Old 03-27-2020, 11:53 PM   #151
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
and here's a pic of my Lincoln 140C this is a great machine, it's the Commercial version not the 140 you can get at Home Depot or Lowe's big difference
anyway I need to get a 20A circuit ranned in my garage, but I know it's me and not the welder responsible for the bird droppings, I shall improve
Gregski is offline   Reply With Quote
Old 03-27-2020, 11:55 PM   #152
Gregski
Post Whore
Gregski's Avatar
Oh Bee have
Old 03-28-2020, 08:51 AM   #153
8man
Very nice work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-28-2020, 11:01 AM   #154
Gregski
Post Whore
Gregski's Avatar
Originally Posted by 8man View Post
Very nice work.
Thank you so much, how you all holding up in Texas?
Old 03-28-2020, 01:10 PM   #155
8man
We're fine. Our county has 30 cases so far. Went shopping for food yesterday and it was eerily quiet on the roads for a college town, no school, both colleges are closed.
How about you all?
8man-aka Robert
Old 03-28-2020, 01:30 PM   #156
Gregski
Post Whore
Gregski's Avatar
How about you all?
When I went to Wendy's on Friday to get hamburgers for us for lunch I was surprised how normal the roads looked, same traffic as always, but again we're Californian's ie better than everybody else, ha ha
the line for the Wendy's drive through was very long though and their parking lot was not designed for such an event
my wife has to go in to work since as she puts it "their department feeds Amercian" LOL
Old 03-28-2020, 05:21 PM   #157
joedoh
joedoh's Avatar
nice work! I think that cutoff wheel was more of a surface groover by the time you were done
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-30-2020, 11:01 AM   #158
LT7A
Agreed. Looks like it would still be an effective exfoliator too.
Old 03-30-2020, 11:02 AM   #159
LT7A
Did you want to increase the strength at the shock mounts or change the geometry? Whatever the case, the final result looked good and clean. Where did you get the brackets?
Old 03-30-2020, 11:18 AM   #160
Gregski
Post Whore
Gregski's Avatar
The stock shocks mounted outside the frame rails and with the Second Gen Camaro rear end there was not enough room to run them in stock location as the they would hit the inside of the wheels, so I made my own brackets.
Old 03-30-2020, 01:43 PM   #161
8man
I have that same mig, got it from a buddy at Airgas. Seems to work well for me too.
8man-aka Robert
Old 03-30-2020, 01:48 PM   #162
Gregski
Post Whore
Gregski's Avatar
Awesome I got the demo floor model from Matheson for about 50% off with helmet, gloves, and a tank of gas, it's nice and heavy isn't it with proper metal guts not plastic shiet. Can you please tell me what your settings are for welding 1/8th thick square tubing for example, I just can't get it dialed in to give me that "concave" bead looking weld... UPDATE: one month later, figured it out, I just had to increase my wire speed by one notch from a 2 to a 3 setting! but at the time I kept twisting the wrong knob (ie the volts) like an idiot.
Old 03-30-2020, 01:53 PM   #163
8man
On 1/8" I'm running D at about 3, with .035 wire on thicker steel and on the sheet metal I'm on C at ~2.5 with .023 wire.
I keep fiddling with the settings trying to get a better feel for it, but I keep going back to these two.
8man-aka Robert
Old 03-30-2020, 01:54 PM   #164
8man
Oh, and I am by NO means a good welder, but I'm learning and I'm liking it.
8man-aka Robert
Old 03-30-2020, 02:08 PM   #165
Gregski
Post Whore
Gregski's Avatar
I can't thank you enough. Yeah I bought a demo unit from Matheson I think or some other small specialty outfit, and their unit actually has sharpie marks on 2 for wire speed and D for voltage! that with .025 wire works great on sheet metal.
Currently I think I am running only .030 wire on the 1/8th brackets cause I think that's all Home Depot had at 10pm one night when I ran out, ha ha.
Are you running on 120 volts? Do you have a 20 amp circuit? I keep tripping my 15 amp one LOL
Old 03-30-2020, 02:12 PM   #166
8man
Yes, running 110 V on a 20 amp circuit. When the welder is plugged in, the only thing on that circuit is the welder. That was the way I set up the shop.
8man-aka Robert
Old 04-01-2020, 12:15 AM   #167
LT7A
I see. I thought the parts that sandwiched the tubesteel were manufactured parts. Good work.
Old 04-01-2020, 12:21 AM   #168
Gregski
Post Whore
Gregski's Avatar
wow thanks bro, imagine if my welds looked as good as my fab work, ha ha
Old 04-03-2020, 09:17 PM   #169
Gregski
Post Whore
Gregski's Avatar
a while back I got that rollpan in the organic paint booth and gave it a coat of high end cheap primer, lol
Old 04-03-2020, 09:22 PM   #170
Gregski
Post Whore
Gregski's Avatar
it's held on with screws for now (pronouned: "ever") ha ha and I like it it's probably good for another 20 hp, what do you all think
I apologize for the bad pics with the shadows and all
Old 04-04-2020, 10:03 AM   #171
joedoh
joedoh's Avatar
I like it!
Old 04-06-2020, 02:51 PM   #172
Gregski
Post Whore
Gregski's Avatar
nothing to write home about, just liberated the 45 lbs horn from the "core support" in order to have more access to mounting yet another radiator and fabricating the lower radiator core support crossmember
Old 04-06-2020, 05:14 PM   #173
8man
I just removed one of those horns too. Couldn't get it to do anything and I needed the room anyway.
8man-aka Robert
Old 04-06-2020, 05:27 PM   #174
Gregski
Post Whore
Gregski's Avatar
Cool, did you use an engine hoist, or a scissor jack, ha ha? solid heavy little suckers aren't they?
Old 04-06-2020, 05:32 PM   #175
8man
Yeah, I feel a little guilty taking it to scrap. Feels like I'm cheating them.
8man-aka Robert
