Old 05-23-2015, 05:08 PM   #1776
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Junction Block & Positive Battery Cable
then I visited this '73 where I thought I could score the radiator core support, it looked all shinny and black, I was guessing the truck was recently repaired in the front, but... only to remove every bolt but one, you guessed it the rusty one under the battery tray in the bottom lowest corner, that's when I realized that although all the metal is there, the lip in the corner is paper thin, the rust has already gotten to it, so I passed on it, although unscrewing all those 50 screws was hecka fun
I did walk away with this junction block, but Greg we didn't realize you needed one? Well I sorta drove the truck to work with the wiring harness loosened up from the firewall and I smelled plastic burning on the way home, and then I found out it was my old junction block melting on the ol' exhaust manifold
I also picked up a proper Positive Battery Cable ($2.50) with a RED terminal, I wich the entire cable was red, but I will settle for at least a red tip, that way if the wifey has to jump start me one day she won't cross the jumper cables
Gregski is offline   Reply With Quote
Old 05-23-2015, 05:12 PM   #1777
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so yeah, six parts how ever small they may be I only paid $10.05 and had a fun scavenger hunt at what I call the Adventure Theme Parking Lot
Old 05-23-2015, 05:30 PM   #1778
greg64
greg64's Avatar
Re: Restoring Rusty
Awh, sh1t, I didn't know you were looking for that clutch spring. I'm nearly certain I have one in my parts bin I could have shipped you.
I notice your battery cable is for a side terminal battery. I know GM used the side terminals a lot, but in my opinion, they're crap compared to a top terminal. When the corrosion starts on the side terminal, it's hidden by the wire and you're not aware of it. Not so with the top terminal, and the connection surface area seems larger too.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-23-2015, 05:40 PM   #1779
enaberif
Re: Restoring Rusty
Agreed on the terminals. I much prefer top post with marine clamps and then make my own 4g wiring.
enaberif is offline   Reply With Quote
Old 05-23-2015, 05:49 PM   #1780
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
My friend I hate those things with a passion, they get stripped, they are terrible for jumper cables, I hate them more than you. I may be thinking of a conversion to top terminals at some point, but I just bought that battery brand new and it don't have both and top terminals just the lame side ones.
Old 05-23-2015, 06:24 PM   #1781
greg64
greg64's Avatar
Re: Restoring Rusty
Bummer. I was thinking your new battery was side terminal only.
Greg
Old 05-23-2015, 06:48 PM   #1782
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
considerin' these ugly spark plug wire booties for my too close to the headers problem, saw this pic on Craigslist today - please don't let me do it, they are ugly as heck
Old 05-23-2015, 07:06 PM   #1783
Titomars
Titomars's Avatar
Re: Restoring Rusty
They may be ugly but they work. I run a set on my 454. Only need them for 2 wires but it looks dumb unless it's a complete set on the engine. Also they look a bit better if they are not that tan color. I went with black ones.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-23-2015, 08:45 PM   #1784
69heavychevy
69heavychevy's Avatar
Re: Restoring Rusty
Thanks for the pics Gregski, very clean install BTW
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 05-23-2015, 09:45 PM   #1785
albertgen
Re: Restoring Rusty
You sure did a good job, I wouldn't begin to know how to do all that! Al
albertgen is offline   Reply With Quote
Old 05-23-2015, 10:05 PM   #1786
rusty76
rusty76's Avatar
Re: Restoring Rusty
Congrats on the score. Now find me a core support as well. Good luck. Mines not only rusty but bent as well......
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-23-2015, 10:27 PM   #1787
SkinnyG
SkinnyG's Avatar
Re: Restoring Rusty
considerin' these ugly spark plug wire booties for my too close to the headers problem....
I have MSD plug wires and they are withstanding headers really well.
I buy those braided heat thingies individually, take the ring out of them, and use them as a "TIG Finger" for welding.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-23-2015, 11:40 PM   #1788
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
still staying with the '79 I decided to see if I can find a similar black ground wire like the loose one in my truck and see where it bolts up to
I found a similar wire so I unscrewed the loop end and cut the other end where it splices into the wiring harness so I can graft it in properly to my own, score
That 6 disconnect ground buss bar mounted to the E-Brake pedal bracket is 1978-91. 1973-1977 use a ring terminal direct to the sheet metal under the dash. The 78-91 part is nicer to deal with. Nice scores BTW.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-24-2015, 12:07 AM   #1789
enaberif
Re: Restoring Rusty
Yeah I grabbed one of those 6 disconnect ground bars myself but I discovered to use it requires a special type of connector to use with said bar.
Or maybe I just ned to use larger female spade terminals?
Old 05-24-2015, 01:30 AM   #1790
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
The 12004267 female Packard 56 singles look pretty but a quality disconnect terminal will work fine.
If you have the 12004267 plastic housing the Packard 56 Female terminals are easy to find.
