Old 01-30-2017, 02:16 PM   #151
ChuckLee
Re: 1970 C10 LWB "Blu"
3
(This build has inspired me....actually, I blame my emptying pocketbook on you too!)
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-30-2017, 05:02 PM   #152
NC_John
NC_John's Avatar
Originally Posted by ChuckLee View Post
3
LOL. I have enough bad influences on here myself. Its funny to find out I am one too.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-30-2017, 09:31 PM   #153
Jason7121
Jason7121's Avatar
Yes my neighbor has it setup independent from the pcm for ac fan control.
Jason7121 is offline   Reply With Quote
Old 03-16-2017, 02:47 PM   #154
NC_John
NC_John's Avatar
Not much progress on the build lately- mostly waiting for parts to come in. A few delays as my engine gets bumped at the shop for professional race team customers.
Block is nearly finished and ready to go. It got the works- it was hot tanked a few times to clean out the dexcool mess. Magnafluxed, sonic tested, bored and finish honed to piston size, align bored mains, cam journals align honed. Still need the front machined to fit the cam chain tensioner since they didn't come on truck engines (at least not on this LQ4). We're using all ARP fasteners.
1970 C-10 LWB "Blu"
Old 03-17-2017, 12:59 PM   #155
NC_John
NC_John's Avatar
Rotating assembly is forged Mahle pistons, forged callies crank and compstar rods. The short block is being set up to hold 1,000 hp all day long. Overkill for sure but will last forever pushing the planned 600 at the flywheel.
Intake is going to be a FAST 102 LSXRT truck intake (got a great deal on this shop mule) with most likely a Nick Williams throttle body.
The final balancing of the rotating assembly should be done by the end of next week. Then we're cc'ing the pistons so we can tell Advanced Induction what to finish mill the heads to. Then we'll check our valve clearance and get a cam grind figured out with comp cams. Should be around .640ish for lift.
None of this is happening fast but it should be worth the wait when its done.
1970 C-10 LWB "Blu"
Old 03-19-2017, 05:43 PM   #156
NC_John
NC_John's Avatar
I spent a few hours at the engine shop yesterday.
The crank got temporarily installed to cc the pistons. We were able to let the cylinder head shop know how much we wanted milled off to finish the heads to get our target static CR.
The reluctor wheel got installed (still needs to be welded on).
And I spent some time doing my rocker arm trunion upgrade (eliminates the factory needle bearings).
Before I left I also hung out a while and watched Rick do a balance on a rotating assembly. I knew the theory of it but haven't watched it being done before.
1970 C-10 LWB "Blu"
Old 03-19-2017, 05:53 PM   #157
GR8-68
GR8-68's Avatar
Thanks for sharing.. Some cool pics too
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-19-2017, 07:16 PM   #158
NC_John
NC_John's Avatar
My crank/rotating assembly got done this afternoon. My guy got it dialed in within 2 grams (1%, which is standard for most machine shops, would have been 17 grams). I'm going to run an ATI dampener as well so this thing ought to be smooooth.....
1970 C-10 LWB "Blu"
Old 03-19-2017, 07:17 PM   #159
NC_John
NC_John's Avatar
Thanks Larry. I wish I had your level of progress to report. I'm probably going to be on the sidelines this year.
1970 C-10 LWB "Blu"
Old 03-19-2017, 07:40 PM   #160
Bhelton
Bhelton's Avatar
Looks like a lot of progress
Bhelton is offline   Reply With Quote
Old 03-19-2017, 07:51 PM   #161
NC_John
NC_John's Avatar
Well...... the engine did get dropped off at the shop in late December. You might be done your new build before I see mine moving under its own power again!
1970 C-10 LWB "Blu"
Old 03-19-2017, 08:11 PM   #162
Bhelton
Bhelton's Avatar
lol I don't know about that
Old 03-19-2017, 08:31 PM   #163
ChuckLee
Sweet pics!
Old 03-20-2017, 08:53 PM   #164
NC_John
NC_John's Avatar
Sweet pics!
Hey man! I just posted on your thread- hadn't heard from you in a while!
1970 C-10 LWB "Blu"
Old 03-20-2017, 10:55 PM   #165
DeepOceanStepside
DeepOceanStepside's Avatar
Awesome build!! Your progress makes me want to dive into my project!
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 04-13-2017, 03:47 AM   #166
GR8-68
GR8-68's Avatar
How is "Blu's" heart transplant moving along ?
Larry
"Project 68"
paypal.me/ldgrant
Old 04-13-2017, 06:33 AM   #167
NC_John
NC_John's Avatar
Other than that sexy new damper (another gratuitous pic below) showing up yesterday, not much to report. I am hoping I can pick up my cylinder heads this week. Advanced Induction lost a board on one of their machines and since they use all F1 spec stuff the replacement had to come from the other side of the Atlantic. That's got them behind a couple weeks.
When I have the heads we are going to get them on my short block and see what my true valve clearance is going to be (put a dial indicator on the top of the valve and see where it makes contact with a piston at tdc). Then we give comp cams a call and see what they come up with for a cam. Looking for 1.5 hp/ci which should be around 600 at the crank. As long as the torque is strong too- should be with the displacement.
Then it's final assembly and back to the shop for initial start, break-in and tune on one of the shop dynos. I'll be happy if it's fired within the next two months.
1970 C-10 LWB "Blu"
Old 04-14-2017, 12:20 PM   #168
made2drag
made2drag's Avatar
cool build!
made2drag is offline   Reply With Quote
Old 04-15-2017, 07:35 AM   #169
NC_John
NC_John's Avatar
Originally Posted by made2drag View Post
cool build!
Thanks. I hope progress starts up again soon. All the waiting for parts and machine-work is killing me.
1970 C-10 LWB "Blu"
Old 04-21-2017, 03:25 PM   #170
NC_John
NC_John's Avatar
Heads are finally done. I had Advanced Induction in Concord, NC give them the works with their 232cc Full CNC Port package with oversize 2.055" intake valves. BTR valvesprings and ti retainers finish it off.
1970 C-10 LWB "Blu"
Old 04-22-2017, 12:15 AM   #171
ChuckLee
What's your head CC and your gasket thickness and compression ratio going to be?
Old 04-22-2017, 08:05 AM   #172
NC_John
NC_John's Avatar
62cc. Don't know which head gaskets we are using (may find out today) but static compression will be 11.2-11.5:1 so I can run pump gas. I don't want to have to worry about always finding "good gas" when I travel somewhere. That was always a hassle when I was traveling on my high compression hot-rod HD.
1970 C-10 LWB "Blu"
Old 04-22-2017, 02:59 PM   #173
NC_John
NC_John's Avatar
Head gaskets are going to be felpro pn 1161-R041. 0.0040 thick.
1970 C-10 LWB "Blu"
Old 04-22-2017, 03:05 PM   #174
NC_John
NC_John's Avatar
Got the heads to the engine shop this morning. One of the guys immediately grabbed them and we put them on the flow bench to test them. So now we've got another component of our cam figured out (max mechanical valve lift) based on the flowbench (airflow) results - just need to confirm it mechanically with the heads on the block. We are eyeing the cam used in a 24 hrs of Sebring roadrace engine build that has the characteristics we want.
Also split up the short-list between the shop and I for who is supplying what to finish it. I need to get a bunch more stuff but the start of final assembly is at least in view...... way, way off in the horizon anyway.
1970 C-10 LWB "Blu"
Old 04-22-2017, 03:14 PM   #175
NC_John
NC_John's Avatar
Thank you sir!
1970 C-10 LWB "Blu"
