Old 06-05-2016, 01:40 AM   #151
whitels1
whitels1's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
It looks good man I dig it! That was quite the endeavor, I think you did a good job!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-05-2016, 04:00 PM   #152
daddyjeep
daddyjeep's Avatar
Don't get used to the SB dually. I plan on going to single eventually. I have come to the realization that I won't be pulling the Jeep with my square in two days. I still have some work to do on the Jeep and there just isn't time. I won't be able to drive the truck to get any confidence in it. I feel like I failed, but I knew all along it would be a long shot to get it done.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-05-2016, 04:15 PM   #153
MTCK
MTCK's Avatar
I know how you feel. Keep the faith. I've postponed a couple driving trips because I haven't worked out the kinks in mine. They will be cool and useful when done, and hopefully reliable. I just try to avoid looking at duramax's on Craigslist!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-06-2016, 12:41 PM   #154
daddyjeep
daddyjeep's Avatar
I don't know if this will work or not, but here is a short video of the truck moving under it's own power. That is about all it is doing, but it is doing it. I am going to throw some plugs in it to see if that wakes it up a little. The plugs have quite a bit of burnt oil on them, so it looks like the rings have seen better days.
[IMG][/IMG]
04 1500 crew cab
Old 06-06-2016, 02:35 PM   #155
Woodyboat
Woodyboat's Avatar
IT'S ALIVE!! BWWWWWHHHHHHAHAAAAAAAAA
I know you must be feeling very good right now. I know I am on your behalf!
Woodyboat is offline   Reply With Quote
Old 06-06-2016, 02:46 PM   #156
daddyjeep
daddyjeep's Avatar
Thanks Woody. It is satisfying that it moves, but still disappointing that it won't be ready to pull the Jeep to the Jeep Festival on Wednesday. I gave it a valiant effort, but came up a little short.
04 1500 crew cab
Old 06-06-2016, 05:21 PM   #157
Woodyboat
Woodyboat's Avatar
I don't know about you, but I have a real problem trying to get things done in any given time frame. Deadlines, time crunches and such like really scramble my brain and virtually always lead to a comedy of errors (to quote Shakespeare) for me.
You can see from my user name that I am into wooden boats. I've been a member of the forum at Glen-L.com since the forum was founded and I was the moderator for about a decade over there. We have a get-together the third of weekend of every September at Nickajack Lake in East Tennessee. This is not a group of guys that have restored antique boats. Rather, it's a group of guys that have brand new built mahogany runabouts from the ground up using modern epoxies and modern drive trains combined with traditional woods. We end up with beautiful boats that have all the charm and appearance of classic water craft but can run with the best fiberglass boats on the water. So, my own boat has really given me absolute fits because, every time I try to work on it, I won't have this tool or that tool, maybe I need to order more epoxy and my supplier is out, or I have an allergic reaction to the stuff. I always try to use the September event to motivate myself and it always leads to disaster.
On the other hand, when I just forget about it and work a little on the boat as I get the chance, it just flows right along and I have no problems at all.
Somehow, I really think that you and I have a LOT in common.
Old 06-06-2016, 06:25 PM   #158
daddyjeep
daddyjeep's Avatar
Yes, Woody projects are all the same no matter what kind of project. Check out my Jeep build linked below. That thing got side tracked and snowballed for 4 years. No matter what the challenges are it is worth all the aggrevation and hard work in the end.
04 1500 crew cab
Old 06-15-2016, 09:38 PM   #159
daddyjeep
daddyjeep's Avatar
Well, the Square didn't make it to the Jeep Festival and the Jeep wouldn't run once I got it there. I think I burned up the computer in the Jeep.
This might be part of the reason the truck isn't running so good.
[IMG][/IMG]
04 1500 crew cab
Old 06-15-2016, 10:04 PM   #160
MTCK
MTCK's Avatar
Crap sorry to hear of your problems. That's a lot easier fix than a lot of potential problems at least!
-Marcus
Project Plow Truck
Old 06-16-2016, 12:37 PM   #161
daddyjeep
daddyjeep's Avatar
I'm not too sure about that Marcus. This isn't my first computer so I will not be just throwing in another replacement. I am either re-wiring to an OBD2 system instead of the OBD1 of spending a bunch of money on a MegaSquirt system. Breaking an axle would have been much easier to fix.
04 1500 crew cab
Old 06-16-2016, 12:56 PM   #162
MTCK
MTCK's Avatar
I meant the tune up your pickup needs, haha. Yeah frying computers is never good. I didn't have great luck with aftermarket EFI on my '77 but they have come a long way. Howell harness and computer work well in my crew cab. Not quite perfect but close.
