Old 12-30-2011, 01:18 AM   #151
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Not Another Rebuild Thread....
Originally Posted by Alan's Classic View Post
Welding hood looks cool and your making some great progress. Keep it up.
Btw awesome art work!!
Alan's Classic is offline   Reply With Quote
Old 12-30-2011, 03:21 PM   #152
McMurphy
McMurphy's Avatar
Thanks Alan !!
I cannot seem to post any pics. I am getting this error:
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
Any ideas?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-30-2011, 03:28 PM   #153
daverod
SSN 706
daverod's Avatar
Where you trying to post porn? Because thats not allowed. Even large amount of bare skin are frowned upon. Really no ideas
daverod is offline   Reply With Quote
Old 12-30-2011, 04:04 PM   #154
McMurphy
McMurphy's Avatar
When it comes to porn I dont like to share....
But now that you mention it, it was a rather large patch panel I am putting in
I will try again laters I guess.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-30-2011, 05:34 PM   #155
McMurphy
McMurphy's Avatar
Looks like I can post pics now so going to try this progress update again!!
#1 is my donor section and my problem area.
#2 I started with cutting out the spot welds along the door jamb.
#3 Then I taped off and cut out the minimum of the problem area.
#4 I used the cut out problem area as a template, then holding the donor section up to the cab, I traced my cut lines again from the inside of the cab in a different color, and over size cut my patch. Then I slowly and incrementally trimmed the patch and the cab until the two fit up nice enough for me to start worrying about over doing it.
#5 I think as I tack weld it in I will be able to get that gap closed even more that it is showing in the pic. I only had a couple of vice-clamps holding it in place for photos.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-30-2011, 10:10 PM   #156
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Looks much better now McMurphy!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 12-30-2011, 11:39 PM   #157
allaboutchevelles
allaboutchevelles's Avatar
That patch panel looks good. I know what you mean about trim a little, check it, trim , check it. It takes me so long to this kind of stuff. I know you will get it. Take your time and it will turn out perfect.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-31-2011, 01:13 AM   #158
McMurphy
McMurphy's Avatar
Thanks guys!!
Well here is how it turned out...
#1 after my initial pass on all my spot welding, I had to cut a half dozen of them on the back side on the long verticle seam because I was not paying attention and it mis-aligned on me.
#2 this is how it sits now, ready for a light skim of filler, and paint. I also bonked myself because it wasnt until I took this pic that I even thought about the body lines aligning. Guess it is better to be lucky than smart, because I was HUGELY relieved to see they lined up as well as they did !
#3 this is my proud pic, this part looks so near seamless that I could lie and tell someone I know what I am doing ..... yah riiiiiiiight !!!
#4 while I was running my spot welds on the patch panel, I was scooting over to the d-side and installing my fuel fill patch as well.
#5 looks good to me !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-31-2011, 01:23 AM   #159
McMurphy
McMurphy's Avatar
I think it is time for me to get the floor patches now that I feel more confident on what I am doing with the welder.
I know I will need both rear cab corners, both side floor pans and both rocker panels. I will probably order the complete rockers instead of the partials.
I guess tomorrow will be a toss up between more fab work, or cutting out bad flooring.....
I am certainly uncertain, at least I am pretty sure I am....
Good night all, beer time !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-31-2011, 02:28 AM   #160
C@rnut001
Man, that looks good... and a huge improvement on the old ratty piece! Keep up the great job and keep the updates coming our way....
C@rnut001 is offline   Reply With Quote
Old 12-31-2011, 09:19 AM   #161
VeronikA
VeronikA's Avatar
Damn -23° sounds like not fun at all! I was complaining about -1° lol
You have definitely art skills my friend. Don't stop doing it. Not everybody is blessed with those hidden talents. Would definitely love to see more works from you!
At the same time I have to say you did a great job on that rusty part on your trokita! Looks awesome now! Keep it up my friend!
VeronikA is offline   Reply With Quote
Old 12-31-2011, 01:59 PM   #162
chad64chevy
chad64chevy's Avatar
cab corner looks real good, so does the gas filler piece! can't even tell you haven't welded before! i like the filler pieces you did on the grille panel, i thought of doing that myself! what does the frame notch for that look like?? keep it up its looking good!!
chad64chevy is offline   Reply With Quote
Old 12-31-2011, 05:36 PM   #163
McMurphy
McMurphy's Avatar
Thank you for looking, I appreciate the feed back!
Yep one of the coolest things about this site is seeing folks make progress in many different settings! I tend to not only learn from this vast diversity, but also keep my sense of adversity in perspective. I can certainly sympathize with the fellows who dont want to get out and work in 100+ degrees when I have to deal with 20 or 30 degrees below!
It keeps my whining to a minimum
Thanks Chad.
No frame notch.
I cut the frame end off as I will be adding a face panel under that to connect those two spots from the fenders, and dropping my bumper to below that. I will be modding the bumper as well.
The only way I can get away with this is because I am not dropping my front more than a very few inches.
Although I respect and admire the slammed guys for their work and vision, I would not be one of them...
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-01-2012, 05:09 AM   #164
57truckguy
Hey sarge,, good looking art,, I'm about as artistick as a bowling ball.. LOL But I do work good with my hands. Ha Ha When I was beginning to weld up the holes in my firewall was on a local contraction site and pick up a couple dozen plugs from the electrical boxes that the electrications were throwing around. With a little fileing several of them fit perfect and saved alot of cutting and )(*()*)*. if you know what I mean..
