Avatar
Once you get it complete you need to map the four link. Once you have the map you can pick and instant center length and height. How flat is your garage floor for setting the preload and anti roll?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-10-2012, 02:13 PM   #155
bigboybodry
bigboybodry's Avatar
To bad you don't live closer I would come help being I'm waiting on parts for my hull. Good luck and make sure someone take a video cam
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 05-10-2012, 02:33 PM   #156
Marv D
Marv D's Avatar
ooooops, wrong thread!!
Old 05-10-2012, 11:34 PM   #157
Super73
Super73's Avatar
Jimmy
Already mapped ICG before it left the chassis shop at its current ride height. Might have to add a couple turns on the spanners once fuel is in it to keep it where it is at as far as ride height.
Old 05-11-2012, 01:06 AM   #158
Super73
Super73's Avatar
Ok, got the following done:
Converter Bolts
Belt
Oil Change
Wire Fuel Pump (Most of it was there, just one new wire)
Extend Fan Wiring (Most of it was there, just one new wire)
Bolt down Throttle Body and spacer
Batterey Terminals
Fixed an extension harness for theknock sensors and cam sensor (was never right from the company I bought it from)
But as you work on things you see a few more to do..
Here is the update of what to do..
Rear Brake line (made just tighten to flex line for the caliper)
Bleed Brakes
Ground (Drill a 3/8 in a 2ga ring terminal and bolt down)
Check fuel pump
Fuel Pump Relay (Wire is run, just need to figure out which relay, One was for the N20 pump before)
Check Fans (Once I have power, it is easy to do with the computer)
Mount Trans Cooler
Trans temp guage
Top off Radiator
Plugs
Trans Cooler Lines (Need a section of -6)
Tie Loose wires
Passanger Header
Exhaust
Wide Band
Cut outs
Starter
Tighten Rockers
Trans Fluid
Bumper (Optional)
Turn Signals (Optional)
If all goes well it will fire up by tomorrow night. If not it will be on Sunday afternoon.
Old 05-11-2012, 10:14 AM   #159
PGSigns
PGSigns's Avatar
What we do is make a full size map of all the 4 link mount holes at ride height wet with tire pressure set. Then we draw the lines through the holes and make a spread sheet of the hole locations and combinations with there associated lengths and heights. Then pick a starting point based on the vehicle and power. So for your truck I would build a base line sheet that included four link and shock settings. Sheet would look like this
Four link 47 1/2" out 8" up
Preload neutral with driver and no anti roll (set with top right bar)
Rear shocks compression 2 clicks from dead soft, rebound in the middle of the settings.
Front shocks 3 from dead soft.
Tire pressure 8 pounds.
First runs would be with out anti roll to see if any preload is needed to get to track strait in water and the leave.
Then we would make passes and take notes and make adjustments based on video of the leave.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-11-2012, 11:30 AM   #160
hotrod 80
mini truck racer
hotrod 80's Avatar
Alot of work for a week . You gonna make first passes on a radial ? Flow the nitrous regulator also if you intend to spray it due to the fuel system changes . Truck looks good .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-11-2012, 11:52 AM   #161
Super73
Super73's Avatar
PG,
Right now we have it set up with a bit less hit with an ICG of 59" out and 5.75" up. All the bars are currently set in a nuetral state so no preload. The ICG should stay the same with or with out fuel if I adjust the spanner accordingly. After next weekend I will be getting it on my buddies corner scales and finding my true CG and weights based on fuel and me in the truck.
We are using a program call 4-link wizard to help with the 4-link map options. We may make some changes when I hit an actual prepped track like Sac, Dos Palos is not going to give me a ton of data. Sat there is no timers what so ever, no 60' no 330' and sunday only there is a 660' ET, not even sure if there is a mph. I plan on needing to peddle it there as there is no track prep either.
HotRod,
May 19/20 will be motor only. When I had the 347ci motor with the 80E, I could spray one stage once in second. But last time at this event, it was hard to keep the truck from braking loose 60' out. Not sure if it is due to the newer combo 418ci motor and Glide/bigger verter, but I had to short shift or the tires would go up in smoke about 6k rpm in first.
