Old 04-20-2016, 05:54 PM   #151
donandal
Re: Plus Five
and the booster...
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 04-20-2016, 06:03 PM   #152
donandal
Re: Plus Five
the hydroboost has three ports. The yellow one I believe is the low pressure return to the reservoir.
The white and green are both high pressure I think, but not sure which is input and which is out put.
I think the high pressure output from the pump goes to one of these, then from the hydroboost to the steering rack, then back thru the cooler to the reservoir.
Does that sound right?
53 Chevy Pickup
Old 04-20-2016, 09:30 PM   #153
solidaxel
solidaxel's Avatar
Re: Plus Five
Here is my cheat sheet!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-20-2016, 11:38 PM   #154
solidaxel
solidaxel's Avatar
Re: Plus Five
Look for a 2003 power steering pump with three openings on the "can", 2 returns, if you have not looked at pumps, depending what front brackets you have
LS 3 4L70E
Old 04-21-2016, 01:13 AM   #155
Nut Case
Nut Case's Avatar
Thumbs up Re: Plus Five
Don, Where did the brake pedal assembly come from? I have the same cheat sheet. This a great build lots of good stuff to pirate. Thanks NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 04-21-2016, 06:35 AM   #156
donandal
Re: Plus Five
perfect,
that's what I've been looking for.
53 Chevy Pickup
Old 04-21-2016, 06:51 AM   #157
donandal
Re: Plus Five
The brake pedal bracket is from a Ford F150 pickup. I sawed if off flat on the back and made a new back plate with the correct center hole and bolt hole pattern. Then welded it up after mocking up the proper depth for pedal travel and steering column clearance.
You can see the weld in this picture.
There is a sheet metal U shaped channel welded to the firewall for strength. Then the brake assembly bolts just inside that.
53 Chevy Pickup
Old 04-21-2016, 11:29 AM   #158
ptc
ptc's Avatar
Re: Plus Five
I think it has been said many times.... PHENOMENAL!!!! = STUNNING Fabrication work here, thank you for sharing with us all.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-21-2016, 02:30 PM   #159
donandal
Re: Plus Five
Thanks,
I appreciate your comments.
A couple of questions for everyone.
With the corvette rack and pinion, Chevy hydroboost and late model power steering pump, what type of power steering fluid do I use?
Also, is there any bleeding of the power steering side of the hydroboost, or does it bleed itself?
What size cooler and what type of cooler? fin and tube or plate?
53 Chevy Pickup
Old 04-21-2016, 02:46 PM   #160
donandal
Re: Plus Five
I made the brackets for the brake light switch and mounted it.
I also started mounting the brake/power steering components.
The reservoir is a stock GM two hole remote mount that I added another return line fitting to. I just made a steel washer and punched a hole thru it with a prick punch that widened it out to 3/8 of an inch. The flange that it formed gave good purchase for solder and I soldered up the return tube to the reservoir. The tube bends down on the inside toward the bottom. Then I painted it black.
53 Chevy Pickup
Old 04-21-2016, 02:52 PM   #161
solidaxel
solidaxel's Avatar
Re: Plus Five
I am going to use Power steering fluid
I think it will bleed the same as a rack, at least I hope it will, jacked up front end slow turn left and right lock to lock with the engine running check and re fill
For the PS cooler I removed the cooler from the Tahoe I got everything from 2003
LS 3 4L70E
Old 04-21-2016, 02:58 PM   #162
solidaxel
solidaxel's Avatar
Re: Plus Five
What front alt and PS bracket are you using?
Which pump and reservoir did you use
I am having a clearance problem with my pump pulley and rack!
LS 3 4L70E
Old 04-21-2016, 02:59 PM   #163
donandal
Re: Plus Five
Isn't there the red stuff and also clear fluid too?
Is it all the same? Is it interchangeable?
53 Chevy Pickup
Old 04-21-2016, 03:04 PM   #164
donandal
Re: Plus Five
I used Kwik performance brackets. The pump is just a stock type GM pump.
It was recommended by Pace performance. I'm not sure it would have enough clearance for a pump that has a reservoir attached.
Alternator is just typical GM style.
53 Chevy Pickup
Old 04-21-2016, 07:03 PM   #165
donandal
Re: Plus Five
OK,
more questions,
My transmission ( 4l65E ) has two quick connect fittings that look something like this.
The radiator has two threaded ports on the side for the transmission cooler.
I think I would benefit with an additional cooler before fluid goes back to the transmission.
