Old 02-13-2012, 01:52 AM   #176
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: My 66 Service Truck Build Thread
Spent hours just getting the hardware cleaned up to mount the rear bumper.
That was why I got the box so cheap - it was welded to the frame.
I had to cut the rear part of the frame off the truck the box was on, and I spent this weekend getting all the welded junk off the mounting hardware and bumper.
Here's the bumper mounting brackets cleaned up and bolted to my frame:
66 C20 Service Truck:
Old 02-19-2012, 02:11 AM   #177
LostMy65
LostMy65's Avatar
Finally! Bumper is mounted.
I still need to do a little more welding, but good enough for now.
Now back to mounting the master cylinder.
Shaft extended with bolt and nut to lock pedal adjustment
Master Cylinder is bench bled.
Old 02-19-2012, 01:09 PM   #178
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Very nice... each step forward is a step closer to completion
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 02-20-2012, 08:15 PM   #179
LostMy65
LostMy65's Avatar
Thanks for the reminder to look at it as progress.
Between spending 3 days just getting that box mounted up, and now battling with a faulty O'rielly Master Cylinder, I feel like I'm making very little headway. I know I'm just more anxious because I want this 66 back together and mechanically sound so I can get started on my 65.
Old 02-25-2012, 05:18 PM   #180
LostMy65
LostMy65's Avatar
When I was working on getting the bumper mounted, there was this nut welded to one of the brackets that I needed to remove.
I cut it off and it feel to the ground, but I couldn't find it anywhere. When I got in the house I noticed one of my shoes was making a clicking noise when I walked.
Found the nut:
Old 02-25-2012, 06:11 PM   #181
C@rnut001
LOL...it did not want to be discarded....LOL. Keep at it, you will get this one done and be able to do a great job on your '65. Your story on your trucks is so cool, since you bought the one to replace the '65 and then you found and bought back your original '65!
C@rnut001 is offline   Reply With Quote
Old 02-26-2012, 03:36 PM   #182
LostMy65
LostMy65's Avatar
Brakes all bled. Clutch linkage hooked up.
Just need to put the steering back together - and then, Yippie! I can start putting the front body panels back on so it can look like a truck again.
Old 02-26-2012, 03:38 PM   #183
LostMy65
LostMy65's Avatar
Yeah, I keep walking out to look at my 65 to remind myself I really do have it back.
Old 02-27-2012, 12:16 AM   #184
LostMy65
LostMy65's Avatar
I found it interesting that the 66 had longer tie-rods than the 79.
Here is the 66 cross-link laid across the 79 for comparison:
Old 02-27-2012, 12:25 AM   #185
66-PMD-GMC
66-PMD-GMC's Avatar
Doesn't suprise me. The location where the idler and steering box are mounted are both "raised" making the width wider.
Projects..
440CID 2X4 Pontiac
Old 03-02-2012, 11:05 PM   #186
LostMy65
LostMy65's Avatar
Pretty good week.
I finally got all my under hood stuff done.
And Brakes are nice and firm.
So I started bolting the front clip panels on.
All but the hood and the bumper are mounted.
I'm hoping to start putting the interior in this weekend, and if all goes good, I might even have it drivable minus the windshield.
I hope.
Old 03-04-2012, 01:26 AM   #187
57truckguy
Found the nut
I was skip reading your thread and I just about fell out of my chair... LOL I thought I was the only one who did stunts like that.... LOLLL
57truckguy is offline   Reply With Quote
Old 03-04-2012, 01:29 AM   #188
57truckguy
I hope you haven't answered this question a bunch of times before but are you going to keep it a service vehicle or ?"???? One of the guys locally has an 65 chevy auto wrecker that he refurbished to orginal. Looks pretty cool..
Old 03-04-2012, 01:43 AM   #189
LostMy65
LostMy65's Avatar
Yes, I will keep the service box on it because I really like the usefulness of the box. I also plan on using this 66 for scavenging wrecking yards for parts.
Also, it was originally a service truck and still has the county decal on the doors.
They're painted over, so I'm not sure what the circle decal says:
Originally Posted by LostMy65 View Post
I've told you guys that under the almond color paintjob the truck is county orange.
