Old 04-03-2014, 07:59 PM   #176
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1954 3100 C4 Tube Chassis Build
Not this week so far. Been rocking at work, hockey and baseball with my little man, etc. Probably this weekend for sure. will be starting a 5 window conversion soon as well!
--Josh
Old 04-03-2014, 08:08 PM   #177
FarmerSid
FarmerSid's Avatar
5 window conversion? Do tell.....Raking in the gold eh! I'm off to a three day hockey tournament tomorrow morning in Toronto (coach) so I won't be able to touch my truck till next Wednesday at the earliest. Both boys have hockey Monday and Tuesday night. I expect an update when I get back!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 04-03-2014, 10:07 PM   #178
STOCKISH
STOCKISH's Avatar
Ill do my best not to disappoint. Hope to have the 5 window stuff here soon and I will get lots of pics for everyone!
--Josh
Old 04-04-2014, 08:04 PM   #179
xpickup
xpickup's Avatar
STOCKISH, looks great. I can not wait for the 5 window swap.
Shannon
xpickup is offline   Reply With Quote
Old 04-09-2014, 03:08 PM   #180
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome build! Be sure to drive it down to Charleston when you are done!!
ChuckDriver is offline   Reply With Quote
Old 04-11-2014, 11:11 PM   #181
STOCKISH
STOCKISH's Avatar
Thanks man, Id love to go back to Charleston sometime, would be a fun road trip.
--Josh
Old 04-14-2014, 01:47 PM   #182
FarmerSid
FarmerSid's Avatar
Hey Josh. Got to thinking about the long lower control arm bolt. I know you said that it's 1/2" diam. 18" long and threaded 2" on each end. Did you use anything special for that rod?
C4 IFS & D44 IRS
5.3 HO L33
Old 04-14-2014, 11:52 PM   #183
STOCKISH
STOCKISH's Avatar
I believe its driveshaft steel they use for large electric motor driveshafts. Its like grade 10.9 or something crazy. Hows your progress coming along? You know, you need a build thread buddy!
--Josh
Old 04-16-2014, 10:11 AM   #184
STOCKISH
STOCKISH's Avatar
Was hoping for some progress last night but to no avail. Sometimes I think I should have just thrown a solid axle and leaf springs under this thing....
On a positive note, I ordered a C4 torque arm so I can get the rear end and trans tied together. Cool that it negates the need for a transmission crossmember. I just need to get the 4 trailing arms mounted so I can be done with the rear of the truck finally. Just need to find exactly where my wheelbase needs to be to center the rear tires in the fenders, my rear fender is so beat up I don't trust it to mock up and determine the final wheelbase.
--Josh
Old 04-16-2014, 10:31 AM   #185
99 to Life
99 to Life's Avatar
Do you have another fender and moch up for the other side? I don't think you could go wrong with a 117-117.9 WB. s10 swaps are 117.9 and most of them look good. anything is better than the 116 stock.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-16-2014, 10:59 AM   #186
STOCKISH
STOCKISH's Avatar
I don't have the other side fender. I'll pick up a good one and go from there. Seems like 117-118 is pretty common though. Just want to be certain .
--Josh
Old 04-16-2014, 12:02 PM   #187
jcramsey
jcramsey's Avatar
X2....excellent build. If you drive it down to Charleston, strap the 292 in the back. I want one!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-16-2014, 01:49 PM   #188
STOCKISH
STOCKISH's Avatar
Already sold it. You should have come to get it.
--Josh
Old 04-16-2014, 02:16 PM   #189
jcramsey
jcramsey's Avatar
I definitely would have...too little, too late..just found your thread today!
The Egg Hauler
The Government Mule
Old 04-16-2014, 08:14 PM   #190
STOCKISH
STOCKISH's Avatar
Ok guys, I think I have this figured out. My wheelbase is actually going to be 116". The reason is this. I wanted to push my bed a bit closer to the cab to take up some of the gap that was there. I also think I could have moved my front wheel a little further forward than I did, but at the end of the day I think it will be ok. Still looks bad ass to me and if need be I can change the front wheel openings enough to make it perfect. What do you fellas think?