57truckguy is offline   Reply With Quote
Old 01-01-2012, 11:41 AM   #165
daverod
SSN 706
daverod's Avatar
Much better. And I learned a new word. Trokita, I'm suprised I did'nt alraedy know that word. Keep up the good progress.
Old 01-01-2012, 11:48 AM   #166
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
You may already know this 57truckguy, but make sure you have PLENTY of ventilation or a fumes mask if the plugs are the galvanized kind. Very toxic from what I have heard!
Jason
Old 01-01-2012, 11:56 AM   #167
coulter
coulter's Avatar
its looking good man nice work!!!! btw have fun on that floor...im in the works of doing mine right now and im not having fun..lol
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 01-01-2012, 06:05 PM   #168
McMurphy
McMurphy's Avatar
Yeah, I welded up some holes on my d-side door last night. Not a fun process by any stretch.
There is a welding shop here that lets me rummage thru their scrap dumpster for odds and ends and all they charge me is a couple dozen doughnuts from time to time. I think I am going to pop in there Tuesday on my way to work and see if they have an Iron Worker machine that punches holes and if I can get the plugs from it.
Thanks Coulter, I just ordered my patch parts today, hopefully they will be here in time for next weekend. I ordered both cab corners, floor pans, and complete rocker panels for each side.
Chad, I fabbed and put in the last of my grill mount modifications yesterday. It doesnt look like much right now, but when the paint goes on, you will see a huge change in the look of the face of the truck for it. I mounted it on the radiator core support and up onto the frame for you to see what I have done.
What I would not give for an anvil though!
You guys would laugh I think if you saw what I am using to fab my parts with!
#1 The spot I plan to fill.
#2 The part I made to fill it, roughed in.
#3 After tack welding in from both sides
#4 finished and mounted on the truck
#5 attempt at a perspective shot to show how flush it set.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-02-2012, 12:24 AM   #169
flips72
flips72's Avatar
killer work, patch panels look awesome, that kerosene heater must be doing its job....-23 wow, i would have gave up till spring
flips72 is offline   Reply With Quote
Old 01-02-2012, 02:38 AM   #170
57truckguy
Yesw I did know but it is good you brough it up for thoes that may not be in the know... good Work..
Old 01-02-2012, 02:40 AM   #171
57truckguy
Sarge Your patches are coming along great... I didn't have any of that to do on mine.. cab was in real good shape.. I think I could now that I've had some pratice with the welder...
Old 01-02-2012, 02:52 AM   #172
KroAutomotiveInc
KroAutomotiveInc's Avatar
looking good man keep it up and that 6 arms snake lady is crazy!
KroAutomotiveInc is offline   Reply With Quote
Old 01-02-2012, 09:10 AM   #173
KroAutomotiveInc
lol just read through your first post all the way you dirty wow player!! i was hooked on that **** since it came out finely quit for good 10 mouths ago i have well over a year /played time crazy waste of time!! to anybody with kids never let them touch that game give them heroin instead they will probably quit it easyer lol
Old 01-02-2012, 03:52 PM   #174
Chad215
Good job on those welds, I'm sure it was a little scary attacking with that welder for the first time.
I'm already a little nervous since I know I have some rust repair in my future and I've never touched a welding machine before. I've got my old front bed panel that I'm replacing to practice on though, so hopefully I'll be ok.
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 01-04-2012, 12:21 AM   #175
McMurphy
McMurphy's Avatar
Ummm Yeah... it was -40* when I went to work this morning. Oddly enough, they close the ski resorts when it gets below -20*. Thanks for looking at my patches, I appreciate the kind comments. Hopefully by the time I am really ready to do some serious stuff, I will know what I am doing!!
Thank you 57truckguy, I you always have positive feedback!! On getting on your welder you just need to... (to steal a golf quote...) grip it and rip it !!
looking good man keep it up and that 6 arms snake lady is crazy! lol just read through your first post all the way you dirty wow player!! i was hooked on that **** since it came out finely quit for good 10 mouths ago i have well over a year /played time crazy waste of time!! to anybody with kids never let them touch that game give them heroin instead they will probably quit it easyer lol
Thanks Kro! Wife and I played EverQuest for 8 years until they nerfed my Ranger into the stoneage. At that point we were both 3boxing on 3 seperate desk top computers, and putting in about 40 or more hours a week. My Ranger was ranked 10-12th on the server and we were in the second highest guild.
Then we switched to WoW to play with some friends of mine from work, but the sense of community wasnt there, I guess because of the amount of solo and PvP .... but.... the truck is more fun now and certainly has a tangible sense of productivity.
Oh and glad you like the snake chick. You should see the original art piece on her, the detail still amazes me (that I actually did it hehehehe)
Thank you for looking Chad215 !!
My first runs with the welder were more fustrating than scary because I could not see what I was doing so well. Then I got the auto hood and life with my welder changed LOL !
Just put on at least one leather glove (on your guide hand) and some not-so-flamable clothes and get up close with your gun and face, you will do fine I bet! It will help if you know someone to coach you a little too. I did about 30 years ago, but didnt take advantage of it when I had it....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