How much pressure is in these lines?
How do I connect to these transmission fittings?
What type of hose?
What type of cooler? How big?
I have no experience with this stuff, and there seems to be about a million fittings to choose from, of which I'm sure most would be wrong!
53 Chevy Pickup
Old 04-21-2016, 10:28 PM   #166
Advanced Design
Advanced Design's Avatar
Re: Plus Five
Originally Posted by donandal View Post
OK,
more questions,
What type of hose?
don,
I remove those fittings from the transmission and use pn 7304988 from Napa. It is the same for a Thm350 or 700r4. The 5/16 steel line connects to that fitting with a standard brake line nut double flared on the line. Routing is typically along the trans and engine forward to the radiator similar to OE.
While I have never measured pressure on this circuit, many transmission coolers connect with a barbed fitting and clamp to a rubber hose so the pressure isn't substantial.
Your radiator sounds like it has a transmission cooler in it. Typically those are sufficient for keeping the oil cool enough, though touching base with the radiator manufacturer for additional recommendations based on how you will use the truck wouldn't hurt.
Advanced Design is offline   Reply With Quote
Old 04-22-2016, 06:45 AM   #167
donandal
Re: Plus Five
Thanks,
I guess I need to verify my radiator fittings and see if the transmission came with any fittings then get out my Visa card.
53 Chevy Pickup
Old 04-22-2016, 11:35 AM   #168
ptc
ptc's Avatar
Re: Plus Five
My personal opinion would be keep the OEM GM "quik-connect" connectors and get OEM hoses to fit them. You may be able to locate a local hydraulic hose/pipe shop (Parker Hannifin) in your area and they will put fittings on your hoses or purchase it from them. You've done an incredible job on this truck to this point so dont skimp out on the mechanicals now....
As for an additional trans cooler, I would get it setup first with just the radiator cooler and see what kind of temps youre running. The GM recommended max trans temp is 275 std and 285 towing. If you are anywhere near those numbers you should look into added cooling. Most vehicles DONT need additional cooling.
Old 04-22-2016, 02:04 PM   #169
solidaxel
solidaxel's Avatar
Re: Plus Five
Thanks,
The Parker Store is my new best friend!
Fittings and hoses for fuel and oil, maybe even brake lines!
LS 3 4L70E
Old 04-22-2016, 03:26 PM   #170
II_Slow
II_Slow's Avatar
Re: Plus Five
Hardline and flare fittings would be best - bend your own. Just make sure you use all 45-degree flare stuff, or all 37-degree (AN) fittings and flaring tools. Personally, I wouldn't use the factory quick connects. That is primarily to make for fast and easy assembly at the factory. I'm ditching the quick connects instead of replacing them on my truck.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 04-22-2016, 03:56 PM   #171
Iplumb
Re: Plus Five
On our 700r4 I believe the case is tapped iron pipe size (IPS). We bought adapters, fittings and stainless braid along with 90s and adapters for the radiator - inverted flare for those if remember correctly. Summit cost was about $90 I think if that helps.
You can see them in this picture. They still need to be clamped in place.
Mike
Iplumb is offline   Reply With Quote
Old 04-22-2016, 06:26 PM   #172
BlueJeep
BlueJeep's Avatar
Re: Plus Five
Not sure what you have for a flaring tool but a Mastercool one will make the "flares" for the quick connects. That said I swapped mine out for inverted flare ones too.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-22-2016, 08:27 PM   #173
donandal
Re: Plus Five
Thanks everyone,
I don't have a lot of confidence in the quick connector fittings.
I think I'll go with a combination of -6 AN fittings and hose from the tranny to the frame and go with hard lines along the frame to the cooler in the radiator.
I can bend and flare some steel 3/8 tubing.
I need to see how much room I have if I want to add another cooler in the return line.
Which brings up another dumb question. Which line is inlet and out let on the transmission case?
Does it matter which is inlet/outlet on the radiator, top vs bottom?
53 Chevy Pickup
Old 04-22-2016, 08:43 PM   #174
BC Toy chest
BC Toy chest's Avatar
Re: Plus Five
Awesome work, keep the photos coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 04-22-2016, 11:13 PM   #175
Advanced Design
Re: Plus Five
Thanks everyone,
Donandal, I like your solution better than my recommendation. The top is the return line. Here is a good discussion on transmission coolers if you are interested. http://ls1tech.com/forums/automatic-...0e-f-body.html
