Old 05-30-2014, 10:41 PM   #176
dman1982
dman1982's Avatar
Re: Finally starting my 5.3 swap!!
ouch
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 05-30-2014, 11:08 PM   #177
dman1982
dman1982's Avatar
http://www.fixya.com/cars/t3560837-kanuter_valve
haha
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-30-2014, 11:10 PM   #178
ivorton74
ivorton74's Avatar
lol funny
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-30-2014, 11:18 PM   #179
dman1982
dman1982's Avatar
Originally Posted by ivorton74 View Post
lol funny
I thought so...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 01:19 PM   #180
dman1982
dman1982's Avatar
Well I was talkin trash and carma got me man...fuel line came off
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 07:28 PM   #181
ivorton74
ivorton74's Avatar
lol uh oh!! how did it come out? what kinda fuel lines did u use? I used all rubber lines on mine.
Old 05-31-2014, 07:32 PM   #182
dman1982
dman1982's Avatar
A mixture of nylon covered with rubber (to protect from heat) and rubber with all quick disconnects...I put one on there as a temp for startup and forgot about it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 07:44 PM   #183
ivorton74
ivorton74's Avatar
be careful dawg...don't wanna be rolling down the street in a ball of fire.
Old 05-31-2014, 07:45 PM   #184
dman1982
dman1982's Avatar
That'll just give me a reason to go faster!!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 07:48 PM   #185
ivorton74
ivorton74's Avatar
did u do any work on ur truck today besides that fuel line issue?
Old 05-31-2014, 07:52 PM   #186
dman1982
dman1982's Avatar
Haha...didn't have to...mostly done man...looking for a good bed then off to body work, I may switch out the doors tomorrow
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 07:57 PM   #187
ivorton74
ivorton74's Avatar
kool...didn't work on mine today....probably sometime next week
Old 06-05-2014, 12:00 AM   #188
ivorton74
ivorton74's Avatar
So I've been trying to figure out why my trucks running funny and I narrowed it down to the idle air control. I found some vids on youtube of vehicles that are doing the same thing mine is... this is an example right here....https://www.youtube.com/watch?v=QHp6AKsmcVE......
so im going to try cleaning that along with the throttle body and see what happens.
Old 06-05-2014, 01:35 AM   #189
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It was running fine before right? I watched your video from the previous page, but the audio from in the cab isn't much to go by.
The perennial question; scan for codes?
IAC is controlled by a stepper motor, not a vacuum source or mechanical linkage like older vehicles. If you have a problem with that, for the most part its in the tune, unless you have another handicap with it. Make sure the maf is plugged in and sitting correctly, make sure you don't have an obvious vacuum leak. A very dirty tb can cause issues with the air gap on the blade, or worse if the bleed hole is plugged.
Anything else change? This doesn't seem like an issue from first start right, since you've put a couple miles on her.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-05-2014, 09:18 PM   #190
ivorton74
ivorton74's Avatar
It ran good when we first started it and all the times we started it. occasionally when we had the engine running the idle would drop a bit and the come back up and run smoothly again. my buddy said the pcm is probably re-learning how the engine is running now without the egr and stuff. I only drove it that one time in the video and only for a mile or so and its started to idle rough and would stall...exactly like that Ranger in that other vid I posted. I haven't been back to the shop since that time to tinker with it but I have been online researching and tryin to figure what the problem is. Im going to check the vacuum lines and make sure the intake manifold isn't leaking...ill also re-check the maf and throttle body, iac and fpr. I have to go buy the obd2 port too.
Old 06-13-2014, 08:41 PM   #191
ivorton74
ivorton74's Avatar
Update...well worked on the truck a little bit today and we found out that only half the engine is firing...running on 4 cylinders....my buddy says either the coils arent firing or the injectors are not spraying so he said he's going to work on it next week and i might have back by next weekend.
