Old 03-24-2010, 02:33 PM   #176
Dan Bowles
AD Addict
Re: 52 GMC Envoy Burb meld/build
Goody goody gumdrops, I like surprizes!!
Dan Bowles is offline   Reply With Quote
Old 03-24-2010, 02:47 PM   #177
BBEEP
Junior Member
BBEEP's Avatar
My grandma used to say that!
48 GMC Panel Sold 12-14-15
52 White/Chevrolet School Bus
52 GMC Burb/Envoy Meld
61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13
67 c/10 SOLD 2012
71 SS454
77 c/20 Sold 11-11-15
08 TBSS The Wife's car!!
50 GMC School Bus SOLD 11-7-10
29 F**D Delivery (Chevy powered) SOLD 11-4-11
53 GMC 630 Firetruck/Ramp Truck
BBEEP is offline   Reply With Quote
Old 03-24-2010, 03:11 PM   #178
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Suspense is killing me...
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 03-24-2010, 07:36 PM   #179
T Hilde
Just remember, on this build there is no such thing as too many pictures.
T Hilde is offline   Reply With Quote
Old 03-25-2010, 08:31 AM   #180
DARKASS04EXT
BBEEP... I first saw info about this build on TRAILVOY.COM. I believe you posted under "1952 ENVOY". I know members there would love to see some pics of the progress. Keep up the great work.
DARKASS04EXT is offline   Reply With Quote
Old 03-25-2010, 04:25 PM   #181
BBEEP
Junior Member
BBEEP's Avatar
O.K., so I tried widening the fenders 2 inches on by 52 Envoy/Burb and it didn't do the job. The tires still rub front and rear. I know I could radius those fenders, but I would like to try some 1-ton front fenders. Does anyone have a pair of GMC or Chevy truck fenders out there?
Also, does anyone know what the difference is between the Chevy and GMC fenders? My truck is a GMC and I will keep it that way regardless of what I find, just curious.
67 c/10 SOLD 2012
71 SS454
Old 03-25-2010, 04:38 PM   #182
BlueJeep
BlueJeep's Avatar
From what I've read, the difference between chevy and GMC fenders involves the running light, and some of the inner fender holes being different. That's nothing for you.
Also, although you'll hear conflicting reports on this, but I believe what you're looking for are 1.5 ton and up fenders, as my 1949 3800 1 ton (single wheel, had 9' stepside bed) has the exact same wheel openings as a 1/2 ton.
Post up pictures of the clearances with the widened fenders, so we can help you brainstorm.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-30-2010, 02:33 PM   #183
BBEEP
Junior Member
BBEEP's Avatar
Test fitting the passenger fender after widening 2 inches. I can turn the front of the 28 inch tall tire out, and it hits the top of the tread about 75% out. Turning it in, the back of the tire hits almost immediately. If I put a shorter tire on it, that will help some, but then it is really low. (still completely stock AWD chassis & suspension) I'm going to get some measurements off of my 50 School Bus to see if the 1 1/2 ton fenders will work better. Any other ideas?
Obviously I haven't straightened the frame yet. I want to get things mocked up, then send it out while I am dipping the parts that I will use.
67 c/10 SOLD 2012
71 SS454
Old 03-30-2010, 04:12 PM   #184
67chevy2wd
67chevy2wd's Avatar
Try a different backspacing on the rim? Not sure how much more you could move the wheel in without it looking goofy though.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-30-2010, 04:14 PM   #185
Dan Bowles
AD Addict
As a daily Trialblazer driver, 268k miles, while you have it down, get into the splined disconnect, clean it up good, and put improved grease in it! Lots of discussion on Trailvoy.com but I suspect you know this. Mine took a dump this winter and still waiting to get it fixed. Also, get a good look at your exhaust manifold. I've just had my second one go bad. Other than that...drive the double-toothpicks out of it!!
On the fenders...hmmmm...big bolt is one way to go but just not sure what else to do.
Old 03-30-2010, 04:46 PM   #186
BlueJeep
BlueJeep's Avatar
It looks like you need one of about two things. Either you need the body to sit higher so that you can use your existing setup, or you need larger wheel openings in the front. I don't imagine different backspacing is an option, looking at the wheels that are on it now. Since it's AWD, narrowed control arms aren't an option. I think what I'd do is section the front fenders and use the existing wheel openings, just make them larger and higher.
