04-10-2019, 12:18 PM | #1901 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
These things always come apart easier than they go back together... it’s getting a full inspection, cleanup, and reseal before getting stabbed back in for the (hopefully) last time. Finding lots of little things wrong, so I’m glad I decided to tear into it. Fingers crossed for full function and no leaks
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-10-2019, 03:38 PM | #1902 |
Get it taken care of before it hits the road. Smart guy!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
04-12-2019, 03:11 PM | #1903 |
Still Learning
Awesome progress Chris! digging the stick shift!
04-12-2019, 05:12 PM | #1904 |
A guy with a truck
Well, I don’t know if I’m smart so much as I hate leaks. Prolly should have chosen a different trans for that, as I’m learning that marking territory is part of the Muncie charm, but I’m doing everything I can to make it as dry as possible. Maybe someday I’ll grab a t56 or TKO cheap...
Thanks a lot, I’m just ready to get it stabbed and get to rowin’ gears On that note, it’s back together with no major parts still laying on the bench, seems to be functioning properly, and is almost ready to stab. Need to torque a new front bearing nut and plumb the hydro throwout first...
04-14-2019, 07:37 PM | #1905 |
A guy with a truck
Got the hydro slave all setup and plumbed, then stabbed the tranny back in for the (fingers-crossed) last time. Once it was in place, I got to assembling the entirely too complicated Hurst shift linkages. I am happy to report that it all seems to be working properly and that the throw is actually nice and compact, despite the extra-long shift lever.
04-14-2019, 08:01 PM | #1906 |
A guy with a truck
...and fabbed up a mounting bracket for a modified set of ICT Billet coil relocators to bolt to the back of the cylinder heads. These are designed to stack the coils in a row; I rearranged them to suit my needs and to fit the space I have available. Mounted them back where a distributor would be to maintain the small-block ruse
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-14-2019 at 08:33 PM. |
04-14-2019, 08:10 PM | #1907 |
Holy crap that is awesome
04-15-2019, 12:02 AM | #1908 |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-15-2019, 12:19 AM | #1909 |
A guy with a truck
Thanks dudes! We won’t talk about how many different ways I flipped the coils and brackets around before settling on this setup that just barely fits, but fit it does...
04-15-2019, 08:44 PM | #1910 |
It Is What It Is
The end result is all that matters, my friend! Everything that you are doing is spot on!
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
04-15-2019, 11:54 PM | #1911 | |
A guy with a truck
Still chipping away as I poked a couple of 9/16” holes in my nice, shiny valve covers tonight for the PCV system. More to come on this as I finish up with all of the plumbing hopefully tomorrow. The -6an bulkhead elbow fittings are on the back side of the valve covers, near the firewall where it is starting to get a little crowded. What’s that saying about putting 10 lbs of something in a 5 lb sack?
04-16-2019, 02:56 PM | #1912 |
Stellar man. Looks great! good work.
And thanks for taking that bed off, I was worried at first. 3 hours later page 77 all is great
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
04-16-2019, 03:07 PM | #1913 | |
Complete awesomeness.
04-17-2019, 01:40 AM | #1914 | ||
A guy with a truck
As for the hydro TOB, it is a Ram 78125HD, which reviews well, is rebuildable, and looks and feels like a quality unit. It setup nice and easy using all but one of the provided shims, though I did have to extend the locating pin. No real pictures of it at this point as it is tucked away safely inside the bell housing. Will update here once it’s all bled and (hopefully) functioning properly.
04-17-2019, 12:59 PM | #1915 |
Nice work on the coils. I had that idea floating around in my head but thought it would be too difficult and time consuming, so I moved on. Looks like it worked out great! Maybe I should rethink this...
Do you have some sort of baffle on the valve cover fittings to keep oil from coming out through those fittings?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
04-17-2019, 08:49 PM | #1916 | |
A guy with a truck
As for the PCV fittings, yes, the “dirty” side will be baffled, using vacuum hose connected to the internal valvecover baffle (pictures of this coming soon). The “clean” side shouldn’t need to be baffled, as it will only be providing fresh air into the crankcase. I also decided to use Earl’s stat-o-seals (rubber o-ringed crush washers) on the fittings to help quell any oil leaks at the bulkhead pass-through.
04-18-2019, 06:30 PM | #1917 |
A guy with a truck
Special delivery today, couldn’t help but to go ahead and install the “easy” stuff:
04-18-2019, 09:15 PM | #1918 |
It Is What It Is
Wow!
04-18-2019, 09:35 PM | #1919 | |
A guy with a truck
-6an bulkhead elbow with 3/8” barb adapters on both ends, then drilled/tapped the valve cover baffle for a 1/8” npt x 3/8” barb elbow, and connected them with a piece of 3/8” silicone hose held on with oetiker clamps. Pretty simple setup that I hope keeps the oil out of the PCV, if not it will just help keep the spark plugs lubricated
04-18-2019, 10:47 PM | #1920 | |
I like how the coils turned out. You have so much room with that intake, lol, it looks like a dream to work on compared to mine.
04-18-2019, 11:42 PM | #1921 |
Awesome work!!!
You've got a lot to be proud of!!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
04-19-2019, 12:51 PM | #1922 | |
04-19-2019, 08:08 PM | #1923 | |
A guy with a truck
Good point on the clean side, I may reassess Thanks a lot, I’ll just be happy to get it running Yes, it tucks inside the valvecover completely, which is all well above the rockers on the LS. This would not work on an SBC at all
04-22-2019, 12:42 AM | #1924 |
A guy with a truck
What I’ve been up to the last few days:
Tore down the original 3-on-the-tree steering column to gut all of the unused everything and take 8.25” of length out of it. This will help put the upper steering joint closer to the firewall, hopefully keeping my angles the way I want them and also clearing everything with the steering shaft. Ended up deciding to cut my own DD into the end of the shaft as opposed to taking it to a machine shop. Measure twice, cut once, used an angle grinder and finished it off with a set of calipers and a file. Not too bad to do, just a little time consuming. Actually was a little therapeutic (and a little stressful). I will say if you attempt this, do not use the ididit instructions, as their measurements are way off (or I was just to dumb to figure them out)... Also used a slick little piece from CPP, the “column saver”, which slips into the end of the column and has a bushing and thrust bearings for the shaft to ride on. Made figuring out how to terminate the hacked-off column a no-brainer.
04-22-2019, 01:56 AM | #1925 |
I can relate to your "therapeutic" comment on that kind of work. It's nice to step outside of your day to day thoughts and saturate yourself into something that 99% of people will never even think twice about. My problem is I tend to do this on almost every task I undertake when it comes to my truck project. I admire some of these guys who just knock it out and move onto the next step. Great work as always Chris,