--Josh
Old 04-16-2014, 08:51 PM   #191
ghettoluxury
ghettoluxury's Avatar
The rear is spot on. If it was me I would have pushed the front forward a little more.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 04-16-2014, 09:28 PM   #192
STOCKISH
STOCKISH's Avatar
Yeah, I will have to look into changing the wheel opening a bit, it looks worse because of that angle as well. I will get a better pic straight on to see what everyone thinks.
--Josh
Old 04-16-2014, 09:41 PM   #193
STOCKISH
STOCKISH's Avatar
Ok, after posting my last response I came back out to the garage to get a better picture. I looked and realized I did not have any of the alignment shims in between the control arm and the control arm mount. I put the shims back in it that were originally in the Corvette suspension when I bought it. This is how the wheel looks now. Looks perfectly centered in the wheel well as best as I can tell. Pics in a few.
--Josh
Old 04-16-2014, 09:53 PM   #194
99 to Life
99 to Life's Avatar
What I'm wondering is how you moved the bed forward and still have the same length running board? Something would have to give aka be pushing or flexing on your fenders. Do you have enough bolts in them fenders too? They have room to play up or down and the rear has play forward to back. It looks like your front fender is a tad bit high which will make that gap look off too.
IF you really wanted, you could move your bed forward say 1". Move your cab back about 1" or say .75 on each. That way your front fender moves back and centers up in the well better, if that is the real problem there and not just an illusion or whatever pics do.
Then your rear fender would relocate on the bed, thus needing different bed mounting holes (some guys do this) I've thought about doing it. Anyway, then you can keep stock running board, splash filler pan. Then just move your rear to where you want it.
Lotta options really. its also nice to have engine in there to help see where things will fall with it. i don't think you'll have any issues really and if you did you could recess firewall or a few other things.
Old 04-16-2014, 10:05 PM   #195
STOCKISH
STOCKISH's Avatar
[QUOTE=99 to Life;6632583]What I'm wondering is how you moved the bed forward and still have the same length running board? Something would have to give aka be pushing or flexing on your fenders. Do you have enough bolts in them fenders too? They have room to play up or down and the rear has play forward to back. It looks like your front fender is a tad bit high which will make that gap look off too.
Then your rear fender would relocate on the bed, thus needing different bed mounting holes (some guys do this) I've thought about doing it. Anyway, then you can keep stock running board, splash filler pan. Then just move your rear to where you want it. QUOTE]
This is what I did, I slid the bed forward but slid the fender rearward on the bed side. Still looks proportionate and gave me the smaller gap between the bad and cab that I wanted. The front fender is mounted to the cab in the factory location, the wheel was back in the wheelwell because the shims for the caster and camber adjustment werent in there. When I put the shims back in the wheel is perfectly centered front and rear now. Phew!! I knew I had centered the wheels perfectly before, I was getting worried for a minute trying to figure out what I screwed up. Pay attention to the basics!
--Josh
Old 04-16-2014, 10:37 PM   #196
ChuckDriver
Winner, winner!
Old 04-16-2014, 10:50 PM   #197
ghettoluxury
And we have a winner! That looks spot on to me.
Old 04-16-2014, 11:28 PM   #198
oldman3
oldman3's Avatar
Let's make it four for four, winner....Jim
oldman3 is offline   Reply With Quote
Old 04-17-2014, 12:26 AM   #199
mcbassin
Still Learning
mcbassin's Avatar
Awesome work Josh! Please tell me you're keeping this one...for a while at least.
mcbassin is offline   Reply With Quote
Old 04-17-2014, 12:32 AM   #200
Ozzy2013
Ozzy2013's Avatar
[quote=STOCKISH;6632604]
Looks great!
Ozzy2013 is offline   Reply With Quote
