07-08-2012, 08:37 PM | #151 | |
Re: Project "Captain Insano"
yeah, my wife is cool. she helps out......as long as it's from inside with the a/c. lol
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
07-08-2012, 08:47 PM | #152 |
got the c notches in. wrestling the frame around is a bit tough, but worth it to be able to work from the side or on top. i'm going to leave it where it's at now because i'll need to tip it up again so i can cut or drill out some large holes through the upper bag mounting area for the rear, through the c notch and 2 layers of frame (this isn't going to be fun).
i mocked up the lower control arms with the bags and upper plates bolted on. i raised it up, held it with a C-clamp, and marked where to drill the plate bolt holes. there's not much room as you can see, so i used a small rod with a very sharp point ground into it and tapped it just enough to mark it. then removed all of it and remarked my holes with a punch. marking with a punch is important so your drill won't walk on you when you start. (and that crossmember is tough to drill through) i stepped down 3 bit sizes. started with a 1/8" to 1/4" to 7/16". doing this makes it a little tougher on the larger bits, but makes it much easier. i resharpend bits every other hole. i just have a cheap grinder from harbor frieght. the motor isn't all that powerful for grinding big stuff or with lots of pressure, but it's perfect for sharpening drill bits and deburring edges.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. Last edited by suspect; 07-09-2012 at 07:31 AM. |
07-08-2012, 08:48 PM | #153 |
captain insano
07-08-2012, 09:52 PM | #154 |
Nice progress Daniel suspension is looking real good. I know you're a stud and all but I'm just around the corner if you need a hand flippin' the frame over bro.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
07-09-2012, 07:27 AM | #155 | |
i'm not going to weld in the c notch yet. i plan on driving this truck by this time next year. then i'll start buy the dropmember stuff to slam it. i'm not set on these plans yet, but that's probably what will happen. i just want to be able to disassemble it easily and sale the notch if i want to.
07-09-2012, 10:36 AM | #156 | |
a c-notch in the rear? As in will it frame the truck or how much clearance will you have when aired out Posted via Mobile Device |
07-09-2012, 06:59 PM | #157 |
i'm not sure how far off the ground i will be when aired out. i've looked at alot of pictures to get an idea. different factors play into it like wheel/tire size, bump stops in notch, cups mounted on bags, etc. i know you can get it low enough to were the differential will stick through the bed an 1" or 2". i'm going with a wood bed, so i'm not sure if i want to go through the bed just yet for an 1". i'll have 20's for wheels. i think i'll get it pretty low.
07-10-2012, 12:15 AM | #158 | |
07-11-2012, 08:58 PM | #159 |
i made a templete out of 1/8" steel plate at work during lunch today. it's not the prettiest, but i just needed the bolt pattern. i bolted it through the spring hole. i'm going to start off with the bags mounted against the frame and trailing arm. i will weld on some extra plating to the sides of the frame and trailing arms for support on the bags that go past. i will add a steel plate or cup just enough to clear the bed floor later after it's all assembled.
within 2-3 days, i'll be able to start assembling the front suspension. it's getting exciting.
07-13-2012, 05:51 PM | #160 |
i ordered some powerbraid sleeve to run over my air lines in some areas. i also got a grommet kit from summit and a gas filler plate from infanti.
07-15-2012, 12:05 PM | #161 |
Nice build man! Jeez i need to start a build thread already.
-Gunnar Spending $ I Dont Have,
On Things That I Dont Need, To Impress People I Dont Know, It's The Truth. |
07-16-2012, 06:51 PM | #162 |
thanks nuttinspecial. i picked up a 700r4 w/torque convertor today, '89 model. the guy says it works good when they pulled it from his friends truck. if it does, then that'll be a nice bonus. if not, i'm going to see how well i do at learning how to rebuild it.
07-20-2012, 11:02 PM | #163 |
i needed to replace some lug bolts. figured i might as well clean them up and replace the seals also. i may just go ahead and buy new axles also. the bearing area is still nice, a little wear on the seal area. they're cheap though so it probably just depends on how impulsive i feel some day.
to get the lug bolts out just knock them out with a 3-5 lb hammer. about 4 good hits and they'll come out. if they don't, then get a bigger hammer. got wilwood rear disc conversion with d154 calipers and E brake ordered today. should be here in about 2 wks. when i first started this build in january, i was worried i would be ahead on the work and be stalled by getting the parts in. i now have all these parts piled up waiting on me. my plan was to be driving it by the end of next summer. it may be early spring now. we'll see.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. Last edited by suspect; 08-02-2012 at 07:13 PM. |
08-02-2012, 07:23 PM | #164 |
the rear disc conversion came in today. i haven't done much in the last couple weeks. it's been over 100* everyday plus we don't have a/c in our shop at work so i don't care to keep working in the heat once i get home.
i got the wheel studs, seals put in, and painted the rear end. i was assuming i could put this brake kit on with the axles in, but i have to take them back out. i started on setting up the air system, i can't find any place to mount the valve manifold. so i have to make a mounting plate and figure where to put that. i'm hoping i'll get quite a few of this stuff assembled this weekend.
08-03-2012, 07:53 AM | #165 |
67cheby
Sweet brake kit !
08-03-2012, 08:08 AM | #166 |
X 2! Where did you get it? Part #?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-03-2012, 09:06 AM | #167 |
Still Learning
Nice!
08-03-2012, 09:43 AM | #168 |
Laid Back
Very nice!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
08-03-2012, 12:06 PM | #169 | |
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
08-03-2012, 08:24 PM | #170 |
thanks to everyone. they have a bit of a price tag, but they are going to set the look of the truck off. i just ripped it off like a band aid and got it done.
i ordered them through scotts hot rods, talked with justin. this is what is on my sales ticket: wilwood 12" D/S rotor metric caliper red - parking brake 12 bolt c10 part # 140-12569 DR they look just like the D52 but are a little smaller and have a metric fluid inlet. the rotors are 12" diam X 1" thick. everything there is wilwood brand. they're not in the photo but wilwood brake pads and caliper bolts are also included. i still have to order the E brake cable, justin says a stock one will not work with it. while i was waiting for them to show up, i checked out the part # on the wilwood site to see what the E brake set up was like. i couldn't find out anything about it. anyway, turns out the E brake is just like a 2001 silverado style.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. Last edited by suspect; 08-03-2012 at 09:34 PM. |
08-04-2012, 10:46 AM | #171 |
Those rear brakes are beautiful !!! A little spendy for me but I likey.
08-05-2012, 12:09 AM | #172 |
Just did a full read.....MAN.....you are killin it. Wish I could get stuff done fast like you. Get it done before your wife starts makin out Honey-Do lists to keep you occupied.
-subscribed- |
08-05-2012, 05:52 AM | #173 |
thanks a lot. i do feel fortunate that i'm able to do a build like this. i have a lot of respect for the guys out there with families and kids to take care of, so i know that can hold you back. us not having kids to take care of (plus here i am up at 4 am on a sunday about to go to work), we're able to do a little more playing.
08-05-2012, 05:08 PM | #174 | |
Keep up the great work!!!!! |
08-05-2012, 08:16 PM | #175 |
i got to tinker with some of the new parts today. everything in this kit bolts up real nice. i've checked out other peoples drilled/slotted rotors and have seen them mounted the other way. these have an arrow stamped on them, so i'm not sure how much of a difference it makes.
