Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-30-2014, 12:16 PM   #151
JJH Jimmy
JJH Jimmy's Avatar
Re: Project "It's a Jimmy Thing"
Wow it has been a while since i last updated, but i have been working on the jimmy between the normal spring chores like getting the bikes ready for summer!
I bought the body molding, laid it out and drilled all of the holes.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 05-30-2014, 12:22 PM   #152
JJH Jimmy
JJH Jimmy's Avatar
After spending so much time lining the doors up i decided to drill and dowel the hinges so it would be easy to put them back in the exact same spot. I just drilled two 1/8" holes in each hinge and pillar and inserted a small piece of 1/8" welding wire in the hole and welded it in.
1985 Chevy K20
1994 GMC Yukon
Old 05-30-2014, 12:34 PM   #153
JJH Jimmy
JJH Jimmy's Avatar
Luckily i have a place close to me that rents out a large blasting cabinet by the hour. So i took the day off of work and brought my fenders, doors, cowl and a box of misc. parts to blast.
I then dropped everything off at the painter and he epoxy primed it and is going to paint the inside of the fenders, inside of the doors and the jambs.
I also chemical stripped the hood. There was about 10 layers of paint on it and it took about the same number of applications of the stripper. I used to have a lot of fun with strippers this was definitely an exception.
1985 Chevy K20
1994 GMC Yukon
Old 05-30-2014, 12:39 PM   #154
JJH Jimmy
JJH Jimmy's Avatar
I guess next on the agenda is the assembly when i get my doors and fenders back from the painter so i used the Eastwood metal blackening kit on a bunch of bolts. I blast all of the heads of the bolts first and it works pretty good. I just wonder how long they will keep looking good after it is on the road?
1985 Chevy K20
1994 GMC Yukon
Old 05-30-2014, 01:06 PM   #155
jaros44sr
jaros44sr's Avatar
Nice idea on the hinge alignment studs. Nice progress, wish i could say the same for me.
I hit a black layer when i was stripping body panels, and it was a sumb!tch to get off....
Trim looks great on there
Great dirt bike!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-02-2014, 10:58 AM   #156
JJH Jimmy
JJH Jimmy's Avatar
Great dirt bike!
Thanks!
I knew that if i took the doors off without some means to get them back in the same spot i would be kicking myself.
I thought blasting was bad, but the chemical stripper is way worse! I was just afraid that i would warp the hood if i tried to mechanically strip the hood.
I originally was not going to put the trim back on so i welded up all of the holes but now i feel it would look naked without it.
I am going to try to ride my dirt bike more this summer. I used to race a couple GNCC's a year, but i would like to get in good enough shape to at least make the last one of the season in Crawfordsville IN. Got to have goals right?
1985 Chevy K20
1994 GMC Yukon
Old 07-03-2014, 12:02 PM   #157
JJH Jimmy
JJH Jimmy's Avatar
I don't have a lot of progress to report but i did manage to order my shocks and install them. I also rebuilt my vent windows but it was not that exciting so i didn't take any pictures.
I guess you could say my project is in paint prison. My painter has been swamped so i am still waiting for my doors and fenders to get the jams painted. There is no way i will have this thing done this summer any ways, but i am still planning on having it done in the spring.
1985 Chevy K20
1994 GMC Yukon
Old 07-03-2014, 12:17 PM   #158
JJH Jimmy
JJH Jimmy's Avatar
Since i have a little bit of down time from my Jimmy i decided to get out a future project that has been sitting in the weeds at my parents place for about a 20 years! I bought this 51 from my brother in-law when i was 16 and never really didn't anything to it. It supposedly ran when i bought it but never heard it with my own ears. I believe that it has a later model pressurized 235 in it with a 12V system. The plan for now is to get it home and see if i can get it running. I think it would be cool to beat around town in it like it sits until i get the Jimmy done.
When the Jimmy is done it will get stripped down and get independent front, and LS motor. Not sure if i want to make it nice or leave the patina.
1985 Chevy K20
1994 GMC Yukon
Old 07-03-2014, 12:19 PM   #159
JJH Jimmy
JJH Jimmy's Avatar
Here is my 51 after i gave it a bath!
