08-21-2014, 08:16 PM | #176 | |
Re: Captain America 68 short/fleetside
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
08-22-2014, 12:00 AM | #177 | |
My rims are 0 offset and are 10" wide but the size is only 275x45x20 and I have no issue with clearance with the full travel of the bags. Here is a great calculator for offset and clearance issue. https://www.customwheeloffset.com/ti...et-calculators
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-22-2014, 12:05 AM | #178 | |
The calculator is great for figuring that out and for current wheel / tire size compaired to new wheel / tire size. It will tell you that a different offset or size will increase or decrease the distance of the rim to the inner wheel well and outer wheel well. Handy stuff
08-23-2014, 04:13 PM | #179 |
Thanks for clarifying, Dave. I do know the difference between back spacing and offset, even though I worded it wrong. That calculator for the wheel offset is pretty cool.
I must say, the company I got the spacers from is super fast when it comes to delivery times. Got the correct spacers in today, and there's a considerable difference between the two. -Josh
08-23-2014, 09:33 PM | #180 |
So how does the new ones fit? Does it fix the issues?
09-24-2014, 11:29 AM | #181 |
I haven't tried anything else with the wheels since getting the new spacers. The wheels are on hold because I can't afford new tires. The tire that are on the truck are fairly new and it seems wasteful to replace them before I need them.
I did, however upgrade the headlights. I bought H4 housings and LED bulbs. Man, what a difference. I have to wait until it gets dark before I can adjust them, but I love them already. -Josh
09-24-2014, 02:38 PM | #182 |
I've checked out your thread a few times and I do love the direction you have taken the truck. Eveything is starting to come together. Keep up the good work.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
09-24-2014, 04:17 PM | #183 |
Truck looks Great! Love the taillights. Looks like the new headlights got rid of the yellow cast. They look Great. Nice and white/bright. Can't wait to see it in person. Nice work!
CHEVY/GMC VIN DECODERS |
09-24-2014, 08:28 PM | #184 |
How much were the led bulbs?
09-24-2014, 09:48 PM | #185 |
Housings were $40.00, LED bulbs were $65.00.
-Josh
11-13-2014, 09:36 PM | #186 |
I've been working on my Tonneau cover for the Captain. It's been a week of building, but I wanted more pics to present for better footage. Using 2 inch aluminum angle, 5 inch trailer railing which holds the side panels of dry box trailers for the cross braces. I used 2 inch angle for the frame and for the supports for the cross braces. I'm working on making a bracket to hold the lockable latch at the back of the cover. Once we figure out the latch bracket, we'll rivet the skin across the top and finish it off with "J" moulding on the edges. More pics to follow......
-Josh
12-03-2014, 05:51 PM | #187 |
With the Tonneau cover on hold, I decided to swap out my front turn signals. I has to trim the mount brackets to fit inside the grille shell. I also trimmed the excess that stuck out past the chrome trim rings.
Here's some before and after pics. -Josh
12-03-2014, 05:53 PM | #188 |
During and after pics.
-Josh
12-27-2014, 09:06 PM | #189 |
I installed the power bucket seats and center console from a 99 Silverado I'm stripping for my 65 Buick Wagon.
-Josh
12-28-2014, 01:01 AM | #190 |
Do you have more room with the new seats or less. I always thought these seats with the built in seat belts were the way to go.
12-28-2014, 03:53 AM | #191 |
Moderator
Keep up the good work!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-28-2014, 12:00 PM | #192 | |
I finally got tires for my factory 20 inch wheels. I hope i can get them mounted Wednesday so i can install them on the truck and post more pics. -Josh
12-28-2014, 01:14 PM | #193 | |
12-28-2014, 04:50 PM | #194 |
I know I'm of Wednesday, but that's going to be a crazy day. I might be off Thursday.
I went with 245/40r20 tires. Found some online for $85 each. With shipping, it was less than $400.00. -Josh
12-31-2014, 07:05 PM | #195 |
Ok, I finally got my tires mounted and balanced (245/40R20). Correct 2 inch spacer adapters push the wheel out into the center of the wheel well. Rims are 20x8.5 with 22mm offset. Total back spacing is 5 inches. I like the look of the front wheels in the fender. I think I need bigger tires in the rear next time. I"ll have to relocate my exhaust tips for that, but it'll do for now.
-Josh
01-01-2015, 09:55 AM | #196 | |
01-01-2015, 12:16 PM | #197 |
The Captain is looking good!
01-01-2015, 12:35 PM | #198 |
PROJECT 7DEUCE
Looking good bud
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-15-2015, 12:15 AM | #199 |
Got some progress on the Tonneau cover today. Last week, Dad and I figured out how to mount the cover to the bed via hinges bolted into the front top rolled edge of the bed. Today, I mounted the rear "T" handle latch that locks the cover to the tail gate, Mounted the hood springs (1999 Chevy Silverado hiid springs) and attaching brackets. Now, I have to take the cover back off to have it skinned and install weatherstripping.
-Josh
01-15-2015, 09:34 AM | #200 |
What a perfect use for the hood springs! Its looking great. How did you get the hings mounted on the rolled part of the bed? I couldn't tell in the pics