I agree that before I go anywhere on the unit I will figure something out on the N20 system.
Old 05-11-2012, 02:09 PM   #162
PGSigns
PGSigns's Avatar
Preload needs to be checked ready to go and on good flat surface. All preload is checked and set with the top right bar buy most folks. What I like to do reach in and while the driver is suited up and the car is in a ready state is just give it a rock and make sure the bar is loose. A quarter turn will make a change in the way one will drive. 4 link wizard is a good program. Let me know how the long IC does, Most my stuff has been in the 46 to 54 inch range. Just started working with a local pomod racer and that is another animal all together than I am used to and will see how that goes. Testing at Super Chevy in a week. Hope to run some 3.80's if the track is good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-12-2012, 04:12 AM   #163
Super73
Super73's Avatar
She runs.. Fired right up. Pretty much everything is together and running. I still need to have the windshield installed and will need to do something about the exhaust as the old set up did not fit with the outriggers. I need to get it warm, and double check the coolant level and trans fluid level. Might bleed the brakes one more time just to be sure.
I will try to get a little video up on Sunday.
Old 05-12-2012, 06:52 AM   #164
djracer
djracer's Avatar
Sweet! I can't wait till my pig is painted!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-12-2012, 06:55 AM   #165
hotrod 80
mini truck racer
hotrod 80's Avatar
Keep us posted and let us know how you do at the race this weekend .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-12-2012, 10:06 AM   #166
PGSigns
PGSigns's Avatar
Always a good feeling when they come to life.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-12-2012, 11:50 AM   #167
bigboybodry
Can't wait to hear it! !!!!!
Old 05-13-2012, 10:50 PM   #168
Super73
Super73's Avatar
Sorry, no video today. Went to take it for a short ride to find out the Weldon pump I got from a buddy of mine wasn't interested in making me happy. Luckily I have the exact same pump brand new on a shelf waiting for my Camaro. Swapped it out and worked a little on the tune.
Then I decided I would fix Danielle's Trailblazer SS since I need it to tow with this weekend. Never knew a starter motor would be such a task. It is barried in there along with the AWD stuff. Don't even have it out yet need to finish it tomorrow night.
Old 05-14-2012, 08:19 AM   #169
Marv D
Marv D's Avatar
You got that close, I'm impressed. That was a LONG 'to-do' list. Congrats on making it move under it's own power anyways.
BTW, you were dead right. Started pulling the urathane bushed bars off to replace them with solid rod ends and found a very damaged bushing in the diagonal link. That was why she was driving right at every shift. Great chatch!!!
Old 05-17-2012, 09:52 PM   #170
Super73
Super73's Avatar
Ok, decided I am not going this weekend. Buddy could get the windshield installed tonight, but I don't feel confident in the current tune. Having some timing issues at idle and would rather spend some more time getting it right before going to the track. Will probably try to hit the dyno next week. Here is a little idle video though.
Old 05-18-2012, 10:09 AM   #171
Marv D
Marv D's Avatar
Ohhhhhh baby!!! she is sounding seriously wicked!!!
Old 06-10-2012, 07:50 AM   #172
djracer
djracer's Avatar
That is a sexy truck. Good luck with the new combo. Some Rattle can flat black would look Awesome on your truck! Coming from the guy who is painting mine shiny Black.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-05-2012, 06:07 PM   #173
BigDan3131
BigDan3131's Avatar
Is this build thread done or will you still be adding to it? Did you ever find headers that work for you? If you haven't maybe you should just buy a kit and have your fab guy build you a set.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-05-2012, 10:45 PM   #174
shortbed70
shortbed70's Avatar
That beast sounds nasty!!!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-06-2012, 09:27 AM   #175
Super73
Super73's Avatar
Big Dan, the true question is are any of them ever done?
There are some things I want to do still:
Different headers
Re-wire the truck
Swap out the 12 bolt for the 9" I have
Port the intake
Get one of Paul Baxters front ends
Mount my fiberglass front end
Do some body work
Oh the list goes on
Thanks Shortbed.. Going to run it 8/17 and 8/18.
