Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-25-2008, 03:05 AM   #176
Rust Buster
Rust Buster's Avatar
Re: 72 K20 build thread, need good name
Richard,
We do need to check out each other's projects, I'm just tied up straight, since I'm in source selection at work.
I normally use a cutoff wheel on my electric grinder, but I also have a Bosch sheer for curves. Unfortunately my plasma cutter is still in MA...
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 04-25-2008, 03:23 AM   #177
RICHARD MORGAN
You did a nice job!
I’m actually buying a plasma cutter this week, your more than welcome to borrow it. I'll be working on my truck this weekend, swing by if you get the chance.
Richard
RICHARD MORGAN is offline   Reply With Quote
Old 05-08-2008, 08:59 AM   #178
JJ
Lurking Member
Two things I was wondering about, Did you bend your own fuel lines? And were you able to use the stock emergency brake linkage with the rear discs?
I am completely impressed by what you've posted so far, keep up the great work, and please keep posting the pictures.
JJ
72 GMC 1500 350 4 Speed, stone stock baby!!!!!
72 GMC K-2500 350TPI 700R4
For those who fought for it, Freedom has a flavor the protected will never know.
JJ is offline   Reply With Quote
Old 05-08-2008, 03:36 PM   #179
Rust Buster
JJ,
I haven't done any fuel lines yet, but will be using Aeroquip's socketless hose. I've used it in the past and it is great and eliminates the need for bending. Haven't gotten to the e-brake yet either, but I will let you know what I end up using.
Thanks for the compliments!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 06-11-2008, 01:25 AM   #180
JJ
Lurking Member
I have checked back several times, after showing the build to just about everyone that stops by and even cares about what I'm building. I'm wondering if you've gotten any further on the fuel lines? Can you tell me where I can find information on the product you're going to use?
Again, keep up the good work. For the record, the people I've showed your build were duly impressed.
JJ
Old 06-11-2008, 08:24 PM   #181
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
the fuel lines he is using i looked up and found in summit racing
72blazer_mud_bogger is offline   Reply With Quote
Old 06-12-2008, 11:21 PM   #182
Rust Buster
JJ, mud bogger is right, they are aeroquip socketless hose that you can get from Summit and probably Jegs. I used it before when I converted the truck to TBI and really liked it. It definitely beats bending steel tubing. I haven't gotten to putting the fuel system back together yet, but when I do I will post plenty of pics. Thanks for the compliments!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 06-13-2008, 08:39 PM   #183
72blazer_mud_bogger
rust buster do you know how to run a gravity line
Old 06-13-2008, 10:35 PM   #184
Rust Buster
What do you mean by that? Just a gravity fed fuel line?
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 06-14-2008, 02:08 PM   #185
72blazer_mud_bogger
i was talking to someone about taking my fuel tank off the bottom of my blazer and running to full size kegs, and they told me it would just be easier to run gravity lines from them, i don't know what that is. i was just thinking about swapping my manual fuel pump to an electric fuel pump and just run seperate lines to each keg they set it up with a switch to change the tanks back and forth, for those long days in the woods or camping in the mountains. but i still dont know what a gravity line is???????????
Old 06-14-2008, 02:57 PM   #186
watahyahknow
watahyahknow's Avatar
i think they mean running lines from under the tank so its allways fed (disconnect the lines and the tank empties )
normally they run the lines from the top to the bottom
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-10-2008, 02:07 PM   #187
msgross
msgross's Avatar
any updates?
nice meeting you at Carlisle, keep in touch...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-10-2008, 04:02 PM   #188
Rust Buster
Mike, good to finally meet you at Carlisle! I can't believe I haven't updated the build in so long. Partly due to the garage being so damn hot, and also because progress has been really slow aligning panels and getting everything ready for the final body work.
I'm on my third 67-68 hood trying to get one that lines up well with my fenders. Seems like every panel for these trucks has their unique shapes, and they all fit differently. I finally started to fix the problem with my hood not meeting the GMC top grille bar nice and flat. I welded on some angle iron to the bottom of the hood to ensure that it was flat and now I need to shape the rest to of it to match the contour of the hood and bar.
One more weekend of that kind of work, then I should be able to start the filler work. I can't wait for fall and the cooler weather! Threw the toolbox in there becuase I wasn't sure if I had done so before.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-10-2008, 04:04 PM   #189
Rust Buster
Hood work
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-10-2008, 08:36 PM   #190
72blazer_mud_bogger
how do you keep your alt from touching the valve cover. did you clock the alt. or what any help would be great
Old 08-10-2008, 09:18 PM   #191
Rust Buster
I didn't have to do anything, there is not interference between the alternator and the valve cover. I used a late model SBC serpentine system and had no problems with clearance.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-10-2008, 10:47 PM   #192
72blazer_mud_bogger
then can you take some closer pics of the mount and alt and around the valve cover
Old 08-17-2008, 11:40 AM   #193
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Rust buster, that thing is looking sharp, Keep up the good work.
I am going to be diving into mine like that in the next couple of months. Crazyness!
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 08-17-2008, 11:44 AM   #194
msgross
msgross's Avatar
How did you like the HVLP system? I'm waiting for you to sell yours so hurry up and paint!
The Garage:
Old 08-17-2008, 03:29 PM   #195
Rust Buster
72blazer_mud_bogger,
I should have those pics tonight, sorry for the delay.
Mike,
I do like it, still tweaking the settings on the gun, but bought a few different needle sizes, and that has helped. With all that money you collected selling at Carlisle, just go buy one, you'll use it for the rest of your life!!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-17-2008, 04:02 PM   #196
Rust Buster
It's close and may need some modification, but I can make it work
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-17-2008, 05:46 PM   #197
msgross
msgross's Avatar
I came home with a dollar after I bought all new sheetmetal!
But my new bed, floors and fenders looks nice.
You used expoxy primer after you had it blasted right?
The Garage:
Old 08-18-2008, 09:31 PM   #198
Rust Buster
yes, I used the Southern Polyurethanes, great stuff!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 08-18-2008, 10:21 PM   #199
67_C-30
I have a radical idea!
67_C-30's Avatar
If you still need a name, how about Butt Nasty! - This is one awesome build! You guys are going to make me buy a 4X4!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-18-2008, 10:24 PM   #200
MrBeast
high-Tech Red Neck
MrBeast's Avatar
You could always convert your dually.... I am just sayin... dont want mine to be the only one in the 4x4 club....
