05-31-2013, 06:44 PM | #176 |
Re: Crusty Rusty Leaky Squeaky 67 Step
I'm gonna go out on a limb here and say I may have found at least one reason the brakes weren't working all that well on the drive home...
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
05-31-2013, 08:43 PM | #177 |
Wow that's bad, never underestimate the depths of stupidity and ignorance of the P.O haha
06-13-2013, 03:28 PM | #178 |
Last load on the way to the blaster's. Should be squeaky clean in a couple of weeks. They're going to squirt the chassis and suspension parts satin black for me, so that will save a few headaches here at the house. Workshop almost looks abandoned. I have a ton of stuff to do between now and the time my parts are ready to pick up. Still cleaning and painting small items. Need to check with my engine builder and see where he is on the block and heads. With the workshop empty, it would be convenient to assemble the engine and bag it for installation once the chassis is rolling again. You can't really see it but Eagle's sign says, "Best strip joint in town."
06-13-2013, 04:18 PM | #179 |
Good progress! Time to have an epoxy party!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
06-13-2013, 04:50 PM | #180 |
Yep, won't be long now. Hopefully, we haven't seen the last of the nice days.
06-18-2013, 06:27 PM | #181 |
With the workshop semi-vacant, I was able to move some of the parts around that needed cleaning and painting. When I got this truck, it had an interesting hood feature that I kind of liked. It was poorly installed (naturally) but it seemed to work with the hood lines. Brian G. donated a hood he's not planning to use, so I figured I might graft the hood bubble onto his ...assuming it was salvageable. So today I finally got around to grinding the rest of the bondo away from the seam to expose what I might be facing. Actually looks good so far, although I'll know more when I get the spot welds cut and see what's underneath. I wish I knew what it came off of. Got a car designer buddy that may be able to point me in the right direction. Looks sort of Mopar'ish.
Also got the TH400 tuned up. It was filthy and had a bent vacuum modulator as well as several dings in the pan. Degreased and washed it then rubbed it with lacquer thinner to remove any residue. Repainted it with wrinkle finish and installed a new filter, gasket and modulator. Hammered out the dents in the pan and shot it dull aluminum to mimic the aluminized finish it had when new. While the speedo gear was out, I logged the number of teeth on both gears so I'll know what I need when the time comes. I found a Lokar knockoff firewall mount trans dipstick on eBay. It came with a tiny little fill adapter. Never occurred to me that the braided steel line has about a third of the cross section as the stock tube. Guess I'll fill as much as I can before I insert the tube and then the rest once it's running. While going thru my ever growing swap meet pile, I found a pair of shocks I took off the other truck when I converted it to QA1's. Also found a brand new set of tie rod ends that had the wrong taper for the silver truck, but will work just fine with CRLS. Love it when I find hidden treasure!
06-18-2013, 07:43 PM | #182 |
Great job tearing into that cab. You are very brave, that sucker was toast!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-18-2013, 08:00 PM | #183 |
Seems like they're always worse after you get them home than they look when you're opening up your wallet. We'll see how it looks when it returns from the metal blaster. There's usually a surprise lurking somewhere under all the layers of paint and filler.
06-18-2013, 09:16 PM | #184 |
Since the P.O. decided to just tack weld the hood piece you lucked out and with a little dent removal at the nose it should be a really nice piece to butt weld into the other hood, I can't wait to see the modification done right by someone as good as you, it's going to look killer!
06-19-2013, 08:10 AM | #185 |
x2, git ta choppin! This is gonna look great when it's finshed.
06-23-2013, 07:13 PM | #186 |
Good grief man. What a way to tear into a truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-24-2013, 03:13 AM | #187 |
LOL yeah Vic never does anything halfway, it will be the nicest parts hauler on the road that's for sure.
07-08-2013, 04:04 PM | #188 |
I've had to share my time the last two weeks with Rachel and Ryan, the twins that used to live next to us in Houston. They come up for a visit every summer and the build takes a back seat out of necessity when they are here. Ryan and I did put in some shop time cleaning up and painting a few subassemblies, but at 9 years old, he was more into building a model car than a real one. Maybe next year he'll want to spend more time in the workshop. We did manage to finish a '69 GTO Judge model on which he learned how to handle an airbrush. We met their parents in McAlester, OK on Saturday for the hand-off, so the house is pretty quiet.
