Old 01-03-2012, 06:51 PM   #176
grennberet02
Re: LS engine swap info
I am looking for a cost effective header. Where did you purchase. I do not prefer thin headers.
Did you do the duals or dual to single?
Did you place the 02 sensor right after the header?
grennberet02 is offline   Reply With Quote
Old 01-03-2012, 11:22 PM   #177
Firebirdjones
No one makes a long tube header for the LS 4x4 blazer swap.
I looked around and only found shorties, which didn't interest me. They aren't worth much power over the truck manifolds, which are actually a decent flowing piece, said to be one of the best LS manifolds aside from the vette. For $500 for shorties I elected to just use the truck manifolds.
I simply made some exhaust pieces out of mandrel bends to connect the manifolds to my current exhaust system, which is a dual exhaust. I then welded in 02 bungs right after the exhaust manifolds in a convenient spot.
At some point if someone comes out with long tubes, I'll swap over.
Firebirdjones is offline   Reply With Quote
Old 01-04-2012, 12:45 PM   #178
thor
thor's Avatar
How about the Doug Thorley headers for LS swaps into 67-72s? I think part # 324Y-C. As for cost effective, that's a different matter.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-04-2012, 12:49 PM   #179
mooseknuckles
mooseknuckles's Avatar
.....most guys are using long tube camaro or chevelle ls swap headers..they seem not to hang lower than the frame...but if it's a 4x4 it wouldn't really matter anyway?
mooseknuckles is offline   Reply With Quote
Old 01-04-2012, 12:57 PM   #180
Firebirdjones
Those are only 1 5/8" primary tubes, and all the Dougs truck headers are of the Try-Y design.... Guess if you are just looking for a set of headers and didn't mind those details, these would get the job done for you...
I prefer at least 1 3/4 for a small LS, or 1 7/8 for larger LS.
Old 01-04-2012, 01:03 PM   #181
Firebirdjones
I haven't seen that done in a 4x4 swap yet. Plenty of 2WD's though.
I'm not sure what year camaro you are speaking of. I have 2 4th gen camaro's here with LS engines and long tube headers in both. The driver side header collector has a weird kick out toward the rocker on both cars (to clear bellhousing) at about 20 degrees. That would be nearly impossible to make work in a 4x4 blazer when you have a pair of crossmembers and a transfer case to deal with.
My chevelle and 1st gen camaro doesn't have an LS in either, so I have no idea what those swap headers look like. Guess I'm just not willing to experiment with a $700+ set of headers...but I'd plunk the money down in a heart beat if something out there on the market worked for certain.
I was hoping someone would chime in with pics that has actually done this but it doesn't seem to be a popular swap as of yet?
Old 01-04-2012, 01:21 PM   #182
mooseknuckles
I meant the 70-81 camaro ls headers......but man its hard to get an answer on this topic!
Old 01-04-2012, 01:40 PM   #183
Firebirdjones
Oh okay. I have a 2nd gen here as well, (but no LS) so I'd be curious to see what those headers look like.
I know what you mean. I beat myself up over this last summer when I did my blazer LS swap. I just couldn't find the answers I was looking for. Seems people shy away from the long tubes when 4x4 blazer is part of the picture
Funny though, I had long tubes in the blazer with the original 350 (Hedmans), and they fit rather nice with good clearance for the transfer case, although the collectors and primary tube length was a bit short to accomplish that.
So I don't see why someone in the aftermarket couldn't make a set for an LS. Probably not enough demand I guess.
Old 02-04-2012, 10:59 PM   #184
shadow1967
shadow1967's Avatar
thanks was lookimg for info like this!!!!
shadow1967 is offline   Reply With Quote
Old 11-05-2012, 01:42 PM   #185
smoky02
Location: Sunny, Florida, some might call it South Alabama
I am also very interested in what headers will work on a 2wd, I'm seeing ya'll are talking about the 2nd gen LS headers and Chevelle headers, but what brand are ya'll referring to?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-05-2012, 02:40 PM   #186
grennberet02
Smile Re: LS engine swap info
I used a 98 camaro driver side manifold and truck passenger side manifold. I installed an 02 bung on the passenger side as the manifold did not have a provision. The camaro dirver has a hole provision for the 02 sensor already on it.
