Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-05-2017, 03:15 PM   #1751
Hart_Rod
Hart_Rod's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
Originally Posted by ajgriffin View Post
I love this Burb! Did you decide against using the wood grain in the interior or just haven't gotten around to installing it yet? I'd love to see pics of the interior all buttoned up
Still waiting on a few parts. Will probably be the end of the month....
Originally Posted by Advanced Design View Post
Gotta be the coolest Burb on the planet...
Thanks!
Originally Posted by 04ls1gto View Post
Much rather have your burb over the lambo or whatever that is
Thanks!
Originally Posted by kehstr View Post
x2
Thanks!
Originally Posted by 68SWB4x4 View Post
Man those truck taillights look GOOD
Thanks! Can't wait to get the rest of the trim on.
The tune is coming along nicely, hope to have that wrapped up by the end of the month also. I had a new driveshaft built with a slip-yoke, heavy duty carrier bearing and a double cardan joint. This should make all my driveline angles nearly perfect and hopefully no vibrations.....
There are two other things that I'm looking to upgrade:
1) I'm thinking about switching to a hydroboost setup for the brakes. My power steering pump is already setup for it, so it shouldn't be a hard conversion. Any thoughts on it? Any recommendations as far as a kit to purchase?
2) Driving this thing is a beast with the factory power steering box! I would like a quicker ratio box. Any suggestions or recommendations?
Hart_Rod is offline   Reply With Quote
Old 07-05-2017, 05:12 PM   #1752
knomadd
knomadd's Avatar
On the hydroboost, I'd recommend Hydratech as that's what I'm running on both my 71 C/10 and my 65 GTO.
Here's a link to their stuff. http://www.hydratechbraking.com/GM_67-72_CK.html
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-05-2017, 07:55 PM   #1753
gringoloco
A guy with a truck
gringoloco's Avatar
Red head steering. Zero complaints here. Nice, firm, tight, reduced ratio, and my pump stopped whining
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-05-2017, 10:44 PM   #1754
ajgriffin
ajgriffin's Avatar
I think Delmo uses ABS Powerbrake:
http://www.abspowerbrake.com/maincat...ameset024.html
Not sure how the price compares, but I think all of these options are rather pricey.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 07-06-2017, 08:53 AM   #1755
Hart_Rod
Hart_Rod's Avatar
Thanks for the link. Will check your build again.
Thanks. What ratio did you go with? I believe factory is 4.5? Where's the best place to purchase one?
Thanks. Will check it out.
Old 07-06-2017, 10:02 AM   #1756
gringoloco
A guy with a truck
gringoloco's Avatar
I ordered quick ratio directly from redhead--good service/fast shipping. If you're not in a huge rush, I'll have mine up for grabs soon-ish (dropmember going in). For hydro-boost, check out the Astro-van conversion captainfab offers, if you don't want to break the bank.
-Chris
Old 07-06-2017, 10:24 AM   #1757
Hart_Rod
Hart_Rod's Avatar
Define "soonish? Is the quickratio 4.0 or 3.5 LTL? I'll check Captainfabs setup.
Old 07-06-2017, 01:17 PM   #1758
gringoloco
A guy with a truck
gringoloco's Avatar
In the next few months I'll start teardown. 3.5 turns on the qr box
-Chris
Old 07-07-2017, 09:18 AM   #1759
Hart_Rod
Hart_Rod's Avatar
Does it feel "touchy" at speed?
Old 07-07-2017, 10:54 AM   #1760
gringoloco
A guy with a truck
gringoloco's Avatar
It's definitely not as relaxed as a stock box when highway cruising, but I wouldn't call it touchy or twitchy. I did run a flow reducer to slow it down some
-Chris
Old 07-10-2017, 09:13 AM   #1761
shearjs
shearjs's Avatar
Rob,
I used a hydroboost from a 2500 Silverado. The only problems I ran into was connecting an adjustable pushrod to the unit to attach to my pedal. Other than that, it was cheap and works great. I have a list of fittings I used laying around somewhere, if that would be beneficial at all.
shearjs is offline   Reply With Quote
Old 07-10-2017, 11:17 AM   #1762
Hart_Rod
Hart_Rod's Avatar
Originally Posted by shearjs View Post
Rob,
Sounds good!
