Old 04-04-2016, 08:53 PM   #176
piratexpress1369a
piratexpress1369a's Avatar
Re: Mike's 60 Suburban build
Are the glass guys coming to your place
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 04-04-2016, 10:18 PM   #177
mikesacs
mikesacs's Avatar
Nope, driving it there. As long as it doesn't rain!
mikesacs is offline   Reply With Quote
Old 04-08-2016, 08:59 AM   #178
mikesacs
mikesacs's Avatar
I've had 2 slight setbacks. After confirming that a local glass shop could install glass in an old vehicle with a wrap around windshield, I drove it to them and left it for a day. Went to pick it up and they decided it was too difficult for them. Now I need to find a new glass installer.
I also sent my seat belts to a company called Safety Restore to have the webbing changed to grey and the buckle side extended a few inches. Received them back and one of the shoulder belts has an extra half twist in it. I need to return that to them.
Old 04-08-2016, 03:41 PM   #179
AJCK87
Love the color on your burb! You should be proud of the work you have done! Wishing I was at the paint stage. Awesome build
AJCK87 is offline   Reply With Quote
Old 04-09-2016, 10:41 AM   #180
piratexpress1369a
I had help from my neighbor to put my window
Back in. ..butchers cord and a curved pick tool for pulling the rubber gaskets over the lip...we put the gasket on the window first .taped in place them with two suction cup tools carried it to the hood ..then placed top in first and pushed the button in ...it did take us a couple of hours but it did turn out good. ..needs to be a warm day if you are working outside
63
Old 05-04-2016, 02:25 PM   #181
mikesacs
mikesacs's Avatar
I have a few more pictures since it is drive able.
I had an ordeal getting the windows installed. The first place couldn't do it after telling them exactly what type of vehicle it was and that the windows needed to be roped in. The second place got them in, but my fixed rear quarter gaskets wouldn't work. I ordered the cheap ones and then had to go back and buy the expensive ones.
Just put the running boards on, but still need to adjust them. Also replaced a tie rod end along with the sway bar bushings.
I'm so glad to be driving it again!
Old 05-04-2016, 02:39 PM   #182
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Love that color combo!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 05-04-2016, 03:44 PM   #183
kchampagne
kchampagne's Avatar
Nice work man!!!
kchampagne is offline   Reply With Quote
Old 05-05-2016, 08:57 AM   #184
piratexpress1369a
That turned out awesome mike...bet it feels good driving again ...i was in mine yesterday having it pulledto my nneighbor's place while i get moved again
63
Old 05-21-2016, 08:25 PM   #185
RANDY COX
RANDY COX's Avatar
I just read through your build and one word AWESOME, Love all the mods you did and to go with a diesel, it sucks about the first engine you had in there. I like the color combos you did. I know how much work all that is with my truck too. It's a lot of work without all the mods that you did.. my hats off to ya great work and it looks great...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-20-2016, 08:03 AM   #186
mikesacs
mikesacs's Avatar
I've started working on the air conditioner again. I installed a Vintage Air evaporator and heater years ago. The compressor (GM R4) has been in place since I installed the serpentine belt system. Whats left is the condenser, dryer, trinary switch, plumbing, and wiring. I installed the condenser yesterday and cut to fit all the hoses. I'll try to have a local shop crimp the hoses for me today. The condenser is the largest I could find at 16"x28.5". The compressor is the same one used on a 95 Suburban with front and rear air. I'm leaving the possibility of adding rear air in the future with this setup.
The 2nd and 3rd picture shows the mock up for hose lengths. The last picture shows the condenser installed.
Old 06-21-2016, 02:44 AM   #187
AJCK87
This is a great truck! Diggin the diesel and the color . I see that you have the stock master. How is that with the extra weight of the diesel engine?
Old 06-21-2016, 07:56 AM   #188
mikesacs
mikesacs's Avatar
The master cylinder and hydro boost work fine. They actually came out of the diesel donor vehicle. I have thought about adding rear disk brakes in a future project.
Old 06-22-2016, 04:58 PM   #189
mikesacs
mikesacs's Avatar
I finished the installation. On Friday I'll drop it off at the AC shop and have them vacuum, charge, and check for leaks. Assuming it works! I'm leaving the grill out to allow easy access to the fittings and trinary switch during testing.
Old 09-27-2016, 01:50 PM   #190
mikesacs
mikesacs's Avatar
Someone asked for the dimensions of the plates I used on my rear hatch. This was detailed in an earlier post on this thread. I would use a lighter cylinder if I did it again.
Old 01-17-2017, 09:59 AM   #191
mikesacs
mikesacs's Avatar
Installed my headliner. I debated for years on how I would do this. Used Rattletrap first then foam backed vinyl with spray adhesive. Sprayed each side with 3 coats and let set 7 minutes. Tucked the edges of the vinyl under the edges. Looks good, hope it all stays up!
Old 01-17-2017, 08:13 PM   #192
kchampagne
kchampagne's Avatar
That looks fantastic! Where did you get your foam backed vinyl? I want to do something like that on mine!
Old 01-17-2017, 10:28 PM   #193
mikesacs
mikesacs's Avatar
I bought it from Great Lakes Skipper. They are a marine store.
Old 01-18-2017, 08:50 AM   #194
mikesacs
mikesacs's Avatar
Built a stainless steel spare tire mount that bolts to the driver's side behind the rear wheel. A lot of measuring since everything was angled. I took the idea from a pickup bed mount that I've seen.
Old 01-19-2017, 06:49 PM   #195
piratexpress1369a
That's awesome
63
Old 03-07-2017, 10:39 AM   #196
PGSigns
PGSigns's Avatar
On your lift cylinders what do you have on it now and what would you go with? I like your idea and plan to try it on mine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-16-2017, 11:45 PM   #197
dinobody
That Burb is awsome!! What are the part munbers of the lift shock?
Thanks Doug
dinobody is offline   Reply With Quote
Old 04-02-2018, 11:27 AM   #198
mikesacs
mikesacs's Avatar
Here is a drawing of the rear hatch bracket on the bottom for the hydraulic lift. I've had a few requests for it. It does not need to be very precise.
Old 04-09-2018, 08:18 AM   #199
mikesacs
mikesacs's Avatar
I finally got tired of our crappy stock wipers and wiper arms and wanted something better. I picked up some Bosch 13" blades, Trico 51-151 (except I think they are Anco 4102 in a Trico box), and some Mighty Clear 42630 wiper arms for the J-hook part. I cut the J-hook down to 2.5" long and replaced the bayonet piece on the Trico arms with it. I used a dremel tool to widen the gray plastic adjuster, epoxied it in place and drilled and tapped the j-hook. Now I have the standard j-hook connector that you can attach any common 13" wiper to.
Old 04-09-2018, 08:21 AM   #200
mikesacs
mikesacs's Avatar
A few more pics. I'm happy with the function. I do think they would look better if the arm was one piece stainless, but that would be a lot of work!