The box and all came from the factory county orange.
Under every nook and cranny it's county orange.
Well today I just discovered another neat possibility;
you can see a slight outline of a circle on the door.
The circle's diameter is around 16"
I'm hoping that I'll be able to safely remove the paint to expose who really owned this truck.
Old 03-04-2012, 03:10 AM   #190
McMurphy
McMurphy's Avatar
Your local DMV should have a form for you to fill out, and after a week or two, they send you a complete history of ownership for that VIN#. You should only have to be the legal and currently registered owner to request that info.
I found out by accident while at the Alaska DMV last fall.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-04-2012, 03:42 AM   #191
LostMy65
LostMy65's Avatar
That's a great suggestion.
Thanks.
I will also try that with my 65 now that I have it back.
I need to find out who sold my 'buddy buckets' so I can kick their butt!
Old 03-04-2012, 10:29 PM   #192
LostMy65
LostMy65's Avatar
This is one of Mark's pics of doing his inner fender fix.
I'm saving it here for future reference:
Old 03-04-2012, 10:36 PM   #193
LostMy65
LostMy65's Avatar
My 66 wiring was pretty hacked up.
As with many of our trucks, someone cut the ignition plug off to wire some stupid aftermarket ignition switch.
Also, the turn-signal wiring was all hacked up and routed to some toggle switch for the blinkers.
I found a couple old wiring harnesses that had what I needed, so I did a rebuild on my wiring - soldering the connections.
I'm really happy with the results, and I saved myself quite a bit of money.
Those new wiring kits are rather expensive.
Here's the left-overs:
Here's the toggle switch that was used for the blinkers:
Old 03-04-2012, 11:03 PM   #194
LostMy65
LostMy65's Avatar
Another post by Mark saved for future reference:
http://67-72chevytrucks.com/vboard/s...d.php?t=387693
Old 03-05-2012, 08:34 PM   #195
McMurphy
McMurphy's Avatar
In that mess of left over wiring, did you end up with an ignition plug?
Someone hacked mine out.
I got the new ignition, along with the lock set (ignition, doors, glovebox) but dont have the plug.
Drop me a PM or a post on my build (or here) if you have this and dont mind parting with it.
Thanks!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-05-2012, 09:56 PM   #196
LostMy65
LostMy65's Avatar
No ignition plug left over.
Old 03-06-2012, 09:52 PM   #197
LostMy65
LostMy65's Avatar
I didn't get anywhere near what I wanted done this last weekend.
Punch list for completion:
(In no particular order)
Updated: 3/07/12
Install Windshield
Install Gas Tank - DONE
Get new Lock Ring for tank. - DONE
Cotter Pin for Pitman Arm - DONE
Bolt steering shaft to box. - DONE
Find nuts for front shocks - PARTIALLY DONE
Replace Water Pump.
Fix leak at radiator hose.
reinstall power steering pulley belt.
Install steering wheel - DONE
Install new turn signal harness. - DONE
reconnect headlight and taillight wiring. - PARTIALLY DONE
Attach muffler. - DONE
Install throttle linkage. - DONE
Finish Bolting bellhousing to motor - DONE
Reconnect Emergency Brake Cable. - PARTIALLY DONE
Finish welding bumper and hitch receiver.
Old 03-06-2012, 11:17 PM   #198
McMurphy
McMurphy's Avatar
Me either!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-06-2012, 11:51 PM   #199
niterider65
niterider65's Avatar
Cool Re: My 66 Service Truck Build Thread
looks like what i had under my dash had all of it working but turn signals also but i bought a couple of old harness and made an new one from other harness too. lots of fun and
keep up the good work ..
niterider65 is offline   Reply With Quote
Old 03-08-2012, 08:58 PM   #200
LostMy65
LostMy65's Avatar
I took it up the road and back.
Pretty neat. Power Steering.
Power Brakes - 8 lug front discs with 1 ton calipers.
14 bolt ff with 13" drums in the back.
Basically, the whole drivetrain and suspension is
a 79 chevy. except the transmission is still the 66. sm420
I've held off mounting the doors until I was sure I had all the interior together.
The only thing left is installing the windshield, and then I'll mount the doors.
