Old 03-09-2010, 01:16 PM   #176
DPowers
DPowers's Avatar
Re: I wana drive 65.
70 Suburban- Are you out there somewhere?
DPowers is offline   Reply With Quote
Old 03-09-2010, 03:16 PM   #177
my67chevytruck
Under Construction
my67chevytruck's Avatar
any update? check your pm when you have a minute.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-12-2010, 02:52 AM   #178
Captainfab
60-66 Nut
How are you coming on this?
Old 03-12-2010, 11:20 AM   #179
DPowers
DPowers's Avatar
Not speaking for him at all- but I spoke with him the other night and sounds like his job is keeping him real busy right now.
Old 03-12-2010, 11:53 AM   #180
highperf4x4
Well he better get in here and show us some progress before we show up knocking on his door!!!!!!
highperf4x4 is offline   Reply With Quote
Old 03-13-2010, 03:06 AM   #181
Captainfab
60-66 Nut
Well that's a good thing in a lot of ways....good that he has a job.
Old 03-13-2010, 09:06 AM   #182
70 Suburban
Rods
well ill have to sum this up. its 6 am on a saturday.. i need sleep.. I have the engine in place. moved the engine mounts forward left the stock auto crossmember and drilled one hole for the trans mount. I did get the a/c in place but didnt like how big it was so i will not use it. i am goin to use the dash and the column and that is test fitted and i like it. i have a set of inner fenders in place and have test fitted the harness and ecms along with the brake booster. but i am still leaning to use captfabs because it will look cleaner. I am thinking about putting the stock air box in the battery box location and moving the battery to the frame rail and building a box for it to hide it.
I started to test fit the sway bar but still need to update the centerlink for my power steering.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
