Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-19-2013, 02:32 PM   #151
jgammill
Re: Project: GOOBER, 1971 GMC
Originally Posted by johnnyclack View Post
Looks great !
Close tolerance / clearance; if it becomes an issue later on ya’ might want to consider placing bump stops between spring perch(s) and frame rail.
I had a similar problem with a 28,000 GVW boom truck which we installed Hy-rail gear on so it could operate on RR tracks. Because of reduced suspension travel we extended the mounts on bump stops thus eliminating the hitting/rubbing issues.
I already have bumps on front and back. You can see one of the rubbers in the 3rd picture behind the tie rod on top of the spring plate. That was with it flexed out setting on the bump.
jgammill is offline   Reply With Quote
Old 07-29-2013, 12:53 PM   #152
jgammill
We made it down to the river and set up camp. We were watching the water for a couple of hours and decided we better move the camper a little further away. It was coming up quick. About half way through the day my rig made a pop sound like the tcase popped out of gear and I lost all movement. I was setting on flat ground and just tried to start going when it happened. Pretty sure it's my intermediate shaft on my double transfer case set up. So I had to be dragged back to the camper and we pushed it backwards to get it hooked up so we could move it, since I was the only one with a hitch.
Picture of our camp after the move.
Then we had to get me loaded up the next day with the camper still in tow.
I've got it in the shop now. Hope to get it pulled tonight and see exactly what is the problem.
Old 07-29-2013, 03:04 PM   #153
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Know the feeling,
I had/heard a “pop” in a similar situation one time in my 76’ FJ-40 small block. I Had cracked my transfer case (case)in half. Cost $800.00 in 1978~$ to replace it w/new.
I hope your luck is better than mine...
johnnyclack is offline   Reply With Quote
Old 07-29-2013, 03:08 PM   #154
jgammill
Know the feeling,
If it is the shaft that I'm thinking about, it will be the second time for it to brake. The other time is when I had this setup in a jeep. If it is that then I'm going to spend the $300 to get the aftermarket beefier designed shaft and not put a stocker back in like I did last time.
Old 07-29-2013, 05:18 PM   #155
obijuan
What or whos doubler do you have in there?
obijuan is offline   Reply With Quote
Old 07-30-2013, 10:27 AM   #156
jgammill
It is a Jed's steel doubler, 203-205
Old 07-30-2013, 11:00 AM   #157
obijuan
i have heard about those resplined shafts breaking, but a new hardened one ought to do you good. its a pain in the ass to pull my ord doubler. your adapter is steel!
Old 07-30-2013, 11:08 AM   #158
jgammill
I found my problem. I believe it is called the intermediate shaft coming from the NP203 gear box. The splines twisted pretty good before it let go. Waiting for ORD to open this morning so I can give them a call and see if they have something better than stock. I have another case I could rob it out of but would rather upgrade while I'm in there.
Old 07-30-2013, 12:38 PM   #159
obijuan
Nice!
Old 09-04-2013, 11:56 AM   #160
jgammill
Got the doubler all back together with another factory resplined shaft from Jed's. That's the only way to get another shaft and he had to make it for me. I should be good cause I really thing I must have shifted the wrong case iin first and that caused to much torque on the shaft. I won't do that again.
We decided to go to Clayton over the labor day weekend and had a pretty good time. To bad it was 108 degrees during the day! We had already decided that we would just be night wheeling anyways. Pulled in at midnight Friday, unloaded, set up camp, and went wheeling. We didn't pull back into camp until 7am. No breakage that night so we just hung out in the camper in the ac all day sleeping and bsing. Went back out Saturday evening about 6 and wheeled until 2 of the rigs in our group had major problem. One smashed the tranny pan and broke the shifter off the side of the case. The other one had a link mount rip off the frame and then on the way down his tcase took a ****. But I made it out without any carnage except for a few more dents in the old girl.
We only got a few pic all weekend and very little video since we were mainly night wheeling. Here's where I was starting in to try the ledge. Never had tried before cause I never thought it would fit.
I had to hit it at a hard angle to get the bumper to clear so I could get started up it.
Got most the way up without much issue.
Then when my belly bottomed out it allowed the rear end to slide to the passenger side, witch put the top of my bed corner right under the big rock behind me. No way to back out. So we figured to try and winch it and make it pivot back to clear the bed. I thought it was going to rip the whole bed side down but it came out alright. I'm just glade they put the tailgate down cause it would have ripped it down. Just a couple more dents.
Then on top of the mountain it got a little sideways. Picture doesn't do it justice.
Was able to drive out of it.
We had a good little group of rigs with us.