I think you ultimately may need to take the same approach as these guys:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-30-2010, 08:30 PM   #187
Dan Bowles
AD Addict
Bluejeep has something there...the first COE looks like he's radiused the wheel wells AND flared them out. You might be getting some style points there!!
Old 03-30-2010, 08:48 PM   #188
BBEEP
Junior Member
BBEEP's Avatar
Yup Dan, very cool. The fender does go back into the doors, being a coe, but very nice. Would be cool if I could snub nose it, too.
I printed the pic, I'll take it to the shop tomorrow.
67 c/10 SOLD 2012
71 SS454
Old 03-31-2010, 01:59 AM   #189
Cautrell05
You probably already know this but with the envoy awd you need to keep all 4 tires close in size or the transfer case module gets confused. Seriously though, you got the body on that far. making the tires clear isnt that big of a deal compared to what you have accomplished so far. Keep it up.
Nick
Cautrell05 is offline   Reply With Quote
Old 04-01-2010, 12:30 AM   #190
BBEEP
Junior Member
BBEEP's Avatar
Nick
Thanks for the encouragement! Also, the reminder! I had a problem when I bought street tires for my John Deere 4x4 and I definitely don't want another problem like that.
67 c/10 SOLD 2012
71 SS454
Old 04-01-2010, 07:31 AM   #191
hgs_notes
GEARHEAD
hgs_notes's Avatar
I said it once before, but about a 2" body lift might help a lot.
hgs_notes is offline   Reply With Quote
Old 04-01-2010, 08:16 AM   #192
Cautrell05
Also the base trailblazers and envoys came with 16 inch wheels so that may be an option also.
Nick
Old 04-01-2010, 08:25 AM   #193
DARKASS04EXT
Nick
depending on the model Trailblazer/Envoy they came with 16" and 17".
BBEEP... If your using an XL envoy you will have to stay with atleast the 17" wheels. The LWB Envoy(XL) and Trailblazer(EXT) must use the 17" because the front brakes are larger than the SWB versions.
I didnt notice what model Envoy your using, if its the SWB you can use 16"+.
Old 04-01-2010, 09:14 AM   #194
Dan Bowles
AD Addict
I forgot about that detail. I've got 16"s on mine, my buddy has the EXT with 17"s. Now I know why!! I can at least steal his rims...
Old 04-01-2010, 09:24 AM   #195
DARKASS04EXT
Old 04-01-2010, 10:47 AM   #196
BBEEP
Junior Member
BBEEP's Avatar
Using the short wheel base, with 17's. I'll have to check, but at first glance it looks like it has the bigger brakes.
Old 04-01-2010, 11:10 AM   #197
DARKASS04EXT
It shouldnt have the larger brakes on it. All SWB come with the standard size rotor and calipers. The XL/EXT have larger dia rotors and different calipers. The only SWB that has the larger brakes is the SS. I see you actually have an SS, so match the caliper to the envoy. From what ive been told the EXT and SS run the same brake setup. The EXT/XL use it for the added weight, while the SS uses them for the performance gains. The EXT calipers have "ribs" on top of the caliper unlike the SWB calipers. Hope this helps some.
Also, over @ Trailvoy.com, we have other members that would be able to set you up with the info you may need.
Old 04-03-2010, 08:09 PM   #198
BBEEP
Junior Member
BBEEP's Avatar
Bought fenders and hood from a 49 GMC 2-ton today for $60 total. Looks like if we cut the front 1/3 from the original fenders and graft them to these truck fenders, it will be a winner. They are a little wider, taller, and the flare out some. The hood is actually 'pancaked'. The hood will have to be shortened by about 3 inches. I'll post pics as I can to show what I mean.
67 c/10 SOLD 2012
71 SS454
Old 04-04-2010, 08:37 PM   #199
Dan Bowles
AD Addict
You'll have to post pics because I can't see the 1/3 thing. Nothing lines up, the big fenders fit over top of the small ones!
Old 04-06-2010, 05:05 PM   #200
BBEEP
Junior Member
BBEEP's Avatar
What this did was give me a different shaped opening. The front opening of the 2-ton was too far forward, as well as the fender being 3.5 inches longer. Attaching the front of the Burb fender cured both things. The 2-ton also sits about two inches higher, which gives the hood a pancaked look. Still have to shorten the hood the 3.5 inches.
I will raise the running board to be flush with the body and shorten the rear hang of the front fender and the front hang of the rear fender. (say that 3 times real fast!)
67 c/10 SOLD 2012
71 SS454
suburban