Old 05-24-2015, 02:37 AM   #1791
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
For the battery side terminals, I used two brass side post adapters with the studs on the back, but I used the ones for the double-wire setup, so they are longer on the battery end. I screw it through the cable so it just dead-ends in the battery, to catch all the threads, then tighten a nut down onto the cable. The studs off the back side give me something to connect accessories to, as well as jumper cables. I should have a picture here somewhere.
Here it is. I cut the ring off that held the old clamp bolt captive. The yellow residue is from some 3M weatherstrip adhesive I used to glue a cap on it at one point. But you can see how the clamping bolt is not all the way down, there is a nut clamping the cable.
This is the part you want. Note the "LONG" in the description. That is because some GM side post setups had TWO cables on one clamp.
http://optimatrays.com/viewitem.php?type=accessory&id=5
Anyway, this way you engage *all* of the threads in the battery, and won't strip it, and those big hexes are a lot easier to deal with than the small ones.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-24-2015, 07:25 AM   #1792
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by jeremybadeker View Post
Are you sure that's a v8 tach and not for a 6?
not sure Jeremy but it does have a 4 Wheel Lock light on it (under the speedo) so I'm assuming it came off of a V8 truck since I don't think they had 6 cylinder 4x4s, please correct me if I'm wrong
Old 05-24-2015, 07:31 AM   #1793
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by motornut View Post
Maybe the black could be seat belts ?
Among everything else grounded they usually went down to one wire about a foot from the cluster plug in
Kinda late to reply to this one, and I believe we settled it that indeed it is ground, but just for foresuredness (lol) and Keith may correct me, I don't recon they had electronized the seat belts back in 1974 as I don't think they even made shoulder belts mandatory yet back then
the new gauge cluster circa 1979 does have a seat belt light under the tachometer
Old 05-24-2015, 01:12 PM   #1794
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Sunday Morning
to the tune by Maroon 5
Sunday morning, truck is calling
Spin some wrenches, scrape some skin
Clouds are shrouding us in moments unforgettable
You twist to fit the part that wont go in
But things just get so crazy, fixing rust gets hard to do
And I would gladly hit the road, get up and go if I could
That someday it would bring me back to you
That someday it would take me back to you
That may be all I need
In darkness, my truck is all I see
Come and test your skills with me
Driving slow on Sunday morning
And I never want to leave
Fingers trace your every outline
Paint your body with my hands
Back and forth we sway like branches in a storm
Change the weather (stripping), hold together where it bends
Come and test your skills with me...
Old 05-24-2015, 01:25 PM   #1795
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - 74 & 78 Printed Circuit Boards
today we hope to complete the 74 => 78 gauge cluster swap
below for high level comparison I included a picture of the old 74 printed circuit board (top pic) and below it a picture of the old 78 printed circuit board
the idea is to just give you an idear that they is different, we do not expect you to use these fotos to trace and compare the actual circuits
also this is what they look like to Superman ie if you could see through the blue housing this is what they look like facing you the way the gauges face you naturally, I find that when you turn the cluster over and are looking at the back side, things are super confusing because right is left and left is west, you git the idear
Old 05-24-2015, 02:52 PM   #1796
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Give me six hours to chop down a tree and I will spend the first four sharpening the axe.
~ Abraham Lincoln
and so we prepare and prepare for this cluster surgery, just tracing these boards on paper and making these drawings was a great exercise to acclamate to what lies ahead
I present to you the Anti Schematic Wiring Schematics
Pic 1 - 1974 gauge cluster with mechanical oil gauge absent tachometer
Pic 2 - 1978 gauge cluster with electronic oil gauge with tachometer
Old 05-24-2015, 03:28 PM   #1797
enaberif
Re: Restoring Rusty
My 74 is a Canadian truck with only lap belts and yes the ground for the harness is to the metal on the dash where the 6 prong bar goes later.
Old 05-24-2015, 03:40 PM   #1798
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thanks, so in '74 there is no 6 prong bar, that came later? I don't have one so I don't know if I am missing one or it never had it, thanks
Old 05-24-2015, 03:49 PM   #1799
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
took my time and removed and labeled every single wire from the gauge cluster connector plug
here they colorphabliclly
Light Green - Hi Beam Light Bulb
Gray - Five Cluster Illumination Lights
Black - Ameter
Black with White Stripe - Ameter
Pink - Positive Switched Ignition Power
Tan with Black Stripe - Brake Light Bulb
Tan - Fuel Gauge
Dark Green - Water Temp Gauge
Black - Ground for Water Temp, Cluster Lights, Fuel Gauge
Dark Blue - Right Turn Signal Light Bulb
Light Blue - Left Turn Signal Light Bulb
Dark Blue - will be Oil Pressure Gauge once installed
Old 05-24-2015, 04:26 PM   #1800
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Fuse Box
now we're playing with Power, no literally we're actually playing with... ah you get the joke
now Greg why in the world did you tear up this fuse box panel thing
two reasons:
1. We had to A. castrate the dangerous Ameter wire(s) and B. graft the new Electric Oil Pressure wire
2. I was curious how all this wiring works and what's behind the fuse box, because starring at wiring diagrams just gives me a headache