1985 Chevy K20
1994 GMC Yukon
Old 07-03-2014, 01:23 PM   #160
briank
Nice, I like AD trucks. I use to have three burbs 48,49 , 52 and a 50 panel before I drifted over to 67-72 k5s and burbs. Id get it mechanically sound and drive it.
briank is offline   Reply With Quote
Old 09-02-2014, 01:15 PM   #161
JJH Jimmy
JJH Jimmy's Avatar
Finally i can update! My painter called and said he was ready for my jimmy. He wanted me to bring it by so he could touch up the A-pillar where i had the supports when it was on the rotisserie. Since he is only a few miles from me i drove it to his shop. I got some crazy looks driving this thing down the road. I can't believe how well it drives. It shifted and ran great. I guess my front end alignment with a tape measure worked out good and i just need to adjust the drag link a bit so the steering wheel will be straight.
1985 Chevy K20
1994 GMC Yukon
Old 09-02-2014, 01:19 PM   #162
JJH Jimmy
JJH Jimmy's Avatar
I also picked up my fenders and doors. They got the block sanded and primed along with the jambs painted. So i spent the weekend taping them off so i could put the Raptor Liner on the insides of the doors and fenders.
1985 Chevy K20
1994 GMC Yukon
Old 09-02-2014, 01:23 PM   #163
JJH Jimmy
JJH Jimmy's Avatar
Tape job.
1985 Chevy K20
1994 GMC Yukon
Old 09-02-2014, 01:26 PM   #164
JJH Jimmy
JJH Jimmy's Avatar
Raptor Liner application.
1985 Chevy K20
1994 GMC Yukon
Old 09-02-2014, 01:29 PM   #165
JJH Jimmy
JJH Jimmy's Avatar
Now it is time to put the doors and fenders on!
1985 Chevy K20
1994 GMC Yukon
Old 10-07-2014, 09:25 AM   #166
JJH Jimmy
JJH Jimmy's Avatar
Well it has been kind of slow going lately. But i did happen to get a windshield and install it. I read a lot of horror stories of installing it with the 72 trim so i watched the Precision video online. I tried it their way of starting at the top and working down but i could not get it to go in. It seem the gravity was working against me. On the second attempt i started at the bottom and work up and it was way easier. Any way here is a couple shots of it installed.
I am now out of things to do until i get it painted. I talked to my painter and he said it was going to be a couple more weeks until he can get it in. Oh well i just want it done before spring.
1985 Chevy K20
1994 GMC Yukon
Old 10-07-2014, 09:28 AM   #167
JJH Jimmy
JJH Jimmy's Avatar
A couple more shots.
1985 Chevy K20
1994 GMC Yukon
Old 10-07-2014, 09:45 AM   #168
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Going to be Awesome!
Tom Vogel is offline   Reply With Quote
Old 10-07-2014, 09:57 AM   #169
skorpioskorpio
I'm sure it's in here somewhere, but the reason for the raptor liner on the inside of the panels is for... ? It looks really cool, just not sure I understand the function.
skorpioskorpio is offline   Reply With Quote
Old 10-07-2014, 10:36 AM   #170
JJH Jimmy
JJH Jimmy's Avatar
Thank you! Can't wait to have it on the road.
No real function other than it looks cool and it gives, the little bit that you see with the hood up, a finished look. Besides i had a couple extra bottles laying around.
1985 Chevy K20
1994 GMC Yukon
Old 10-07-2014, 11:15 AM   #171
skorpioskorpio
It does look cool. I was just curious.
Old 10-08-2014, 01:36 PM   #172
richeilers
richeilers's Avatar
You should try some CLR on that '51 and see what you think......I guess you got it running?
Rich
1971 Blazer 2wd CST 454 http://67-72chevytrucks.com/vboard/s...d.php?t=641414
richeilers is offline   Reply With Quote
Old 10-09-2014, 08:17 AM   #173
JJH Jimmy
JJH Jimmy's Avatar
I think i will eventually and then clear it.
I did get it running and driving but i still need to do a few things before it is road worthy........
rewire the head lights and tail lights
install wood in the bed
install new fuel tank sender
install a set of craigslist tires
1985 Chevy K20
1994 GMC Yukon
Old 10-09-2014, 02:34 PM   #174
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
where did you get your windshield gasket from? and was there any fitment issues? thanks Matt,
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 10-09-2014, 06:04 PM   #175
JJH Jimmy
JJH Jimmy's Avatar
I got the gasket from GMC Pauls. It is a Precision brand and it fit good.
1985 Chevy K20
1994 GMC Yukon