We definitely will not be going back during the heat of the summer like that again though. Ended up coming home a day soon since the other 2 guy were broke.
Old 09-13-2013, 05:59 PM   #161
Jwood70
Holy awesome rig man. You have done some great work and made a sweet truck.
2014 single cabF150- Daily. 35s, camper shell and lifted.
1979 Custom Deluxe- project
Jwood70 is offline   Reply With Quote
Old 01-17-2014, 03:35 PM   #162
jgammill
Haven't posted here in a while. Been wheeling it pretty regularly. I added a light bar to the top and had about 20 rigs come out to play at my place.
Then was asked to bring it to the river for a music video shoot.
Also took the girls and some of the band members for a ride up the river bank after it was over.
Then took it to a new place to try out. It was a little slimy but still had fun.
Hope to get started on building a rear bumper for it before long.
Old 01-17-2014, 03:50 PM   #163
johnnyclack
Looking good
Old 01-21-2014, 03:17 PM   #164
jgammill
Went out by my self yesterday to do some scouting for new spots to play. Decided to go down the creek that I've never tried before, but it has been really dry so I thought I would give it a try. Made it through the first two water holes no problem. Then I tried to skirt around the 3rd one and it sucked me in.
When it started sliding I turned into it and punched it cause I thought it was going to roll. The back tire was really light. Pulled out my 2 chains and tow strap and then hooked my winch to them. Probably 200 foot to the tree. started pulling and went about 2ft before I stopped to reposition my tire. The whole time the passenger side just kept getting deeper and deeper. Went to start winching again and the winch wouldn't work. Probably a good thing. It might have tipped over if I kept pulling the way I was.
Luckily my dad was close by and brought a tractor down. Hooked a chain to me and then hooked another chain to the top of my cage back to the chain going to the tractor, to keep me from rolling. Once we started pulling it leaned over and that chain got really tight. Probably saved my ass by hooking that extra chain up. Got it out without much issue.
Then had to go home and wash it.
Old 01-22-2014, 09:48 AM   #165
johnnyclack
Would have loved to have been there
Old 01-22-2014, 04:10 PM   #166
TheBlueBomber
TheBlueBomber's Avatar
I love how everytime someone goes to "scout" they end up getting stuck. I lost reverse when I got sucked into a hole a couple weeks ago. Had to wait 3 hours for my buddy to bring his jeep to pull me out... It was like an episode of David and Goliath...
Awesome build looks like a lot of fun.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-22-2014, 06:44 PM   #167
fun in dirt
fun in dirt's Avatar
Looks like you've got a great place to ride!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-10-2014, 01:03 PM   #168
jgammill
Had to do something about the glare I was getting on my windshield from my light bar. All the white tubing made it even worse. So, I built a little visor and it made a huge difference.
Old 02-10-2014, 01:51 PM   #169
johnnyclack
Once again A Sweet looking truck
Old 03-12-2014, 12:04 PM   #170
jgammill
Finally picked up a second set of doors so I could make some half doors, and they were even the same color.
All tacked together.
Ground down.
And done with the drivers door.
I also modified the hinges so they slide on and off, like jeep doors, for quick changes and not having to readjust the doors to latch every time I switch them back to the full doors.
I have the other door all welded up now I just need to grind it down and paint it and I'll be done with both of them. It really makes seeing out a lot better now. Didn't realize how small the window were until now!
Old 03-12-2014, 01:27 PM   #171
johnnyclack
What’s with the vice grips on the steering column
Love that alarm system looks to be %100 effective, ….. Runs on High test Alpo Hey' ?
Old 03-12-2014, 02:11 PM   #172
jgammill
Lol! She jumps in as soon as I open the door whether I'm going somewhere or not.
Your the second person to ask me about the vice grips. lol. I use them to hold the throttle cable when I need the motor reved up a little for using the air compressor. The throttle cable is just below the ac vent by the door, black knob. It cant keep the throttle in position on it's own because of the spring on the TBI unit.
Old 03-12-2014, 07:05 PM   #173
70stroker
70stroker's Avatar
Hey man I see your from oklahoma, are you planning on taking this up to the big meats run at disney next weekend
70stroker is offline   Reply With Quote
Old 03-13-2014, 12:18 PM   #174
JayB331
JayB331's Avatar
This might be my favorite truck of all time!
'67 K10 SWB
350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's
My Project
http://67-72chevytrucks.com/vboard/s...d.php?t=602684
JayB331 is offline   Reply With Quote
Old 03-13-2014, 02:38 PM   #175
ERASER5
ERASER5's Avatar
Oh! Light BAR. I only saw the head lights standing on the hood during the jam session. My bad.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