-Marcus
Project Plow Truck
Old 06-16-2016, 01:36 PM   #163
daddyjeep
daddyjeep's Avatar
Sorry Marcus, I am more concerned with my Jeep issues at the moment so that is how I understood your message. I used to have Howell system in my Jeep before I swapped in the V8. I was real happy with how that worked, but then I wanted more power so I went V8. Anyway....back to the truck, hopefully I see instant improvement when I get the new plugs in. We'll see tonight.
04 1500 crew cab
Old 06-17-2016, 01:18 AM   #164
whitels1
whitels1's Avatar
I would think a 6.0 in the dually and a 5.3 in the jeep would fix all issues stated above
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-17-2016, 12:55 PM   #165
daddyjeep
daddyjeep's Avatar
I like the way you think.
04 1500 crew cab
Old 06-28-2016, 12:48 PM   #166
daddyjeep
daddyjeep's Avatar
Not a lot going on the the DaddyJeep shop lately. After the mad rush the last few months I guess I just needed a break. That, and my eye has been really screwed up lately so that has kept me from doing much of anything. I'm getting the eye taken out in July so that will put an end to that problem. My eye hasn't worked in almost 20 years so I won't miss it much. If I can talk the doctor into it I am going to get a new eye painted like an 8 ball.
I did put the new plugs in the truck and new wires. I found a couple of broken wires, so those cylinders were likely not firing at all. It idles and revs better, but I have not taken it out for a drive yet. I also got some Cherry Bomb turbo mufflers. I read that they are tuned so they don't have the drone that many turbo muffler have, and they were cheap. We will see how they sound when I can drag the truck to my buddies that has an exhaust bender.
04 1500 crew cab
Old 06-28-2016, 01:04 PM   #167
MTCK
MTCK's Avatar
I would think a 8.1 in the dually and a 6.0 in the jeep would fix all issues stated above
Fixed your recommendation, Dave
Sorry your eye causing problems. If the doc will go for your plan, that is a cool doc.
-Marcus
Project Plow Truck
Old 06-28-2016, 09:22 PM   #168
whitels1
whitels1's Avatar
Thanks man, dang key board!
So Daddy, if you are tired of working on that K30, ship it out here, Ill tune it up for you and install a shiny new 10 bolt front end and return it to you. The weight savings over that Dana 60 alone will get you a few more MPG
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-28-2016, 09:44 PM   #169
daddyjeep
daddyjeep's Avatar
Wow, that is very kind of you. Just sit on the front porch and wait for it to show up. You might want to pack a lunch though, it might take a couple days.
As luck would have it, I actually spent a little time in the shop tonight. I made the first filler piece to tie the new floor pan into the transmission tunnel.
[IMG][/IMG]
04 1500 crew cab
Old 06-28-2016, 10:14 PM   #170
whitels1
whitels1's Avatar
Right on man, glad your back at it! Looking good!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-29-2016, 10:40 PM   #171
daddyjeep
daddyjeep's Avatar
I finished up the filler for the floor tonight. At least I am making progress. I find it really satisfying forming metal with a hammer.
[IMG][/IMG]
04 1500 crew cab
Old 07-02-2016, 10:58 PM   #172
daddyjeep
daddyjeep's Avatar
Productive day today...passenger side doors and fender removed. Inner and outer front rocker panel removed and new ones welded in. Hopefully tomorrow I can get the rear rocker and cab corner done.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 07-02-2016, 11:12 PM   #173
tinydb84
tinydb84's Avatar
Nice work. Getting it done!
David
Instagram: myfabguy
Old 07-05-2016, 12:35 PM   #174
daddyjeep
daddyjeep's Avatar
Well, Sunday wasn't as productive as I hoped. I found some rust in the floor behind the B pillar so I had to cut that out and had to build my own inner rockers for the back. I have everything built and the rocker mostly modified so hopefully I can finish that part up pretty quickly and move on to the cab corner. When I pull the cab this winter I will have to address some more issues when the bottom is a little more accessible. I need to replace part of the center cab support and fill some holes to seal up the rockers better.
[IMG][/IMG]
[IMG][/IMG]
I didn't set foot in the shop yesterday. I left the house at 2:30 AM to head to Lake Erie to look for some walleye.
[IMG][/IMG]
The sunrise on the lake was pretty amazing.
04 1500 crew cab
Old 07-05-2016, 01:08 PM   #175
daddyjeep
daddyjeep's Avatar
We ended up finding 10 walleye. Not the best day on the water, but will make a few tasty meals.
[IMG][/IMG]
That's me in the orange, my dad, my brother, and my oldest son. Unfortunately my youngest son got sick and couldn't go.
04 1500 crew cab
