Old 04-30-2012, 04:58 PM   #176
gettmoneyy7
gettmoneyy7's Avatar
Re: 1982 C10 swb "SS"
Preciate the info man I been wandering how much they run..and I was only asking because I have a rebuilt 700r4 with a shift kit already . I'd love to do a ls swap just on a budget at the moment .. And im actually almost done with my build I'm just finally getting all the pics together and getting the posted. Didn't have the time before to start the thread.. Here's my build thread . And thanks good luck on yours.
.http://67-72chevytrucks.com/vboard/s...d.php?t=520473..
gettmoneyy7 is offline   Reply With Quote
Old 04-30-2012, 04:59 PM   #177
maxxxy
maxxxy's Avatar
Nice build. Youre making pretty constant progress. i have a question though. what did you use to strip the paint/undercoating off the firewall.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-30-2012, 05:08 PM   #178
shenk10
shenk10's Avatar
I didn't know you were just about done. Doing an ls swap is easy than a frame off so I don't think you will have a problem with it. But yea I believe they make an adapter plate for the trans, I can't remember, but I know people have done it.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 04-30-2012, 05:10 PM   #179
shenk10
shenk10's Avatar
Thanks, and to be honest I'm not quite sure. I know I started with a remover from advance that was in a spray can, and then I just got some liquid paint stripper from home depot. It was a mess either way, but I used a puddy knife and it came off pretty well, and then sanded down to metal.
Jordan
In progress....
Old 04-30-2012, 10:25 PM   #180
gettmoneyy7
id love to do the ls swap now but to be honest i cant afford it at the moment.. im hoping in a couple months i will have it lol
Old 04-30-2012, 11:26 PM   #181
JCampbell
Nice.
JCampbell is offline   Reply With Quote
Old 05-14-2012, 09:38 PM   #182
shenk10
shenk10's Avatar
Well I have been working on the cab some now, I cut pieces to fill all the holes I wanted to fill on the firewall, so just have to get them welded now, as well as the floor cut outs. I finally got the cab mounts figured out and was able to set the radiator support on the truck to test fit the radiator and trans cooler. I also set the cab on the truck for one final time before paint to check clearance with the different lines and trans in final place. Next thing is to order 3.73 gears and get the rear set up so I can order the driveshaft.
Jordan
In progress....
Old 06-05-2012, 02:11 PM   #183
shenk10
shenk10's Avatar
Didn't get much of anything more done. Realizing how much time metal work takes. I have been filling the holes in the firewall, trying to get rid of the seam, as well as working on the rockers and cab corners on each side. I put the fenders on for more fitment and trying to figure out where everything is going under the hood. I'll post more pictures later.
Jordan
In progress....
Old 07-20-2012, 06:22 PM   #184
shenk10
shenk10's Avatar
Quick update. I just got a LH battery tray, along with an 83-87 lower grille panel so I can run an '85 grille, and the smaller mirrors. I also just ordered some pieces for an intake. Should work on the truck a lot some more this week so hopefully will make some progress.
Jordan
In progress....
Old 07-20-2012, 08:35 PM   #185
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Just fyi, if you are ordering a new driveshaft, maybe consider a stronger rear diff yoke connector to the driveshaft if you are rebulding that anyway at the same time.
Your motor will blow apart the smaller diff yoke I think with all that LS POWER!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-20-2012, 08:39 PM   #186
shenk10
shenk10's Avatar
Thanks for the heads up, I was planning on doing a 1350, and just letting whoever I get to make my driveshaft supply it, are you running a 1350?
Jordan
In progress....
Old 07-22-2012, 12:00 PM   #187
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
1350 front and a 1350/1310 in the rear...which will be all 1350 when I get my new rear end.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-22-2012, 02:14 PM   #188
Gordonr1973
Home Built '87
I used a 1350
Gordon
Old 07-22-2012, 02:25 PM   #189
shenk10
shenk10's Avatar
Okay thanks, well I got the battery tray switched to the drivers side, required drilling two holes but went better than I expected. My intake pieces should be on their way so I'll start to get that worked out. I should get a picture or two up tonight.
Jordan
In progress....
Old 07-23-2012, 02:09 AM   #190
Project82
Bretzke Racing Inc.
Project82's Avatar
I must say i love this build! awesome progress! but if you need to get rid of that 82 grille, ill be glad to buy it off ya! is it chrome or silver?
Anyway, good luck with your 82!
Kris
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 07-23-2012, 10:02 AM   #191
shenk10
shenk10's Avatar
Jordan
In progress....
Old 07-27-2012, 06:59 PM   #192
shenk10
shenk10's Avatar
Forgot to take a picture of the battery tray on the driver's side, but here are two of the start of my CAI. I didn't want to spend $300 on an intake that I could piece together for less than half.
Jordan
In progress....
Old 08-04-2012, 09:35 AM   #193
shenk10
shenk10's Avatar
Well I got a chance to work on the CAI yesterday. I pretty much have everything laid out the way I want it. The MAF should go in between the filter and elbow. Just need to find an upper radiator hose or make one...it's a tight fit. Where should I put a support rod? I could do almost anything, come off the core support, frame, or even head. What do you guys think?
Jordan
In progress....
Old 08-05-2012, 12:49 AM   #194
smokedat
smokedat's Avatar
good progress, amazing how a little paint goes a long ways, that motor is looking good
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 08-12-2012, 10:41 PM   #195
Jax87LS1
Those wheels look so good on your truck !
Jax87LS1 is offline   Reply With Quote
Old 01-12-2013, 04:40 PM   #196
exploderjim
exploderjim's Avatar
How are you making out Jordan? I test fit my 6.0 in the blazer last weekend. Now I'm going to take it back out and do the same paint on the engine as you did. Gives us some updates.
exploderjim is offline   Reply With Quote
Old 02-05-2013, 10:47 AM   #197
shenk10
shenk10's Avatar
Thanks for all the compliments, It's been a while since I've done a lot of progress on the truck, but still working on the cab. Progress is very slow with my last semester of school winding down, but should be picking up soon. Here are some of the pictures of the cab from working over winter.
Jordan
In progress....
Old 02-05-2013, 10:53 AM   #198
shenk10
shenk10's Avatar
Jordan
In progress....
Old 02-05-2013, 10:55 AM   #199
shenk10
shenk10's Avatar
Jordan
In progress....
Old 02-07-2013, 11:32 AM   #200
UKNOWME
UKNOWME's Avatar
It's 5.5 on the back and 4.5 on the front. Here are some specs if you need more information. I got them from jdwheels.com because I couldn't find them locally. They seem to have gone up in price since I got them.
Specs:
http://aewheel.com/wheels_detail_specs.cfm?id=442
Any issues with the fronts rubbing or catching the lip of fender? I'm getting mixed reviews on the backspace because that's what I just ordered for mine.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
