Old 04-26-2013, 07:43 PM   #151
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Baby blue 1970 GMC LWB resto-mod
Do you remember the part number for the flowtech headers? I have a
91 IROC engine installed. When I look at summit, they list two different ones.
Also on the pic, looks like the 3rd plug going to the back is blocked by the header, can you confirm that for me? Thats the problem I have now.
Thanks.
Great build.
VDOG is offline   Reply With Quote
Old 04-26-2013, 08:40 PM   #152
Square_78
Square_78's Avatar
Flow tech 11108 I believe. 1967 camaro/chevelle shorty headers. My plug wires are angled heads 90 degrees and they fit with room to spare. I believe you are correct if u have straight wire boots then you might have problems with one or two of the cylinders.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 04-26-2013, 08:45 PM   #153
Square_78
Square_78's Avatar
Thanks.
Great build.
You need the old camaro headers so that they clear the frame rails and motor mounts other headers will hit the frame rails. Even if you have a 91 Iroc motor you will still need the right headers to fit your frame. I guarantee iroc headers will not work.
#teamlongbed
Old 04-26-2013, 08:49 PM   #154
Square_78
Square_78's Avatar
You can also get shorty spark plugs designed for header applications. They are simply shorter and give you more room to work with. Champion RV92YC #930 shorty plugs are what I was told to use for my sbc 350. I think they are listed under marine applications but apparently a lot of hot rodders use them for clearance issues.
#teamlongbed
Old 04-26-2013, 09:17 PM   #155
Slammed66
Needs a Big Block
Slammed66's Avatar
You put the drop spindles in yet????!!?????!!!????
We wanna see........
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-26-2013, 10:28 PM   #156
Square_78
Square_78's Avatar
Not yet still messing with front air bags. Waiting for my ss7's to arrive. Can't do the spindles until I install all my new brakes and master cylinder. Hopefully next month. I'm also excited to see it with another 2" drop!
#teamlongbed
Old 04-26-2013, 11:38 PM   #157
Slammed66
Needs a Big Block
Slammed66's Avatar
I have a pair here... Coulda had em in a day er two!!!
1964 Short box
1972 K10
Old 04-26-2013, 11:42 PM   #158
Square_78
Square_78's Avatar
You have some slam 7's? Well assuming KMS hasn't lost them while transfering them from Vancouver to Kelowna... Hahaha maybe I will need yours! I've already paid for the ones at KMS. Supposed to be here almost 2 weeks ago.
#teamlongbed
Old 04-26-2013, 11:47 PM   #159
Slammed66
Needs a Big Block
Slammed66's Avatar
Good Greif !! Well get you back on track if they don't !!
1964 Short box
1972 K10
Old 04-26-2013, 11:50 PM   #160
Square_78
Square_78's Avatar
Thanks man I'll let you know!
#teamlongbed
Old 04-27-2013, 12:36 PM   #161
VDOG
Grand PooBaa Member
VDOG's Avatar
I see, so even though the Flowtechs are for my year engine, your saying I will have a clearence issue with the frame. Interesting.
Old 04-27-2013, 05:05 PM   #162
Square_78
Square_78's Avatar
Yes all the small block Chevy motors are the same. All the car frames are different. Since they don't make a proper header for our lowered trucks, the next closest frame match is the 67-69 Camaro and Chevelle.
#teamlongbed
Old 05-01-2013, 12:03 AM   #163
re1
re1's Avatar
Nice work,
truck looks great !
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline   Reply With Quote
Old 05-01-2013, 10:53 AM   #164
Rusbuilt
Rusbuilt's Avatar
I like this truck! Nice work!
Rusbuilt is offline   Reply With Quote
Old 05-08-2013, 08:29 PM   #165
Square_78
Square_78's Avatar
A couple new pics
#teamlongbed
Old 05-08-2013, 08:30 PM   #166
Square_78
Square_78's Avatar
#teamlongbed
Old 05-08-2013, 08:33 PM   #167
Square_78
Square_78's Avatar
Finally got my slam ss7 front bags today. Hopefully get them installed tomorrow. These ss6's just don't have any power to lift the front end at 150psi. If I was running 175psi then they might be ok. My compressors aren't rated for it though. If I can get these new slams installed then I can get my front shocks and height sensors installed finally.
#teamlongbed
Old 05-08-2013, 08:36 PM   #168
Slammed66
Needs a Big Block
Slammed66's Avatar
What compressors are you running?
1964 Short box
1972 K10
Old 05-08-2013, 08:40 PM   #169
Square_78
Square_78's Avatar
400c viairs that came with my Accuair kit. They are rated max 150psi. I have heard of people running them at 175 but I don't know what that's going to do to my compressor life span. I can adjust my pressure on my remote easily if I wanted to. It's got 150, 175 and 200psi setting.
#teamlongbed
Old 05-12-2013, 11:46 PM   #170
Square_78
Square_78's Avatar
Got the ss7 bags in the front. 100% improvement and lots of lift. Those ss6's are just too small to lift the heavy front end. Rides awesome at all heights.
#teamlongbed
Old 05-12-2013, 11:47 PM   #171
Square_78
Square_78's Avatar
All up. After the drop spindles go in, the front won't lift quite so high as it does now. 2" less lift because of 2" more drop
#teamlongbed
Old 05-12-2013, 11:50 PM   #172
Square_78
Square_78's Avatar
Back end all the way up
#teamlongbed
Old 05-12-2013, 11:51 PM   #173
Square_78
Square_78's Avatar
All down
#teamlongbed
Old 05-12-2013, 11:54 PM   #174
Square_78
Square_78's Avatar
Next step is get the front shocks mounted and get the ride height sensors mounted so I can use the preset heights and ride control features.
#teamlongbed
Old 05-13-2013, 08:00 PM   #175
Square_78
Square_78's Avatar
Bought some more stuff today. Lordco had some things on sale so I couldn't refuse
Polished aluminum valve covers, felpro gaskets, polished aluminum air cleaner, chrome valve cover breathers etc.
#teamlongbed
