Old 07-21-2014, 07:51 PM   #1926
cubber
Re: 1968
lookin good George!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 07-21-2014, 09:56 PM   #1927
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by cubber View Post
lookin good George!
thanks man I still have a few things that I need to get though
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 07-21-2014, 10:00 PM   #1928
gdavis
gdavis's Avatar
Re: 1968
Today it was hot. I didn't go outside until later in the day. But, I did get the back up light back on the truck Now they look right. I also pulled the cowl to install the leaf guard. I hope to re-install the cowl tomorrow after I get the leaf guard in place.
Check out Patches
Old 07-23-2014, 12:32 AM   #1929
gdavis
gdavis's Avatar
Re: 1968
Today, I made my backing plates for the door hinges on the pass. side. I hope to install them tomorrow. First I have to go to the VA and get some copies of benefits for disability.
There's no telling how long that will take. Our Government at work. Don't get me wrong, we still have the best country in the world. But the red tape is a lot to be desired.
I made the plates out of 1/8 in x 4 x 4 in metal and drilled the holes in the right place. The holes are oblong so I will have room to adjust the door.
Check out Patches
Old 07-24-2014, 12:38 AM   #1930
gdavis
gdavis's Avatar
Re: 1968
today I had to do some work on the homestead. But was thinking on the bolts for the hinge. I think they will be a might short after I put the plate in behind the hinge. So I will have to get some about 1/4 to 1/2 inch longer. Maybe tomorrow I will go the Ace and pick up 6 longer bolts.
Check out Patches
Old 07-25-2014, 12:48 AM   #1931
gdavis
gdavis's Avatar
Re: 1968
Tonight, I sat out side in the yard swing looking at the back of my truck. It is lower in the right side about 2 inches. I guess I better find out what the problem is. Maybe a tire is low or a lose bolt. anyway I will get a better look tomorrow.
Check out Patches
Old 07-25-2014, 05:31 AM   #1932
swamp rat
swamp rat's Avatar
Re: 1968
Or a low spot on the grass, don't get all worked up about it unless you see it on flat pavement and its still doing it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-25-2014, 01:46 PM   #1933
Xeen
Xeen's Avatar
Re: 1968
If you are using the original springs it is definitely possible that one of them is sagging but it is just as likely there is a low spot in the dirt.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-25-2014, 07:53 PM   #1934
Mustard72
Mustard72's Avatar
Re: 1968
Maybe try sitting sideways on the swing and then look at it.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 07-26-2014, 12:54 AM   #1935
gdavis
gdavis's Avatar
Re: 1968
swamp rat you might have something there.
Bryan I am using the 72 springs and they looked and measure the same when I installed them.
And my buddy Nick. I can always count on you to come up with a solution.
Check out Patches
Old 07-27-2014, 10:41 PM   #1936
gdavis
gdavis's Avatar
Re: 1968
every one went camping this week in. So we watched the grand kids. Too much for this old couple to go.
Check out Patches
Old 07-29-2014, 01:09 AM   #1937
gdavis
gdavis's Avatar
Re: 1968
I finally dropped everything and picked up the longer bolts for the door plates. Tomorrow
I will try and attack the pass side door plates.
Check out Patches
Old 07-30-2014, 12:55 AM   #1938
gdavis
gdavis's Avatar
Re: 1968
Went and ordered my new sun visors today. They will be black and orange. The orange will be a strip in the center and black on top and bottom. I will post pictures of them when he finishes them. They cost less than new after market ones.
Check out Patches
Old 07-30-2014, 07:43 AM   #1939
colgad
colgad's Avatar
Re: 1968
Sounds like I should have had your guy do my door panels!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-30-2014, 11:29 PM   #1940
gdavis
gdavis's Avatar
Re: 1968
He's the one that I had do my seat. I will also have him do my door panels.
He takes the visors apart and puts in new board and new chrome clip if it needs them.
They are going to have the Harley Davidson colors the same as my seat.
I am really pleased with his work. He does quality no quantity.
Check out Patches
Old 08-01-2014, 09:28 PM   #1941
gdavis
gdavis's Avatar
Re: 1968
Well, Today I finished the pass side door hinges. I mounted 1/8 in plate behind the hinges top and bottom. Now when the door closes it looks even. Not like before it had a 1/2 inch gap on the back side of the door. Now , created another problem. One of the bolts on the top hinge stripped out and I had a heck of a time getting it out. I can't weld a nut in behind the bolt for I can't see to go in close quarters. I was thinking if I could jump up a bolt size in metric like I did on the other hinge bolts. Anyway that will be tomorrow's work or job.
I also made (4) ground straps for the cab and bed. I thought about putting two on each.
I picked up 8 eyelets with 1/4 in hole in the eyelet and 4 feet of wire. I crimped and soldered the wire to the eyelet and put shrink wrapped over the wire after I finished the straps. it looked good. Now if it holds up. only time will tell.
I still have to adjust the fender on the pass side just a little. That will close the gap on the front of the door a little.
Check out Patches
Old 08-01-2014, 09:57 PM   #1942
Xeen
Xeen's Avatar
Re: 1968
The gaps look better George.
Nice job on the ground straps.
Old 08-02-2014, 06:32 PM   #1943
gdavis
gdavis's Avatar
Re: 1968
Today I made a set of door handle gaskets, out of a inter tube from a lawn mower tire. Don't laugh it worked. So I installed the door handle and the door panel and the inside door handles. In the picture you can see the backing plates. I made for the hinges. I couldn't jump up a bolt size for the hinge. It is hard to tap a square or oval hole, so I just put a locking nut on the back side of the bolt in the hinge. Now the hinge works nice and flat.
I also finished the grounding straps. I ran out of gas for my small torch. So got a small bottle from local Ace hardware. Back in business again. Then I installed the grounding straps one on each side of the cab. I was going to mount two for the bed But, the bed will be bolted to the frame and that fixes that.
Check out Patches
Old 08-02-2014, 06:36 PM   #1944
gdavis
gdavis's Avatar
Re: 1968
I made too many straps. But what the hay, it don't matter. it was only some time spent. I will put them on the parts board maybe someone will need them.
Check out Patches
Old 08-02-2014, 11:55 PM   #1945
gdavis
gdavis's Avatar
Re: 1968
thanks Bryan. Getting a little of the stuff done that holding me back. not really holding me back. Money is the issue.
Check out Patches
Old 08-05-2014, 01:50 AM   #1946
gdavis
gdavis's Avatar
Re: 1968
I couldn't get anything done on the old girl today. For a number of reasons
1 too hot
2 motivation
3 friend came over and he bought him a 1957 Buick special. He wanted me to see it on line so now he will start fixing it up.
Check out Patches
Old 08-06-2014, 12:44 AM   #1947
gdavis
gdavis's Avatar
Re: 1968
I hope everyone had a glorious week inn
Check out Patches
Old 08-07-2014, 07:44 PM   #1948
cubber
Re: 1968
Glad to see you're still workin on ol' Patches, George!
=MATTHEW
Old 08-07-2014, 11:40 PM   #1949
gdavis
gdavis's Avatar
Re: 1968
yea, I have done a little. I will be ordering a rear bumper from a fellow board member Monday
I also will order a set of bumper braces. Then I can install my bumper I will be glad when it is on the truck. A bumper make the truck look road ready
Check out Patches
Old 08-10-2014, 03:52 PM   #1950
gdavis
gdavis's Avatar
Re: 1968
Gods not dead (watch the movie)
Check out Patches
