Old 04-26-2020, 05:35 PM   #151
400/400
Re: Minnesota Daily Driver
Close up of the “little mud on the tires”.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 04-26-2020, 05:40 PM   #152
400/400
The dog enjoyed the ride too.
Old 04-27-2020, 03:10 PM   #153
LT7A
What a great rig. I like how you always tackle whatever goes wrong and update, upgrade, and fix it. Still looks really good.
Old 04-27-2020, 04:02 PM   #154
MTCK
MTCK's Avatar
Truck looks great! Time to drive her more with the cheap gas!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 04-27-2020, 06:09 PM   #155
400/400
Thanks!
Speaking of fixing...
Old 04-27-2020, 06:12 PM   #156
400/400
I noticed a bit of variable rear steer a couple years ago. Found the forward bushings on the rear springs were shot.
Old 04-27-2020, 06:16 PM   #157
400/400
ORD had the poly bushings and greasable bolts to make for a lasting repair.
Old 04-27-2020, 06:19 PM   #158
400/400
This year it was time for cab bushings. 5 of the 6 bolts came out with little fuss. Then the inevitable result of wrenching on a Minnesota truck.
Old 04-27-2020, 06:22 PM   #159
400/400
With some luck and skill, I was able to use the inverted drill press and some old fashioned machinists tools to drill out the 3 + inches of remaining bolt and retap it.
Old 04-27-2020, 06:24 PM   #160
400/400
I previously saw someone post this method of lifting the cab to get them in.
Worked quite well.
Old 04-27-2020, 06:26 PM   #161
400/400
Thanks. It’s definitely nice filling the tanks at $1 something a gallon.
Old 05-03-2020, 05:31 PM   #162
400/400
Finally installed my ORD HD front shackles. Luckily all the hardware cooperated. The frame side bushings were definitely shot.
Old 05-03-2020, 05:40 PM   #163
400/400
Thinking about changing up the front end again. I need a front receiver for my winch and want to make a jib pole. Easiest way to mount that I can figure is off the plow frame I took off.
I never liked how the frame pushed the factory bumper out. It never looked quite right. I’ve got an old piece of c-channel that happens to be the right width I’m looking at using for a bumper. I can also mount my receiver to it and some shackles.
Old 05-03-2020, 05:42 PM   #164
400/400
I made a mini jib pole for the rear. It comes in handy.
Old 05-03-2020, 05:45 PM   #165
MTCK
MTCK's Avatar
Bumper will look tough. I also hate how this vintage Meyer mount shoves the bumper out. My plow will actually contact the bumper if I’m pushing snow with it hard over. Might be worth checking clearance on that channel.
-Marcus
Project Plow Truck
Old 05-03-2020, 05:55 PM   #166
400/400
Good point. Mine had hit the bumper too at stock height based on the paint marks on the old bumper. I never had a problem with it after the 4” lift.
I’ll have to check the clearance. I could probably chamfer the bottom corners of the channel if needed.
Old 05-26-2020, 06:27 PM   #167
400/400
Bumper installed.
Old 05-26-2020, 06:28 PM   #168
400/400
With the winch.
Old 10-25-2020, 06:28 PM   #169
400/400
Not a lot new. Just been using as a second truck.
Decided to change up the steps.
Old 10-25-2020, 07:01 PM   #170
MTCK
MTCK's Avatar
Looks good do they bolt to the pinch weld or the frame?
-Marcus
Project Plow Truck
Old 10-25-2020, 07:30 PM   #171
400/400
They mount to the front cab mounts and by the rear spring hanger to the frame.
Good thing I took care of the body mounts earlier this year.
Old 03-18-2021, 06:47 PM   #172
400/400
Out of hibernation. 1st drive of the year.
Old 03-19-2021, 08:26 AM   #173
calvin78612
calvin78612's Avatar
What did you do with the old step bars ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 03-19-2021, 07:49 PM   #174
400/400
Got ‘em stored away. Have a couple more squares I could use them on.
They seems to multiply...
Old 03-23-2021, 02:00 PM   #175
LT7A
So funny, thought it was black until the last picture in the sun. Like it with a canopy on there.
I went back through your thread and realized that you initially got this truck just for the plow. And then with the work you and your dad put into it, it's turned into a really nice rig.
