Old 03-26-2012, 05:24 PM   #176
McMurphy
McMurphy's Avatar
Re: '60 GMC 4x4 Long Fenderside
#4 need valve seat looked at, or rings perhaps?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-26-2012, 06:50 PM   #177
Dub_X
Professional Crow Bar Tosser
Dub_X's Avatar
I was thinking rings.
Dub_X is offline   Reply With Quote
Old 03-27-2012, 09:10 PM   #178
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
If I shoot some oil in the cylinders, then test it again, and the numbers go up, then it needs rings throughout right?? Just double checking.
I cannot believe how much antifreeze this 305 holds. When we changed the lower heater core hose, we drained out 5 gallons, yes, 5 gallons of fluid. When putting it back in, I have put back in 6 gallons so far. I think it's about done though. I looked it up in the manual, and it says that the capacity is 32 quarts. 8 gallons! I looked it up in another manual, and the 396 only uses 24 quarts, and the 454, 20 quarts. LOL
Also, I need to ask something of other 305A owners. I need to know how long the oil dipstick is from the tip to where it seats on the tube please. The manual says that the 305A takes 6 quarts of oil with the filter. I poured one quart into the filter, and 5 into the engine, and it is still not on the dipstick. When we drained the old oil out, I think we got just under 8 quarts out of it. Is there an extra large oil pan option? I haven't seen anything that talks about it, but who knows!
I got to thinking about the no start issue. We didn't fill the bowl on the carb. I looked in the sight plug, and couldn't see any gas in there at all. This weekend, We will take the fuel line off of the carb, and turn it over, to see if the pump is even working, then fill the bowl, and try some more if it is!!
Thanks!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 03-27-2012, 09:30 PM   #179
FetchMeAPepsi
FetchMeAPepsi's Avatar
I forget which engine you have, but here's all of 'em:
305A = 6 w filter
305B = 10 w filter (yes, TEN. Buy Exxon stock lol!)
305C = 10 w filter
305D = 6 w filter
305E = 6 w filter
Glad you got her turning over. These are really fun and bulletproof engines. I wouldn't trade mine for anything.
FetchMeAPepsi is offline   Reply With Quote
Old 03-27-2012, 09:52 PM   #180
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Its the 305A, and with 6 quarts in, not even on the dipstick yet!
What engine is in yours?
Jason
Old 03-27-2012, 10:02 PM   #181
FetchMeAPepsi
I have the D. Your dipstick might be short or broken off. I'd not put more than 6 in to be safe and keep from foaming. I'll measure mine this weekend for ya if no one pipes up by then. She's away from home till Saturday.
Old 03-27-2012, 10:04 PM   #182
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
The dipstick has the markings on it, so its not broken off, but I'm thinking it may not be the original one.
Jason
Old 03-27-2012, 10:21 PM   #183
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Here is a couple of shots of the dipstick that is in there. Sorry for the blur!
Thanks for your help FetchMeAPepsi.
Jason
Old 03-28-2012, 06:07 PM   #184
Corts60
Just here to tinker
Corts60's Avatar
That dipstick looks to be correct to me. Unfortunately, my burb is 200 miles away so I can't measure it for you. But, one more thing, just check and make sure the actual tube is seated in the block and/or oil pan properly.
Old 03-28-2012, 06:13 PM   #185
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I thought of that, and looked at it a little bit. It looked like it was seated in there properly to me. It is solid, and doesn't appear to have been pulled out any. I will measure how far it sticks out tonight, and see if anyone can verify those measurements too.
Thanks Corts60!
Jason
Old 03-28-2012, 06:39 PM   #186
Corts60
Just here to tinker
Corts60's Avatar
Take a look in this photo and see if your dipstick looks the same height from the exhaust manifold bolt to the top of the tube.
Old 03-28-2012, 06:47 PM   #187
Corts60
Just here to tinker
Corts60's Avatar
Also, look at the difference in the oil pans between these two engines. The first one has a 6 quart pan and the second has an 8-10 quart pan. There might be your answer as to which you have:
Old 03-28-2012, 09:05 PM   #188
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
The dipstick looks like the same height as in those pictures.
Name:  032812-2042 (Small).JPG
The pan looks kind of like a cross between the two. LOL
Name:  032812-2048 (Small).JPG
Name:  032812-2049 (Small).JPG
Name:  032812-2051 (Small).JPG
Jason
Old 03-28-2012, 09:58 PM   #189
Corts60
Just here to tinker
Corts60's Avatar
That's strange man. It seems like you have the 6 quart pan. This is strange. Have you asked the guys over at 6066gmcguy.org?
They will probably know what the correct length of the dipstick should be.
Old 03-28-2012, 10:17 PM   #190
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks for the info Cort! I will see what I can find over there, and keep looking on here.
Anyone else have info??
Jason
Old 03-28-2012, 11:38 PM   #191
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
cayoterun might, he deals with the V12's and they share a lot of parts from the V6's so give him a shout.
http://67-72chevytrucks.com/vboard/s...d.php?t=413154
Edit: On second glance it looks like they have one oil pan so I really don't know.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-31-2012, 11:18 PM   #192
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Anyone else with info on the dip stick length?
My son and I got her running today! Filled the bowl with gas, stuck a battery in it, and turned the key, and it fired up. Runs smooth, and strong. Sounds good, you can't really hear it in the video, but it sounds GOOD!!!
Sorry for the video quality, I was a little excited!
Jason
Old 04-01-2012, 01:51 AM   #193
Captainfab
60-66 Nut
Glad to hear your truck is running.....does sound good, but what is that occasional noise?
Old 04-01-2012, 02:01 AM   #194
Dub_X
Dub_X's Avatar
It liiiiiiiiiives!
Old 04-01-2012, 11:19 AM   #195
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks Captain!
The drive line going to the transfer case was clanking. It would kind of shudder, then clank. I think the u-joints are just dry.
Jason
Old 04-03-2012, 10:43 PM   #196
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I got some answers about the oil quantity.
Over on Jolly's site, I asked them. They gave me measurements for the pan, the dipstick length overall, how far the dipstick "cap" is from the end, and finally, how far the dipstick tube sticks up out of the block. Everything matched except the height of the tube. The 305A with the 6 quart pan should be at 14", and mine is at 16", so therein lies the problem.
Next question is, what would be the best way to get the tube out without damaging it? It is rock solid in there, with the top clamp removed. I tried tapping it in further, tried jiggling it side to side, and tried twisting it. No movement at all.
Any suggestions?
Jason
Old 04-04-2012, 11:53 AM   #197
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Maybe a little propane torch and this stuff:
Tony
Old 04-04-2012, 12:28 PM   #198
Corts60
Just here to tinker
Corts60's Avatar
Either that mentioned above or soaking some PB blaster on it. Before you go destroying it though, make sure you can find the correct one you need. It may be hard to get one. Just a thought. Or, get a tube cutter and cut down the tube to the size you need. kind of ghetto, but will get you by until you can procure the correct tube.
Old 04-04-2012, 01:03 PM   #199
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh good idea with the tubing cutter, I would just do that to avoid breaking it.
Tony
Old 04-04-2012, 03:37 PM   #200
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks guys!!
I figured I would try to mess with it some more this weekend. If I can't get it to at least wiggle, I had thought about cutting it off to the right length, but didn't want to say that on here yet. Didn't want to get attacked for mentioning it, because I know that is not the proper way, but it is better than not knowing how much oil I have, or overfilling it.
Jason
1960, 4x4, 60-66, gmc, k1000
