#1826 |
VA72C10
![]() Join Date: Mar 2008
Re: "Rice Rocket'
sorry...need my adjustable timing light and don't have a fuel regulator...in the past I've gotten them fairly cheap from a parts' store (mr gasket) try ebay also...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1827 |
Grandpa in the rustmobile...
Re: "Rice Rocket'
Ordered a fuel regulator, curve kit for HEI, and an adj timing light from summit this AM
http://www.summitracing.com/parts/EQU-3555/ thats the light I got.. anyone wanan buy a nearly brand new timing light i got all the paperwork etc on it, used it probably 3 times just standard light make me a offer or a trade
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#1828 |
Re: "Rice Rocket'
I've seen this thread 100 times and never bothered to look at it. I didn't realize it was your thread!! When I have more time I'll read through it. BTW, Your Dad was right. C10s are waaay more fun than a Toyota!!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#1829 |
Re: "Rice Rocket'
Well, got the correct licence plate lamp bulb installed and cover installed.
Timing light adv came in the mail along with my fuel regulator im really hoping i can get it running/starting much better sometime in the near future. Im having all kinds of heck with the regulator, if the dang edelbrock pump wasnt so expensive id've went that route Anyway, took a pre asvab test last nite at the recruiters, I need to do some math/algebra practicing before I take the practice/real test again. Going to try to do the last picture (captnfabs) but without the soldering...(If I can find a stupid fitting that I need) Next tool im buying is a quality double flaring kit
#1830 |
Resident of Here
Re: "Rice Rocket'
Progress looks good! How hard was the ASVAB compared to say, the End of Grade tests?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#1831 |
Re: "Rice Rocket'
asvab made alot more sense..if that makes sense lol
probably easier and not as much BS trick questions etc
#1832 |
Resident of Here
Re: "Rice Rocket'
Sweet, I'm joining the ARMY, so it's nice to know...
#1833 |
Re: "Rice Rocket'
Have you taken the asvab yet? what did you make?
#1834 |
Re: "Rice Rocket'
Made a bracket for my regulator today, pix tonite if i remember, i wore rubber crocs on cement all day, bad idea lol
#1835 |
Resident of Here
Re: "Rice Rocket'
Lol no, I asked you how hard it was so I would know. I still have to lose 100lbs.
#1836 | |
Cruzin
Re: "Rice Rocket'
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#1837 |
Re: "Rice Rocket'
thirdstreettito- you should be able to at least take some pracitce tests at the recruiters or maybe take the real test? Have you went and talked with one yet? Just how big a boy are ye? I was barely big enough (scrawny)
Nate-I would've much prefered boots today I believe lol
#1838 |
Re: "Rice Rocket'
got reg.to carb plumbed (notpictured) in hard line, not sure about pump to reg. witha filter..might cheap temporarily and use rubber lol
#1839 |
Re: "Rice Rocket'
And i think i'll trim the top flat..no point in it going straight up
#1840 |
Re: "Rice Rocket'
And regulator will have line to carb comming out the top and going along the valve cover
#1841 |
Resident of Here
Re: "Rice Rocket'
John, I'm 315lbs and 6' 3.5". Everyone says I dont look it, but I'm also always clothed(lol). I have to lose 100lbs the online recruiter said, when I get some gas money I can make it to the real recruiter, he's 40mi away. I cant wait, I also have to pass the fitness test, I'm going to shoot for Army Ranger scores(they arent much higher), that way I make sure I pass with flying colors, instead of barely passing.
#1842 |
Re: "Rice Rocket'
I hear the far away lol
#1843 |
Resident of Here
Re: "Rice Rocket'
Yeah, you probably get worse mileage than me as well.
#1844 |
Re: "Rice Rocket'
About 11 im in the process of a tune up and fuel reuglation correction
MY RADIO DELETE PLATE CAME TODAY! SAME COLOR AND ALL COULDNT BEAT IF FOR $6 BUCKS! POLISHING THE PAINT NOW! Anyone know how to attach radio delete to a cut dash with out the clips? ![]()
#1845 |
![]() Join Date: Aug 2010
Re: "Rice Rocket'
On the radio delete plate, maybe JB weld? Or some other form of adhesive?
Wanted to say too, nice looking engine! Don't think I'd seen a pic of your engine before. I like the newer plastic cover on top of your air cleaner, cool idea! ![]()
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#1846 |
Re: "Rice Rocket'
plastic cover?...
It looked alot better before it was my 1st yours looks better actually. One day i'll pull it and reseal it etc repaint and make it/keep it nice its a dd so impossible to keep nice/clean offroading/dirt/gravel/fields etc I treid gorilla glue but got impatient..will have to try jb weld epoxy i started a thread in the big board so maybe someone posts with ideas pix tom. after church just got back from gfs relatives homade drive in theatre in the STICKS hubscub you think im in the sticks...they have a huge screen and speakers and NO ONE is aruond to hear/see it lol
#1847 | |
Cruzin
Re: "Rice Rocket'
#1848 |
Re: "Rice Rocket'
actually this was closer to manchester than my house..just further in the sticks, if that makes sense lol
#1849 |
Re: "Rice Rocket'
Got my pressure regulator installed tuned. Starts alot better idles alot better (before youd have to go WOT for 3 miles before it would stay running) idles MUCH better and starts alot faster. Now I gotta get the timing squared away...
I DO have pictures but I got a new phone and im still learning...and the camera had dead batteires earlier still thinking of how to mount radio delete and wondering why cigar lighter delete wont stay in the hole (hole too big or cigar lighter too small lol) Anyone measure their cigar lighter hole for me with some calipers and give me the measurements?
#1850 |
Re: "Rice Rocket'
john how is the spot and the trim coming?