I had built up a list of things to do, so I headed out early this morning. First on the list was picking up my wheels from Chip. Did not realize they were clear coated, so polishing them was a bust. After loading them up, I hauled them to the blaster to have them stripped and glass beaded. I may chuck them up in a lathe and sand the rims, leaving the blast finish on the centers. Then have them clear powder coated again. We'll see how they look when I get them back from Eagle. They had finished my chassis parts in Satin Black. Looked nice from what I saw. All remaining parts should be done by next week. Also stopped by the machine shop to check on my engine. Bobby said he would probably have everything ready by the end of this week, but no later than next week for sure. He looked busy! After leaving his place I stopped at LMC on the way to Eagle and picked up a rebuilt quick ratio power steering gear and the stainless trim for the drip rail. Back home, I ordered 3" drop rear coils from CPP via eBay. They're having a special right now with free shipping. Also ordered an aluminum, rear mount, side fill fuel tank from Boyd's Welding. This will force me to hit the salvage yards for a fuel door setup. Also need to research a floor mount e-brake handle as I plan to do away with the dash mount hand brake. I've always liked poking around a salvage yard, but there's no place hotter in the summer or colder in the winter. With the kids gone, I'll be playing catch up for the foreseeable future. I'm looking forward to starting a punch list. Went to my favorite cruise in last night and it sooooo sucks not having a ride.
07-08-2013, 05:22 PM | #189 |
Late in the build, I noticed the filler off my 05 Chev ccsb would be a good fit, but we already had the parts. There's a couple at 24hwy picknpull. Also, I've seen mustang ebrakes mounted outboard of the seat on the drivers side. Maybe a pull one out of a Toyota pu? Food for thought. Sorry again about the wheels!
07-09-2013, 02:05 PM | #190 | |
07-10-2013, 08:19 AM | #191 |
Still Learning
I can appreciate all the hard work you have in your rust repair. Nice job salvaging a bunch of parts most wouldn't attempt to fix. Keep up the good work.
subscribed. |
07-10-2013, 11:42 AM | #192 |
Wow. You have no fear and incredible skills. Sub'd
Posted via Mobile Device |
07-12-2013, 01:34 PM | #193 |
Took a break from bead blasting hardware and modified the inner roof panel. It came with a raised plateau and pre-drilled holes for mounting a stock rearview mirror. Since I don't plan to use that setup, I needed to smooth out that area. Started by cutting out the raised area and scrounging up a piece of sheetmetal. Marked the shape I needed then rolled an offset around the edge. After a little trimming, I positioned some clamps to hold the patch. Then out came the MIG. Ground down the ugly and it's ready for spot putty and primer.
Next up is making the passenger side of the firewall mirror the driver side and patching all unnecessary holes.
07-12-2013, 01:38 PM | #194 |
Sure glad you're not getting all "custom and detailed" on this one, Vic. Wink wink nudge nudge.
07-12-2013, 01:54 PM | #195 |
Crow tastes pretty good sauté'd with butter and garlic.
07-12-2013, 02:14 PM | #196 |
BTW, Vern (Boppa, of the legendary yellow truck) and I had a productive morning at the Pick 'n Pull yesterday. Was able to scrounge the gas filler door and tube from a Blazer for only 10 bucks. Counterman didn't bat an eye that I left a gaping window in the LR quarter panel. There was a tiny dent elsewhere on it, so I didn't feel too bad about destroying it. Besides, it's for a good cause ...cause I needed it!
Vern scored a handful of braided ground straps and a trans dust cover for 5 bucks, so we kicked butt.
07-12-2013, 02:27 PM | #197 |
Still Learning
Awesome work on the roof panel patch.
07-18-2013, 01:17 PM | #198 |
Good news! The strip joint called and said my stuff was ready. Reserved a U-Haul truck for 24 hours and ferried everything back here to prepare for reassembly. Had to move a lot of parts around to make room but felt really motivated.
Over the weekend, I worked on subassemblies and also began prep on the firewall. I want to smooth it out and make it a bit more symmetric since the heater box and fan will be replaced by a block-off plate for the Vintage Air. I also plan to mount the fuse panel on the kick panel and route the wiring along the fenders to hide it better. So various and sundry f/w holes need to be patched. I used poster board to make a pattern that matched the f/w on the driver side, flipped it over and transferred it to a piece of sheetmetal. Rolled an offset bead around two edges then used a homemade corner roller to lay over the upper edge to mimic the rest of the panel. Spot welded it into place and then used my power nibbler to make a single opening on the driver side where several smaller holes needed to be filled. Made a patch for it as well as the clutch and e-brake cable openings. All are now tacked in place and ready for the MIG. It will have to wait, however, as I have bigger fish to fry.
07-18-2013, 01:28 PM | #199 |
Looks good! I gotta get over and play with the bead roller.
07-25-2013, 03:44 PM | #200 |
Progress update. Since picking up my stuff from Eagle Stripping, I've been working on several fronts. I seem to do best when I work on something until I wear out, then attack something else for a while. Rotating between tasks seems to help me avoid vapor locking when something doesn't work out. Anyway, before sending the cab and other parts out for blasting, I had trial fit the inside roof panel and the outer skin as well as some smaller patches in the drip rail above the door frame. I went ahead and spot welded the patches and the panel in place then butt welded and ground the seams. There are a number of small pinholes in the windshield frame and in and around the drip rail. Structurally, these areas are pretty sturdy, so rather than waste a bunch of time trying to MIG the holes and grind the area smooth, I plan to lay fiberglass in the affected areas, then cover it all with acoustic deadener before installing the outer roof skin. Suitable fix for a rat truck!
