Old 02-26-2012, 09:20 PM   #176
E911manager
Re: 1964 Caprick-up = (C10+SWB)*(94 Caprice 9C1+LT1)
Here is the brake pedal assembly. I hooked it all up and have a full pedal...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 02-26-2012, 09:24 PM   #177
E911manager
Radiator top mounts.. I think the brackets are off a mid 80's chevy pickup. The local pickup salvage yard owner gave them to me.. Not quite done. Need some more clean up.. I will have to modify the front core panel things to go around them..
Old 02-26-2012, 09:30 PM   #178
E911manager
Modified the steering column bracket and added about 2 inches to it in order to push the column down far enough to clear the brake booster.
I also cut a hole in firewall behind the front passenger tire. Modifying the inner fender wheels to accommodate the wiring harness and fuse block will be needed. I also plan to make a cover under the inner fender and around the wiring to protect it. Not that I plan on driving in the rain and mud but better to plan and be safe then not and be sorry..
Old 02-26-2012, 10:02 PM   #179
E911manager
Grounded the cab, frame and core support today. Welded in 2 grounds on either side of the interior of the cab. I ran all the wiring and hooked up a battery and the computer.
Turned it over and it tried to start. Had to make a quick frame ground for the rear harness and then the fuel pump started working. Started right up.. Purred like a kitten.......
I had a goal to hear it run by March 1st.. Check.. Now for inner fenders and finish up mocking up the front end so i can tear it apart again and paint the cab...
Old 02-26-2012, 10:11 PM   #180
McMurphy
McMurphy's Avatar
Good to come in on a goal ahead of time!!
Congrats, cannot wait to see how you tackle the rest of this symbiosis build !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-26-2012, 10:35 PM   #181
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
You could always box in the wiring under the inner fender and make a door on top to service it if it ever needed it. That way it would look stockish... not that you are trying to do that just an idea.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 02-27-2012, 06:28 PM   #182
E911manager
That is kind of the plan. But have the access from under the fender and keep the top side clean... I also want to put the AC and heater lines under the inner fender too..
I havent gotten my "good" inner fenders so I can start manipulating them to fit the frame... I hope to get those this weekend, they are currently attached to a pickup in the middle of a thorn patch about a mile off any road...
Old 02-27-2012, 06:35 PM   #183
E911manager
I didnt think I would make this one. With a 55 gallon drum full of wiring, it appeared to be unobtainable.. Next goal, front end fab work done and driving under own power by May 1st. Then body work and tear down for paint.
But I have a BBW kit coming so that has to be worked in there before the next goal.
For those scratching your head (like me)...
sym·bi·o·sis (smb-ss, -b-)
n. pl. sym·bi·o·ses (-sz)
1. Biology A close, prolonged association between two or more different organisms of different species that may, but does not necessarily, benefit each member.
2. A relationship of mutual benefit or dependence.
Old 02-27-2012, 06:56 PM   #184
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great progress and congrats on hearing it run!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-29-2012, 01:05 PM   #185
66ChevyMax
66ChevyMax's Avatar
Congrats on getting that thing started, keep up the great work!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-05-2012, 10:47 AM   #186
E911manager
I go the oil cooler and trans cooler remounted and plumbed in. Made a shifter linkage and installed it. Works well.. Actually, started it and moved it a few inches forward and backward.. Worked on a cab corner and decided that they are both going to need to be totally replaced. Pulled the bed back off and am starting to look for a place to put the battery. Didn't get a chance to go pickup up my inner fenders (complete 65 truck) and it looks like a lot of needed rain later in the week so that may be put on hold for a couple of weeks.. I am just dreading it..
Old 03-09-2012, 11:14 PM   #187
E911manager
I drove the caprickup around the yard today.. I tried to upload a clip but haven't figured it out...
Old 03-09-2012, 11:28 PM   #188
Frizzle Fry
Frizzle Fry's Avatar
Upload it to YouTube, then post the link here.
Frizzle Fry is offline   Reply With Quote
Old 03-09-2012, 11:30 PM   #189
E911manager
Here is a short clip... if it works.
Old 03-09-2012, 11:36 PM   #190
E911manager
Sweet it worked.. Does anyone know where I can get a seat cover for my 5 gallon bucket seat?? Oh and yes my throttle is a broken cable that is located just outside the window....
the first time I started it the remote power steering reservoir was upside down the first time I started it. Now it is noisy.. Maybe some Lucas will clear it up....
Old 03-09-2012, 11:48 PM   #191
E911manager
Thanks Frizzle Fry.
Old 03-10-2012, 11:55 AM   #192
Frizzle Fry
on the bucket! Nice dude! That's gotta be a great feeling. Looking forward to that day myself.
Old 03-10-2012, 12:04 PM   #193
66ChevyMax
66ChevyMax's Avatar
That was classic. Congrats!
Craig
Old 03-10-2012, 05:12 PM   #194
C@rnut001
Congrats man that is so great to see! Keep it up and keep the updates coming. It is neat to see it moving under its own power and the "bucket" seat is priceless as well as the throttle!
C@rnut001 is offline   Reply With Quote
Old 03-10-2012, 09:20 PM   #195
niterider65
niterider65's Avatar
Cool Re: 1964 Caprick-up = (C10+SWB)*(94 Caprice 9C1+LT1)
Dang a five gallon bucket is better than old apple box any day.. your not sitting on spliters :.
Looking good keep up the good work .
niterider65 is offline   Reply With Quote
Old 03-12-2012, 02:16 PM   #196
E911manager
Thanks guys, it is pretty exciting to get it to move.. I just want to drive it around the neighborhood and see how fast the cops come...
Old 03-12-2012, 11:38 PM   #197
64shortbox
64shortbox's Avatar
Congrats on your first drive. No matter how short - that first drive sure gets you motivated to keep going. I can't believe how much you're getting accomplished in such a short time. Great work!!!!!!!!
64shortbox is offline   Reply With Quote
Old 03-13-2012, 11:54 AM   #198
Bears63
...just another truck junkie..
Bears63's Avatar
That video is awesome! Made me chuckle seeing the bucket and throttle, but it doesn't matter, you had it running and moving on it's own. You are moving right along on this and I hope the weather works with you a lot so you can get her finished quickly. Looking forward to seeing the final product.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 03-16-2012, 11:08 PM   #199
E911manager
Thanks Bears and Shortbox... Waiting for inner fenders then I can put it together and hope it fits together...
Old 03-25-2012, 10:26 PM   #200
E911manager
Installed the throttle cable and set the bed in place.. Took off the inner fenders from another donor truck and started to mock them up to fit the frame and bigger radiator.
Then I did a little "grass slinging" in the back yard. I almost fell off my bucket!!!
