Old 07-10-2009, 10:52 PM   #176
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: my 80 build
What's the story on the "farm truck"?
heavychevy79 is offline   Reply With Quote
Old 07-10-2009, 11:13 PM   #177
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
its a 79 gmc 3/4 that I building for a friend but he passed away before I finished it now it his sons, here's the build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=314342
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-17-2009, 06:01 PM   #178
daves69
Re: my 80 build
Where did you get that headliner? Was it generic or custom?
81 Blazer
69 C-10
daves69 is offline   Reply With Quote
Old 07-17-2009, 07:46 PM   #179
flamingbig10
6.0 powered square
Re: my 80 build
I don't have a headliner
Aaron
Old 07-17-2009, 08:50 PM   #180
daves69
Re: my 80 build
Oh I meant to write hoodliner..
81 Blazer
69 C-10
Old 07-19-2009, 03:20 AM   #181
flamingbig10
6.0 powered square
Re: my 80 build
it's a cut to fit replacement from lmc
Aaron
Old 07-19-2009, 11:16 AM   #182
daves69
Re: my 80 build
thanks man.
81 Blazer
69 C-10
Old 07-19-2009, 02:13 PM   #183
mxriderae
Re: my 80 build
excellent work !!
mxriderae is offline   Reply With Quote
Old 07-20-2009, 10:30 PM   #184
flamingbig10
6.0 powered square
Re: my 80 build
thanks mx
some new car show pics
Aaron
Old 07-21-2009, 07:43 AM   #185
JohnC
JohnC's Avatar
Re: my 80 build
Congrats on another trophy man! They are just starting to pile up now!
JohnC is offline   Reply With Quote
Old 07-22-2009, 12:37 AM   #186
flamingbig10
6.0 powered square
Re: my 80 build
thanks john, maybe I'll bring another one home this weekend
Aaron
Old 07-22-2009, 12:46 AM   #187
flamingbig10
6.0 powered square
Re: my 80 build
I finally got fed up with my junky reman quadra jet one day it will run like a wild beast and it will start up easy with out pumping the gas the next day it will only start quick if i pump the gas and then I'll have to let it warm up for about a minute, when I drive it, it will spit, so I plan on putting a edle broc 1406 600cfm with electric choke
Aaron
Old 07-22-2009, 07:25 AM   #188
silvrbreez
silvrbreez's Avatar
Re: my 80 build
Sounds like a nice swap over. I'm running that carb on my high mileage, stock, unbuilt 350 and it starts up and runs like a champ. Does wonders for this old engine.
silvrbreez is offline   Reply With Quote
Old 07-22-2009, 07:38 AM   #189
JohnC
JohnC's Avatar
Re: my 80 build
Yeah that's the carb I'm going to run on my new engine. I've heard a lot of good things about it. I think you'll really enjoy the swap.
Old 07-22-2009, 03:26 PM   #190
flamingbig10
6.0 powered square
Re: my 80 build
went ahead and bought the carb today I think it will be a well spent $300 also wile I'm at I'm going add a new throttle cable
Aaron
Old 07-22-2009, 11:40 PM   #191
flamingbig10
6.0 powered square
Re: my 80 build
well got the old carb off, Tomorrow I'll install new carb if I can get new studs, fuel line that run off the carb to the fuel filter, and a heat spacer
Aaron
Old 07-23-2009, 12:15 AM   #192
menace121978
menace121978's Avatar
Re: my 80 build
good investment... you will def. be happy with it!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-24-2009, 12:27 AM   #193
flamingbig10
6.0 powered square
Re: my 80 build
well got the truck started, but I 'll to start over because I forgot to get a fitting to run the power brake vacuum hose, and the mounting studs I bought are to long
Aaron
Old 07-24-2009, 08:17 AM   #194
JohnC
JohnC's Avatar
Re: my 80 build
Keep us updated man. I'm sure you'll like the new carb.
Old 07-25-2009, 01:35 AM   #195
flamingbig10
6.0 powered square
Re: my 80 build
the new carb sure does look nice and sure start a lot easier , but I'll need to find a new throttle cable though because mines broke, hope I can find one before Tomorrow evening, car show
Aaron
Old 07-25-2009, 02:22 PM   #196
JohnC
JohnC's Avatar
Re: my 80 build
Are you making room for another trophy too?
Old 07-28-2009, 11:02 PM   #197
flamingbig10
6.0 powered square
Re: my 80 build
I was going to enter in the show but it didn't end after midnight and was afraid to drive that late with new carb, but I did drive the truck there and looked around for a couple of hours there was close to 200 cars
Aaron
Old 07-28-2009, 11:22 PM   #198
flamingbig10
6.0 powered square
Re: my 80 build
pics of the carb and I started on cleaning up the brake lines
Aaron
Old 07-29-2009, 12:19 AM   #199
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
nice how hard is it to take the carb off?
i gotta change my intake.
so carb
destrbiter
lines
if u now how?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-29-2009, 12:40 AM   #200
flamingbig10
6.0 powered square
Re: my 80 build
carb is simple to remove, unhook the fuel line, vacuum lines, cables, and the remove the 4 bolts or nuts and gently pull it off and wrap it up in a towel to keep the dirt out
Aaron