Old 07-10-2017, 03:02 PM   #1763
shearjs
shearjs's Avatar
Rob,
Here are the fittings I used on my hydroboost setup. The power steering pump already had two return ports, so I didn't have to add a return or T the two return lines. I used 10' of Powerflex teflon -6 hose (RUS-632620).
Steering box fittings: RUS-640380 5/8-18 TO -6
RUS-648050 11/16-18 TO -6
PS Pump fittings: RUS-648060 16MMx1.5 to -6
Hydrooboost fittings: RUS-670531 16MMX1.5 MALE adapter to -6
RUS-670541 18MMx1.5 MALE adapter to -6
Pressure Hose ends: RUS-620421, Endura Hose end -6 90 degrees.
I just used rubber hose for my return lines, and the hydroboost and steering box both already had a hose barb fitting for the return lines. Hope this helps.
Old 07-11-2017, 12:36 AM   #1764
kehstr
kehstr's Avatar
I did mine with all factory off the shelf parts. I used a new hydroboost unit and lines from what I believe is for a 2000-2003 2500 chevy pickup. All I had to do was drill holes in the mounting plate to bolt in onto my truck and lengthen the pushrod by welding on the original rod on the end for the extra length. Then I just bent the lines to fit and lay nicely.
The holes that have a star pattern stamped into them are the holes that originally had the mounting studs in them, the others I drilled to mount it. I did have to modify the mounting plate slightly after this picture was taken, I had to cut it to clearance the column support mount, and cut it a little more to look better with that part cut out.
Make sure that when you measure the length of the pushrod, you have the brake pedal where you want it, and have the return spring in the end of the hydroboost. I had the brake pedal too high, and did not have the return spring on mine, and had to shorten mine from what you see in this picture.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 07-14-2017, 09:45 AM   #1765
Hart_Rod
Hart_Rod's Avatar
Rob,
Attachment 1669425
Attachment 1669426
Attachment 1669427
Attachment 1669428
Thanks guys!
Old 07-14-2017, 12:49 PM   #1766
knomadd
knomadd's Avatar
I've finally got all my pictures back up in my build thread if you're wanting to check it out.
-Duane
Old 07-20-2017, 10:06 AM   #1767
nastety92
Just wondering which driveshaft you used?
Thanks,
Nick
nastety92 is offline   Reply With Quote
Old 07-21-2017, 11:45 AM   #1768
Hart_Rod
Hart_Rod's Avatar
Thanks!
Thanks,
Nick
I had one custom built.
Old 07-21-2017, 01:41 PM   #1769
nastety92
Any way I could have the info where you got it done? How much it cost? And the length?
Thanks,
Nick
Old 07-24-2017, 12:59 PM   #1770
Hart_Rod
Hart_Rod's Avatar
Thanks,
Nick
I had it built at a local shop driveline shop. 71" total length, 40" from rear end to center of carrier bearing, 31" from center of carrier bearing to the transmission. $750 total (double cardan joint was extra $200).
R
Old 07-24-2017, 03:28 PM   #1771
nastety92
R
Thank you.
Old 07-25-2017, 08:57 AM   #1772
Hart_Rod
Hart_Rod's Avatar
Thank you.
No problem! I would check and see if you have someone local that can build you one. That way they can tell you how to measure everything to make sure you get exactly what you need. Also, I changed mine from the center hang bracket that had the light duty carrier bearing to bottom mounted bracket with a heavy duty carrier bearing. We also upsized the shaft diameter from 2" to 3" due to the amount of torque that my engine will put out. Let me know if you have any other questions.
Old 08-12-2017, 11:20 PM   #1773
72MARIO
72MARIO's Avatar
I am curious what caused you to need the new drive shaft specfically the double cardan joint. I have not been able to get my suburban perfect yet. I have a vibration under acceleration when hauling my camper. Pinion angles are 4up on the pinion and 4 down on the trans output
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-13-2017, 12:48 PM   #1774
Hart_Rod
Hart_Rod's Avatar
Are you running a 1 piece drive shaft?
Old 08-13-2017, 01:19 PM   #1775
72MARIO
72MARIO's Avatar
I have the original 2 piece cut down with the small light duty 2 bolt hanger bearing.
2005 TAHOE DD