I finally got my LS running with 0 issues. I can't believe it fired up at the flick of the key.
Now for all the other fun stuff like brakes, shifter, and wiring.
Old 11-05-2012, 04:00 PM   #187
1970 C10 MJW
1970 C10 MJW's Avatar
subd
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 05-24-2013, 03:04 PM   #188
wesmigletz
wesmigletz's Avatar
Great information. Thank you for sharing.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 05-27-2013, 11:23 AM   #189
Billett
Billett's Avatar
Actually they do sell larger versions. 324y-c is the 1-5/8" version but 323y-c is the 1-7/8" set. I called up Mike just last week and ordered a set and he gave me a great deal on them.
Also, tri-y headers are great for low and mid range power they just lack a bit of the top end that long tubes have. Since I don't plan on running my truck at 6500rpms all the time I think they'll be fine.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 05-28-2013, 11:36 AM   #190
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Would you like to share your contact information for Mike? website, vendor link, etc?
[QUOTE=Billett;6092551]Actually they do sell larger versions. 324y-c is the 1-5/8" version but 323y-c is the 1-7/8" set. I called up Mike just last week and ordered a set and he gave me a great deal on them.QUOTE]
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 05-28-2013, 12:21 PM   #191
Billett
Billett's Avatar
NP, this is from his email to me. He was fantastic to deal with and I'm getting the headers today so I can post some pics if you want.
Mike Johnson | Doug Thorley Headers
803 E. Parkridge Ave. Corona, CA 92879
Direct**** (951) 273-3602
Fax********* (951) 273-3616
Web: www.dougthorleyheaders.com
Like us: http://www.facebook.com/dougthorley
Will
2024 Toyota Sienna
Old 05-29-2013, 05:30 AM   #192
mcmlxix
Collector of Projects
mcmlxix's Avatar
I found this pic at the link below ....
http://dougthorleyheaders.com/produc...productID/1079
Rich
1972 K5 Blazer CST Click HERE
Old 05-29-2013, 12:06 PM   #193
Billett
Billett's Avatar
There are plenty around I was just offering. They dont do them any justice though. These things are high quality and absolutely beautiful.
Will
2024 Toyota Sienna
Old 05-29-2013, 12:20 PM   #194
ChevyCruizer
17's too small
I would like to see some pictures installed. I am running a LS2 with the Porterbuilt drop member (long ways from running LOL) and most guys seem to be going with the PaceSetter 98-02 Camaro long tube headers. I dont like how the drivers side kicks out so much. I was thinking of trying the TrailBlazer SS headers but am not sure if they will work with the drop member, but I do have a TBSS so I could run them on that if they dont fit the C10, but then again I do like the look of these Doug Thorley's.
Old 05-29-2013, 01:09 PM   #195
Hart_Rod
Hart_Rod's Avatar
I don't think the DT's will work with the PB extreme dropmember. However, I'm 99% sure these will:
http://texas-speed.com/p-3066-bbk-20...h-headers.aspx
Hart_Rod is offline   Reply With Quote
Old 05-29-2013, 03:25 PM   #196
aggie91
I'm just glad to be here!
aggie91's Avatar
I have these headers in my son's '82 with a LS and a raised stock crossmember. Should work well with a PB crossmember too.
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV9
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-29-2013, 05:13 PM   #197
Bennett68C10
Bennett68C10's Avatar
Hey Rob have you figured out what headers your going to run on your sons truck. I'm wondering if the Doug Thorleys would work for me with my touring dropmember. That is if I decide to change over
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-29-2013, 08:00 PM   #198
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
not sure if these have been mentioned....but the Hedman/MuscleRods mid-length 1 3/4" x 3" set at Pace Performance in raw steel.....for $309! Or...with the HTC 1300 degree, Shinny Silver Finish for $579
BTW....they show fitting as '67-'98.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-29-2013, 08:57 PM   #199
Hart_Rod
Hart_Rod's Avatar
Not quite sure yet. I know 2010+ Camaro factory manifolds will work. So those BBK's should work. I've got to put the motor back in and put the cab back on, then I will decide....
Those are NICE!!!
Old 05-29-2013, 09:51 PM   #200
Bennett68C10
Well hurry up and get that cab back on
Keith
66 Suburban
IG: bennett68c10
